Setup VLAN and HA tutorial
This is what I’ve been using.
192.168.10.1 is my main LAN.
HA main address is 192.168.10.6
192.168.10.4 is Pi-hole.
Valn 20 is where I keep all IOTs on opnsense
HA vLan 20 address is 192.168.20.3
Should just remove the gate way from this interface then for mdns and HA discovery to work?
Like you said, I was sometimes accessing vlan20 HA instance from my main LAN PC which is wrong as you mentioned.
If you are using the GUI of Home Assistant for network definitions, there is a way to set up an empty gateway easily: just enter “0.0.0.0” in every gateway field in each network interface (VLAN or not) that is not the main one (the one that you open the GUI in and usually the one that is set up first) :slight_smile:
Thank you. Which network adaptor should choose in my case? The vlan adaptor or the default?
Obviously it depends on what you are trying to achieve, but taking into account your description, your vlan adaptor is the segregated one, so it should not have a gateway nor a dns set up (HA does not need them in fact). If this is correct, then what you should have in HA network config is:
Main LAN
Network interface is ENP0S31F6.
Network is 192.168.10.0/24
HA main address is 192.168.10.6/24.
Gateway for this network is 192.168.10.1
DNS for this network is 192.168.10.4
VLAN
VLAN network interface is ENP0S31F6.20.
Network is 192.168.20.0/24
HA address is 192.168.20.3/24.
Gateway for this network is 0.0.0.0
DNS for this network is 0.0.0.0
Go to the terminal and run
ip r
output should be similar to this (some elements may be different, as I’m just guessing here):
 default via 192.168.10.1 dev enp0s6s31f6  metric 110
 172.30.32.0/23 dev hassio scope link  src 172.30.32.1 (these are HA specific)
 172.30.232.0/23 dev docker0 scope link  src 172.30.232.1 (these are HA specific)
 192.168.10.0/24 dev enp0s6s31f6 scope link  src 192.168.10.6  metric 110
 192.168.20.0/24 dev enp0s6s31f6.20 scope link  src 192.168.20.3  metric 110
ha network info
should produce:
- connected: true
  enabled: true
  interface: enp0s6s31f6
  ipv4:
    address:
    - 192.168.10.3/24
    gateway: 192.168.10.1
    method: static
    nameservers:
    - 192.168.10.1
    ready: true
- connected: true
  enabled: true
  interface: enp0s6s31f6.20
  ipv4:
    address:
    - 192.168.20.3/24
    gateway: null
    method: static
    nameservers:
    - 0.0.0.0
    ready: true
That’s it!
Thank you so much for taking the time to explain in detail and provide examples.
I got the exact same results after deleting the Vlan gateway and DNS.
Again, Thank you so much.
Anyone else having an issue with your adapters no longer showing up in HA? I’ve had these setup for months, but now no longer seem to want to show up within HassOS. I’ve tried deleting and recreating
Wondering what changed causing adapters not to be available to the HA container? :frowning:
seems it maybe something with os 11
Looks like there was an interface rename within the HA container from eth0 to end0
As well you can now use ‘ha’ to create a new network vlan interface immediately without rebooting and without the use of nmcli
 ha network vlan end0 3 --ipv4-method static --ipv4-nameserver 192.168.2.6 --ipv4-address 192.168.3.14/28 --ipv4-gateway 192.168.3.1
I have Home Assistant installed on a VM in Proxmox. In my network, I have several VLANs configured; the HA is on the server VLAN, and I have IoT devices on another VLAN.
Yesterday I bought an Aqara FP2, which only allows linking to HA through HomeKit. Since it was in two different VLANs, it was impossible for HA to detect it. I solved it by configuring an additional virtual network card in Proxmox for HA. I assigned the IoT network to that card, and now they can see each other. It seems like a good solution because this way mDNS works on the IoT network, and HA can access it.
Could you please share detail with newbie? Thanks!
Are you using HA in proxmox?
Thanks to @cr0muald0 's excellent tutorial I was able to create a second interface for my HA Yellow to connect to devices on my IoT VLAN on my Unifi-controlled network. I was able to configure my first device (a Sonoff Dual R3 relay) via the ESPhome dashboard, where it shows as ‘online’.
