I just noticed that the language the new voice assistant in HA expects is bound to the language the UI is set to. In my case I would prefer the UI language to be different than the language the assistant understands when speaking or writing commands. It would be great to have an option to manually set the voice assistants language (maybe also an entry like ‘automatic’ or ‘system’ which uses the same language as the UI, but still would make it possible to choose a certain language different than the UI).
Duplicate, may be worth adding your vote here instead, as this already has some traction:
Dang, I did not find it when I was looking for that… thanks for cross linking. I will close this one then…
