Setting the value of a helper in a Python script deletes the Helper's (friendly) "name"
I’ve created a helper:
I then update the value of this helper in a Python script like so:
hass.states.set("input_boolean.power_on_setting_has_next_entity", "on")
Now I go back to my Helpers screen in the UI, and the Helper’s friendly name (Power On Setting: Does Have Next Entity) is gone.
Why? Is this a bug? what am I doing wrong?
I don’t get any error during the automations utilizing the Python script, and everything is working OK.
Since I can only put one media in a post, here’s a screenshot of my Helpers list:
You should include the attributes in your set, or you are basically removing them.
See
Yep, found this just minutes before I got a ping about your reply. Thank you!