The problem is that HA doesn’t auto-discover the device. It does not show up in the Integrations dashboard. I am able to add it manually using the IP address of the device, after which all controls function as expected. While this will probably work fine for a relay which will be online 99.9% of the time, I would really like auto-discover to work properly for future devices that may not be present in my network all the time and may receive different IP addresses.
I’ve read a lot of similar issues, both on the HA forums and on other sources, but none give a definitive answer for my problem. Some suggest that mDNS network traversal should be allowed but that would be necessary only if my HA device was in a different broadcast domain. Since I added the VLAN interface to HA, that should not be necessary. Of course I tried that, but it did not work. This seems to describe my issue but it doesn’t describe exactly what he did to resolve the issue and it received no replies.
Can anyone give me some pointers on where to look next to be able to diagnose this issue?
Hey @gerritgleufhoed, so you are saying the device is in the same network segment, right? That excludes the mdns problem. What integration are you using? As far as I know, the auto-discovery only works with Tasmota flashed devices or ESPhome integrated devices, but you did not mention that clearly. Did you flash your relay with Tasmota (I’m guessing no)? Are you using the ESPhome control system? And you have the ESPhome integration installed? Only then it might auto discovery ESP flashed devices, in my understanding (my Sonoffs are all Tasmota flashed and mqtt’ed) :slight_smile:
Sorry for not stating that clearly. Yes, the relay is in the same network segment as the newly added IoT VLAN interface in HA.
I have installed the ESPhome integration into HA and flashed ESPhome to my Sonoff relay (using the web.esphome.io dashboard wizard because I’m not yet running HA on HTTPS). When looking at the ESPhome HA dashboard (not sure if I’m using the right terminology here), the relay shows as ‘online’ and I’m able to send OTA updates to it. But it does not show up as a device with sensors and switches in HA, unless I add it manually through an IP address. After doing this I can control the relay without any problems.
From what I read, ESPHome requires mdns to function properly, so you don’t have to specify an IP in Home Assistant. How did you configure your ESP?
mDNS Component
The mdns component makes the node announce itself on the local network using the multicast DNS (mDNS) protocol.
Both Home Assistant and the ESPHome dashboard use mDNS to identify the IP address of all ESPHome nodes on the network. If mDNS is disabled, they will no longer be able to automatically find your devices. It may be necessary to use a static IP for all nodes and to enable the ping option in the Home Assistant add-on.
It is recommended to leave mDNS enabled.
Example configuration entry
mdns:
disabled: false
Then Home Assistant should be able to get the node’s IP (from mDNS and create the sensors automatically). Remember, either you give the node a static IP, or if you are using DHCP server, a fixed lease.
Read the Notes on disabling mDNS here: https://esphome.io/guides/faq.html#notes-on-disabling-mdns
and you will understand better the trouble of having a misfunctioning mDNS :wink:
Thanks for the reply, but I did not specify anything regarding mDNS in my ESPhome device yaml. Because mDNS is enabled by default, it should announce itself to the ESPhome dashboard instance, which should make it available to HA. Sadly, the second part of that sentence is not happening.
From the FAQ:
Online status detection in ESPHome’s dashboard by default uses mDNS
Since the ESPHome dashboard shows the relay as online, I must conclude that mDNS is working properly. It must be something related to announcing the device’s presence to HA that is not functioning. I could use tips to start diagnosing this further.
I see. According to what you are describing, it looks like the node is added to the dashboard but not creating the sensors in HA, as it should. For that to happen, it needs to have the node’s IP properly configured, which should be configured automatically, but apparently not always. Check this thread here to see if it helps:
I had read that thread already. The quote solution unquote in that thread is to just add the ESPhome device integration manually via the IP, which works in my case as well but should not be the go-to route to add devices.
One thing I did notice is that I don’t have the captive_portal or fallback AP configured in my device setting as I don’t see the point: the device should be able to connect to the configured wifi or fail, in which case I have to fix the configuration. I cannot image that being the cause of the autodiscover failing in HA, but it’s worth a shot.
I’ll try to get some log output of the device to compare it to the log output in the thread you linked to see if I see similar output.
