I’m attempting to follow the instructions for setting up my SmartThings hub with this but I’m running into a wall. I decided at this time to use Nabu Casa and not worry about opening up my server publically. My understanding with the instructions is that all I need to do is.
- Use and setup Nabu Casa
- Get my personal access token from Samsung/SmartThings
- Connect Home Assistant Cloud, logged-in with a subscription.
What other steps are there after that?
I’ve created my token.
Am I supposed to then do the Configure Home Assistant config steps? If so when I do the system is unable to complete. I get an unknown error.
Log Details (ERROR)
Tue Apr 30 2019 08:48:33 GMT-0700 (Pacific Daylight Time)
Error handling request
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py”, line 418, in start
resp = await task
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py”, line 458, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py”, line 119, in impl
return await handler(request)
File “/usr/src/app/homeassistant/components/http/real_ip.py”, line 33, in real_ip_middleware
File “/usr/src/app/homeassistant/components/http/ban.py”, line 68, in ban_middleware
File “/usr/src/app/homeassistant/components/http/auth.py”, line 216, in auth_middleware
File “/usr/src/app/homeassistant/components/http/view.py”, line 115, in handle
result = await result
File “/usr/src/app/homeassistant/components/config/config_entries.py”, line 154, in post
return await super().post(request, flow_id)
File “/usr/src/app/homeassistant/components/http/data_validator.py”, line 46, in wrapper
result = await method(view, request, *args, **kwargs)
File “/usr/src/app/homeassistant/helpers/data_entry_flow.py”, line 86, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File “/usr/src/app/homeassistant/data_entry_flow.py”, line 80, in async_configure
flow, step_id, user_input)
File “/usr/src/app/homeassistant/data_entry_flow.py”, line 98, in _async_handle_step
result = await getattr(flow, method)(user_input) # type: Dict
File “/usr/src/app/homeassistant/components/smartthings/config_flow.py”, line 79, in async_step_user
await setup_smartapp_endpoint(self.hass)
File “/usr/src/app/homeassistant/components/smartthings/smartapp.py”, line 202, in setup_smartapp_endpoint
hass, config[CONF_WEBHOOK_ID])
File “/usr/src/app/homeassistant/components/cloud/init.py”, line 105, in async_create_cloudhook
hook = await hass.data[DOMAIN].cloudhooks.async_create(webhook_id, True)
File “/usr/local/lib/python3.7/site-packages/hass_nabucasa/cloudhooks.py”, line 35, in async_create
raise ValueError(“Hook is already enabled for the cloud.”)
ValueError: Hook is already enabled for the cloud.
If it says it is already enabled, shouldn’t I see something somewhere on my devices already connection to my hub?
