I need some help setting up an output controlled by a binary sensor. I’m using an esp8266 with a float sensor to detect the water level in a sump well. I’ve been able to configure a binary sensor to detect when the switch in the sump float is open/closed. This area of the code works well. The sensor is seen in HA and performs the way I expect.
I’m trying to add an LED to indicate when the sump float switch is closed. I’ve configured Pin D1 as an output for the LED. I thought adding on_turn_on: and on_turn_off: commands to the binary sensor would work but the ESPHome editor indicates there’s an error.
I need guidance on how to achieve the desired outcome. Would you mind looking over my code and suggesting how an LED connected to a GPIO pin can be turned on/off when the binary sensor is true/false.
Here is the full code I’m trying to use;
esphome:
esp8266:
board: esp01_1m
# WiFi connection, replace these with values for your WiFi.
wifi:
ssid: !secret wifi_ssid
# Enable logging
logger:
# Enable Home Assistant API
api:
# Enable over-the-air updates.
ota:
password: !secret ota_password
# Enable Web server.
web_server:
port: 80
# Sync time with Home Assistant.
time:
- platform: homeassistant
# Text sensors with general information.
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
name: sump_water_level_monitor ESPHome Version
# Expose WiFi information as sensors.
- platform: wifi_info
ip_address:
ssid:
bssid:
# Exposed switches.
# Switch to restart the door-contact-garage.
switch:
- platform: restart
# Enable On-Board Status LED.
status_led:
pin:
number: GPIO2
inverted: true
# Uptime sensor.
- platform: uptime
# WiFi Signal sensor.
- platform: wifi_signal
name: sump_water_level_monitor WiFi Signal
update_interval: 60s
# Define output for "Sump High Level Alarm"
output:
- platform: esp8266_pwm
pin:
# Pin D1
number: GPIO5
inverted: true
binary_sensor:
- platform: gpio
pin:
# Pin D3
inverted: true
number: GPIO0
mode:
input: true
pullup: true
name: "Sump Water Level Monitor"
device_class: moisture
on_turn_on:
- output.turn_on: alarm_led
on_turn_off:
- output.turn_off: alarm_led
If the LED is on when the sensor returns to false, then it stays on. I think there needs to be an else followed by an output.turn_off. I tried adding an else after the last line of code but the compiler complains of an error.