I read somewhere that ESPhome auto-discovery sometimes takes a long time to find (around 5 minutes), so you can always try re-adding the node and wait for a longer period (over a night, maybe) and check later the logs if the API is somehow active and interacting with HA, as it should.
Another thing to double-check is the wireless AP configuration: if it’s not filtering communication between clients (some APs have client isolation by default turned on, especially for non-standard/custom /guest wireless networks).
If you could share your node config (redacted, obviously), it might be easier to check some overlooked config problem, although that does not seem to be the cause…
The VERBOSE logs for my ESPhome relay node doesn’t give a clue:
INFO Trying to connect to mvrelay @ 10.0.30.44 in the background
INFO Successfully connected to mvrelay @ 10.0.30.44 in 0.017s
INFO Successful handshake with mvrelay @ 10.0.30.44 in 0.112s
[22:23:06][I][app:102]: ESPHome version 2023.12.5 compiled on Jan 13 2024, 22:21:36
[22:23:06][C][status_led:065]: Status Led Light:
[22:23:06][C][status_led:066]:   Pin: GPIO13
[22:23:06][C][wifi:573]: WiFi:
[22:23:06][C][wifi:405]:   Local MAC: [redacted]
[22:23:06][C][wifi:410]:   SSID: [redacted]
[22:23:06][C][wifi:411]:   IP Address: 10.0.30.44
[22:23:06][C][wifi:413]:   BSSID: [redacted]
[22:23:06][C][wifi:414]:   Hostname: 'mvrelay'
[22:23:06][C][wifi:416]:   Signal strength: -59 dB ▂▄▆█
[22:23:06][V][wifi:418]:   Priority: 0.0
[22:23:06][C][wifi:420]:   Channel: 1
[22:23:06][C][wifi:421]:   Subnet: 255.255.255.0
[22:23:06][C][wifi:422]:   Gateway: 10.0.30.1
[22:23:06][C][wifi:423]:   DNS1: 10.0.30.1
[22:23:06][C][wifi:424]:   DNS2: 0.0.0.0
[22:23:06][C][logger:443]: Logger:
[22:23:06][C][logger:444]:   Level: VERBOSE
[22:23:06][C][logger:445]:   Log Baud Rate: 115200
[22:23:06][C][logger:447]:   Hardware UART: UART0
[22:23:06][C][uart.arduino_esp32:137]: UART Bus 1:
[22:23:06][C][uart.arduino_esp32:138]:   TX Pin: GPIO25
[22:23:06][C][uart.arduino_esp32:139]:   RX Pin: GPIO26
[22:23:06][C][uart.arduino_esp32:141]:   RX Buffer Size: 256
[22:23:06][C][uart.arduino_esp32:143]:   Baud Rate: 4800 baud
[22:23:06][C][uart.arduino_esp32:144]:   Data Bits: 8
[22:23:06][C][uart.arduino_esp32:145]:   Parity: NONE
[22:23:06][C][uart.arduino_esp32:146]:   Stop bits: 2
[22:23:06][C][uptime.sensor:031]: Uptime Sensor 'Uptime'
[22:23:06][C][uptime.sensor:031]:   Device Class: 'duration'
[22:23:06][C][uptime.sensor:031]:   State Class: 'total_increasing'
[22:23:06][C][uptime.sensor:031]:   Unit of Measurement: 's'
[22:23:06][C][uptime.sensor:031]:   Accuracy Decimals: 0
[22:23:06][C][uptime.sensor:031]:   Icon: 'mdi:timer-outline'
[22:23:06][V][uptime.sensor:031]:   Unique ID: 'a842e350ed40-uptime'
[22:23:06][C][template.select:065]: Template Select 'MechanischeVentilatieSelect'
[22:23:06][C][template.select:066]:   Update Interval: 60.0s
[22:23:06][C][template.select:069]:   Optimistic: YES
[22:23:06][C][template.select:070]:   Initial Option: Low
[22:23:06][C][template.select:071]:   Restore Value: NO
[22:23:06][C][switch.gpio:068]: GPIO Switch 'mvrelay Relay Medium'
[22:23:06][C][switch.gpio:070]:   Icon: 'mdi:electric-switch'
[22:23:06][C][switch.gpio:091]:   Restore Mode: always OFF
[22:23:06][C][switch.gpio:031]:   Pin: GPIO27
[22:23:06][C][switch.gpio:033]:   Interlocks:
[22:23:06][C][switch.gpio:037]:     mvrelay Relay High
