I’m trying to set the temperature of the generic thermostat with a automation. In this way it becomes a kind of clock thermostat. I’ve tried several things but it won’t work. I know that I can use the predefind settings like home, sleep, comfort, etc., but I want to set this in a dashboard.
Below a part of the yaml:
sequence:
- service: climate.set_preset_mode
preset_mode: comfort
entity_id: climate.badkamer
- service: climate.set_temperature
temperature: "{{input_number.badkamer_sleep_temperatuur | float}}"
Thanks for the quick response.
In a way both option worked, but with the withdraw that the temperature is set to 0.0 (with a point). The helper however works with a comma. Can that be the following problem?
Take that temperature template string and go to developer tools / templates and paste it in, what does it give you for a value?
Also typically when using a preset mode on a thermostat, this also sets the target temperature. Doing both back to back with no delay in between could cause a timing issue in the device.
