I’m new to HA and am considering replacing my current home automation with HA.
To make sure I can do all that I need, I am currently playing around with hass.io and, despite looking quite a bit on the forum, I could not find how to do the following:
I want to send command to my onkyo receiver via eiscp. This is possible with a full fledged HA installation as detailed in this post:
However in the case of hassio, I don’t know which path to use to call the onkyo component (basically what should I use instead of “/srv/homeassistant/homeassistant_venv/bin/onkyo” ).
I’ve tried various path but could not figure out the correct one.
Note: I know I can install custom components in hassio, but since the onkyo component is already integrated in HA, I don’t want to install a new component, I just want to be able to call the existing one.
PS: I tried to search for the component using SSH (connecting to the hassio machine), but since hassio runs inside a docker, I don’t know how to search for the path inside that docker …
I’m not using hassio but I’m running HA using the “regular” Docker image.
The onkyo command in that one is at /usr/local/bin/onkyo.
You can get a shell inside a running Docker container by typing “docker exec -ti <container> /bin/bash”.
From there, a simple “find / -name onkyo” will show you where the file is located.
Thanks a lot for the answer. It seems however that hassio does not behave the same way. The path you mentioned does not work for me and “docker” is not recognized as a valid command in the SSH command line of hassio. I guess hassos is quite restricted in terms of commands.
I am actually using the HA built in Onkyo component for controlling the volume and input sources. However, as far as I have seen, the built in component does not enable to start web radios or control other network sources which the Onkyo can do. For this I have read on the forum that I need to send the commands via the eiscp command line. That’s why I need the path of the built in Onkyo component so I can send commands using a command line script… Am I going at it the wrong way, or should I install a full fledged version of Home Assistant instead of hassio ?
Ah OK. Then yes you’d need the shell commands for this. Personally I’ve not give down that road I use the chromecast feature to send online audio to my onkyo
Check this post for more info
Sorry for pasting this in many different conversations, but it seems it may be useful to other users like myself who are relatively new to hassio and may have a hard time finding the info in different conversations, I think this summarizes all I found in an afternoon of research (and finally I got it working!)
for that to work in gui: you go on lovelace, and add a button called -in my example- onkyo_test.
This worked.
following the above, there are a ton of commands that should be usable and they are documented here:
in particular, once you understand the logic, the file https://github.com/miracle2k/onkyo-eiscp/blob/b27e8158c09b04a2160e395d9710f6748f431bf5/eiscp-commands.yaml
is particularly rich of information , for example there are commands to setup listening-mode (stereo, direct, etc), audyssey-dynamic-eq, late-night, music-optimizer-sound-retriever, audyssey-dynamic-volume, preset-memory / preset / internet-radio-preset (1-40 for network radios eg), etc etc etc
I’d been searching for so long trying to figure out how to do this! I combined it with a Sensor so that I get get all the sources for my Onkyo receiver.
For those that find this coming from the Onkyo - Home Assistant page this is how I achieved it:
Add this to configuration.yml (replacing the IP with that of your Onkyo receiver).