[22:23:06][C][switch.gpio:068]: GPIO Switch 'mvrelay Relay High'
[22:23:06][C][switch.gpio:031]:   Pin: GPIO14
[22:23:06][C][switch.gpio:037]:     mvrelay Relay Medium
[22:23:06][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'mvrelay Switch Medium'
[22:23:06][C][gpio.binary_sensor:016]:   Pin: GPIO32
[22:23:06][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'mvrelay Switch High'
[22:23:06][C][gpio.binary_sensor:016]:   Pin: GPIO33
[22:23:06][C][light:103]: Light 'LED'
[22:23:06][C][bl0939:130]: BL0939:
[22:23:06][C][bl0939:131]: Voltage 'mvrelay Voltage'
[22:23:06][C][bl0939:131]:   Device Class: 'voltage'
[22:23:06][C][bl0939:131]:   State Class: 'measurement'
[22:23:06][C][bl0939:131]:   Unit of Measurement: 'V'
[22:23:06][C][bl0939:131]:   Accuracy Decimals: 1
[22:23:06][C][bl0939:132]: Current 1 'mvrelay Current 1'
[22:23:06][C][bl0939:132]:   Device Class: 'current'
[22:23:06][C][bl0939:132]:   State Class: 'measurement'
[22:23:06][C][bl0939:132]:   Unit of Measurement: 'A'
[22:23:06][C][bl0939:132]:   Accuracy Decimals: 2
[22:23:06][C][bl0939:133]: Current 2 'mvrelay Current 2'
[22:23:06][C][bl0939:133]:   Device Class: 'current'
[22:23:06][C][bl0939:133]:   State Class: 'measurement'
[22:23:06][C][bl0939:133]:   Unit of Measurement: 'A'
[22:23:06][C][bl0939:133]:   Accuracy Decimals: 2
[22:23:06][C][bl0939:134]: Power 1 'mvrelay Power 1'
[22:23:06][C][bl0939:134]:   Device Class: 'power'
[22:23:06][C][bl0939:134]:   State Class: 'measurement'
[22:23:06][C][bl0939:134]:   Unit of Measurement: 'W'
[22:23:06][C][bl0939:134]:   Accuracy Decimals: 0
[22:23:06][C][bl0939:135]: Power 2 'mvrelay Power 2'
[22:23:06][C][bl0939:135]:   Device Class: 'power'
[22:23:06][C][bl0939:135]:   State Class: 'measurement'
[22:23:06][C][bl0939:135]:   Unit of Measurement: 'W'
[22:23:06][C][bl0939:135]:   Accuracy Decimals: 0
[22:23:06][C][bl0939:136]: Energy 1 'mvrelay Energy 1'
[22:23:06][C][bl0939:136]:   Device Class: 'energy'
[22:23:06][C][bl0939:136]:   State Class: 'total_increasing'
[22:23:06][C][bl0939:136]:   Unit of Measurement: 'kWh'
[22:23:06][C][bl0939:136]:   Accuracy Decimals: 3
[22:23:06][C][bl0939:137]: Energy 2 'mvrelay Energy 2'
[22:23:06][C][bl0939:137]:   Device Class: 'energy'
[22:23:06][C][bl0939:137]:   State Class: 'total_increasing'
[22:23:06][C][bl0939:137]:   Unit of Measurement: 'kWh'
[22:23:06][C][bl0939:137]:   Accuracy Decimals: 3
[22:23:06][C][bl0939:138]: Energy sum 'mvrelay Energy Total'
[22:23:06][C][bl0939:138]:   Device Class: 'energy'
[22:23:06][C][bl0939:138]:   State Class: 'total_increasing'
[22:23:06][C][bl0939:138]:   Unit of Measurement: 'kWh'
[22:23:06][C][bl0939:138]:   Accuracy Decimals: 3
[22:23:06][C][restart.button:017]: Restart Button 'Restart'
[22:23:06][C][mdns:115]: mDNS:
[22:23:06][C][mdns:116]:   Hostname: mvrelay
[22:23:06][V][mdns:117]:   Services:
[22:23:06][V][mdns:119]:   - _esphomelib, _tcp, 6053
[22:23:06][V][mdns:121]:     TXT: friendly_name = MVrelay
[22:23:06][V][mdns:121]:     TXT: version = 2023.12.5
[22:23:06][V][mdns:121]:     TXT: mac = a842e350ed40
[22:23:06][V][mdns:121]:     TXT: platform = ESP32
[22:23:06][V][mdns:121]:     TXT: board = esp32dev
[22:23:06][V][mdns:121]:     TXT: network = wifi
[22:23:06][V][mdns:121]:     TXT: api_encryption = Noise_NNpsk0_25519_ChaChaPoly_SHA256
[22:23:06][C][ota:097]: Over-The-Air Updates:
[22:23:06][C][ota:098]:   Address: mvrelay.local:3232
[22:23:06][C][ota:101]:   Using Password.
