And after restarting I still don’t see any sensors under “tank_utility” in HASS.
I’d like to show just a simple percentage of how much propane is in the tank for food/heating. Does anyone know how I might be able to get this to work?
I recently had to replace my Tank Utility for warranty. During the new setup I couldn’t find the 24digit number to be used. It looks like the website has been changed.
I did find it this way…
If you login to the app or website, go to your Tank Utility device and click on “Delete” device… You can then see your 24digit number and then cancel the delete.
It seems after updating to core 11.4 it stopped working. I backed out of the change and it starting working. Applied the core update again and it stopped.
Did you ever figure this out? I just installed one and can’t get it to connect to HA. This is the error I’m seeing in my logs:
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 493, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 715, in async_device_update
await task
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/tank_utility/sensor.py", line 139, in update
self._state = round(data[SENSOR_TYPE], SENSOR_ROUNDING_PRECISION)
KeyError: 'tank'