[22:23:06][C][api:139]: API Server:
[22:23:06][C][api:140]:   Address: mvrelay.local:6053
[22:23:06][C][api:142]:   Using noise encryption: YES
[22:23:06][C][wifi_signal.sensor:009]: WiFi Signal 'RSSI'
[22:23:06][C][wifi_signal.sensor:009]:   Device Class: 'signal_strength'
[22:23:06][C][wifi_signal.sensor:009]:   State Class: 'measurement'
[22:23:06][C][wifi_signal.sensor:009]:   Unit of Measurement: 'dBm'
[22:23:06][C][wifi_signal.sensor:009]:   Accuracy Decimals: 0
[22:23:06][V][wifi_signal.sensor:009]:   Unique ID: 'a842e350ed40-wifisignal'
Here is my node config:
substitutions:
  devicename: mvrelay
  max_temp: "85.0"
esphome:
  friendly_name: MVrelay
  # Ensures that, after a reboot, the ventilation will go to the state reflected by the physical knob. Since the relais go off first during the boot, the default value is already "Low" and does not need to be defined anymore.
  on_boot:
    if:
        binary_sensor.is_on: switch_medium
      then:
        - select.set:
            option: "Medium"
      else:
        if:
            binary_sensor.is_on: switch_high
          then:
            - select.set:
                option: "High"
# Enable logging
logger:
  level: INFO
# Enable Home Assistant API
api:
  encryption:
    key: !secret mvrelay_api_key
ota:
  password: !secret ota_secret
wifi:
  ssid: !secret wifi_ssid
esp32:
  board: esp32dev
  - platform: wifi_signal
    update_interval: 90s
    entity_category: "diagnostic"
  - platform: uptime
    update_interval: 300s
  - platform: bl0939
    update_interval: 60s
    voltage:
    current_1:
      name: ${devicename} Current 1
      disabled_by_default: True
    current_2:
      name: ${devicename} Current 2
    active_power_1:
      name: ${devicename} Power 1
    active_power_2:
      name: ${devicename} Power 2
    energy_1:
      name: ${devicename} Energy 1
    energy_2:
      name: ${devicename} Energy 2
    energy_total:
      name: ${devicename} Energy Total
light:
  - platform: status_led
    pin:
      number: GPIO13
      inverted: True
    internal: True
button:
  - platform: restart
uart:
  tx_pin: GPIO25
  rx_pin: GPIO26
  baud_rate: 4800
  parity: NONE
  stop_bits: 2
switch:
  - platform: gpio
    name: ${devicename} Relay Medium
    pin: GPIO27
    icon: "mdi:electric-switch"
    restore_mode: always_off
    # Ensure only one switch at a time is on (https://esphome.io/components/switch/gpio.html#interlocking)
    interlock: &interlock_group [Relay_Medium, Relay_High]
    on_turn_on:
      then:
        - select.set:
            option: "Medium"
    on_turn_off:
      then:
        - select.set:
            option: "Low"
  - platform: gpio
    name: ${devicename} Relay High
    pin: GPIO14
    interlock: *interlock_group
    on_turn_on:
      then:
        - select.set:
            option: "High"
    on_turn_off:
      then:
        - select.set:
            option: "Low"
binary_sensor:
  - platform: gpio
    name: ${devicename} Switch Medium
    pin:
      number: GPIO32
      mode:
        input: True
        pullup: True
      inverted: True
    filters:
      - delayed_on_off: 50ms
    publish_initial_state: false
    on_press:
      then:
        - select.set:
            option: "Medium"
    on_release:
      then:
        - select.set:
            option: "Low"
  - platform: gpio
    name: ${devicename} Switch High
    pin:
      number: GPIO33
      mode:
        input: True
        pullup: True
      inverted: True
    filters:
    on_press:
      then:
        - select.set:
            option: "High"
    on_release:
      then:
        - select.set:
            option: "Low"
select:
    options:
     - "Low"
     - "Medium"
     - "High"
    restore_value:  false
    optimistic: true
    on_value:
      then:
        - lambda: |-
            if (id(mvselect).state == "Low") {
            id(Relay_Medium).turn_off();
            id(Relay_High).turn_off();
            } else if (id(mvselect).state == "Medium") {
              id(Relay_Medium).turn_on();
            } else if (id(mvselect).state == "High") {
              id(Relay_High).turn_on();
If you find anything wrong with this config, please let me know :slight_smile:
I also checked the ESPhome add-on config and it actually has a setting called
Home Assistant Dashboard Integration
which is disabled by default (at least in my case). Enabling it does nothing different. Here are the logs since the most recent restart of the ESPhome add-on:
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
[21:46:28] INFO: Configuring timezone (Europe/Amsterdam)...
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service esphome: starting
s6-rc: info: service esphome successfully started
s6-rc: info: service init-nginx successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service discovery: starting
[21:46:31] INFO: Waiting for ESPHome dashboard to come up...
[21:46:31] INFO: Starting ESPHome dashboard...
2024-01-13 21:46:32,469 INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome...
[21:46:32] INFO: Starting NGINX...
2024-01-13 21:46:33,536 INFO 304 GET / (0.0.0.0) 15.29ms
2024-01-13 21:46:33,610 INFO 304 GET /devices (0.0.0.0) 4.07ms
[21:46:33] INFO: Successfully send discovery information to Home Assistant.
s6-rc: info: service discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
2024-01-13 21:46:38,615 INFO 304 GET /devices (0.0.0.0) 4.03ms
[repeating]
2024-01-13 21:47:44,033 INFO 304 GET /devices (0.0.0.0) 2.96ms
2024-01-13 21:48:37,061 INFO 304 GET / (0.0.0.0) 2.80ms
2024-01-13 21:48:37,174 INFO 304 GET /devices (0.0.0.0) 4.14ms
2024-01-13 21:48:39,696 INFO 200 GET /static/js/esphome/c.VPeQYmPp.js (0.0.0.0) 33.61ms
2024-01-13 21:48:39,743 INFO 200 GET /static/js/esphome/c.nIEdC0BA.js (0.0.0.0) 3.97ms
2024-01-13 21:48:39,749 INFO 200 GET /static/js/esphome/c.bcXJSIrw.js (0.0.0.0) 3.13ms
2024-01-13 21:48:39,754 INFO 200 GET /static/js/esphome/c.KwoaAax2.js (0.0.0.0) 2.69ms
2024-01-13 21:48:39,836 INFO 200 GET /static/js/esphome/c.g39gNE03.js (0.0.0.0) 3.92ms
2024-01-13 21:48:39,867 INFO 101 GET /logs (0.0.0.0) 1.65ms
2024-01-13 21:48:39,871 INFO Running command 'esphome --dashboard logs /config/esphome/mvrelay.yaml --device 10.0.30.44'
2024-01-13 21:48:42,168 INFO 304 GET /devices (0.0.0.0) 3.13ms
[repeating]
2024-01-13 21:49:37,253 INFO 304 GET /devices (0.0.0.0) 2.99ms
2024-01-13 21:49:42,143 INFO 200 GET /static/js/esphome/c.JK_Zc7F3.js (0.0.0.0) 11.83ms
2024-01-13 21:49:42,259 INFO 304 GET /devices (0.0.0.0) 3.04ms
2024-01-13 21:49:43,226 INFO 101 GET /validate (0.0.0.0) 1.07ms
2024-01-13 21:49:43,229 INFO Running command 'esphome --dashboard config /config/esphome/mvrelay.yaml --show-secrets'
2024-01-13 21:49:44,611 INFO Process exited with return code 0
2024-01-13 21:49:47,259 INFO 304 GET /devices (0.0.0.0) 2.72ms
2024-01-13 21:49:52,214 INFO 101 GET /logs (0.0.0.0) 1.29ms
2024-01-13 21:49:52,217 INFO Running command 'esphome --dashboard logs /config/esphome/mvrelay.yaml --device 10.0.30.44'
2024-01-13 21:49:52,262 INFO 304 GET /devices (0.0.0.0) 2.06ms
2024-01-13 21:49:57,265 INFO 304 GET /devices (0.0.0.0) 2.65ms
2024-01-13 21:50:19,020 INFO 304 GET / (0.0.0.0) 1.65ms
2024-01-13 21:50:19,074 INFO 304 GET /devices (0.0.0.0) 2.70ms
2024-01-13 21:54:00,399 INFO 304 GET / (0.0.0.0) 1.71ms
2024-01-13 21:54:00,482 INFO 304 GET /devices (0.0.0.0) 3.68ms
2024-01-13 21:54:05,454 INFO 304 GET /devices (0.0.0.0) 2.57ms
2024-01-13 21:57:30,227 INFO 304 GET / (0.0.0.0) 2.72ms
2024-01-13 21:57:30,283 INFO 304 GET /devices (0.0.0.0) 4.40ms
2024-01-13 21:57:33,097 INFO 101 GET /logs (0.0.0.0) 1.11ms
2024-01-13 21:57:33,613 INFO Running command 'esphome --dashboard logs /config/esphome/mvrelay.yaml --device 10.0.30.44'
2024-01-13 21:57:35,296 INFO 304 GET /devices (0.0.0.0) 2.11ms
[repeating]
2024-01-13 21:58:51,340 INFO 304 GET /devices (0.0.0.0) 2.70ms
2024-01-13 21:58:56,299 INFO 200 GET /static/js/esphome/c.L2HzI1eb.js (0.0.0.0) 11.33ms
2024-01-13 21:58:56,306 INFO 200 GET /edit?configuration=mvrelay.yaml (0.0.0.0) 2.79ms
2024-01-13 21:58:56,326 INFO 200 GET /static/js/esphome/monaco-editor/esm/vs/editor/editor.worker.js (0.0.0.0) 3.97ms
2024-01-13 21:58:57,054 INFO 200 GET /static/fonts/codicon.ttf (0.0.0.0) 12.42ms
2024-01-13 21:58:57,387 INFO 101 GET /ace (0.0.0.0) 1.39ms
2024-01-13 21:58:57,390 INFO Running command 'esphome --dashboard -q vscode --ace /config/esphome'
Not sure if that helps, though.
I don’t see anything wrong, maybe you can increase the verbosity of the log in the node for the desired components and check if there is more info. Something like this:
 logger:
   level: INFO
   logs:
     mdns: DEBUG
     api: DEBUG
Another option is to check the API component and set rules to log when the connection occurs (if it occurs at all) and see what happens:
Like here in the example:
The other possible way is to try and ping or resolve the mdns address from Home Assistant to see if it’s working, given the fact that ESPhome integration needs mdns connection for auto-discovery to work.
As I don’t have it installed myself, it’s difficult to be more helpful :frowning:
I got it working! And I think I know what the problem was:
When you add a new VLAN interface through nmcli, it allows the HA instance to communicate with the VLAN and its devices (hence the ESPhome dashboard finds the relay without issue), but it does nothing with the HA configuration itself. HA is configured to Auto Configure the network adapters the integrations will use by default and it seems that it does not detect an added VLAN adapter automatically.
I found another thread a few days ago which hinted at the solution but didn’t state it explicitly. I hope this will help others who run into the same issue. You simply need to go to Settings - System - Network, go to the Network Adapter settings, unselect Auto Configure and select the adapters that are detected (in my case: end0 and end0.30). You will need to reboot the HA device manually for this to take effect.
By reverting back to the Auto Configure setting, I replicated my problem and the ESP node is not detected anymore. This could actually be worth a bug report, what do you think?
