Shelly 2 as roller shutter with percentage
Ok, if anyone would like to know, I did the following script:
'XXX0368406XXX':
  alias: Open all shutters
  sequence:
  - data:
      entity_id: group.all_covers
      position: '90'
    service: cover.set_cover_position
'XXX0368627XXX':
  alias: Close all Shutter
  sequence:
  - data:
      position: '20'
'XXX0370593XXX':
  alias:stop all
  sequence:
  - data:
    service: cover.stop_cover
And this is the card in lovelace yam
cards:
  - type: entities
    title: Azioni
    show_header_toggle: false
    entities:
      - entity: script.XXX0368406XXX
        icon: mdi:window-open
      - entity: script.XXX0368627XXX
        icon: mdi:window-closed
      - entity: script.XXX0370593XXX
        icon: mdi:stop
Would you mind to share your config how and where to setup the shellies as cover?
hello to all
i want to acess rollers from HA but also from the app.
i have 2.5
currently i have all working with mqtt but it does not allow to have also cloud acess
how can i setup to use rest? thanks a lot
Itā€™s not possible
You can use the cloud and Shelly REST API, but no MQTT
Just use this component, it works great:
Iā€™ve tried to use this component, but Iā€™m getting issue even Iif I donā€™t get any error message in the log.
Can you have any suggestion?
This is my last post in the thread, but I havenā€™t got any answer yet.
Itā€™s been working with no such issues for me, installed 3 months ago. I use it with automations for roller shutters with position control, also with a Pro4ā€¦ Maybe open an Issue at Github, devs seem to be more responsive thereā€¦
for me also not working :frowning:
Try to open an issue on Github, he answered to me.
The thread here is not the right place, I donā€™t see a lot of activity.
Hi, I just updated my shelly 2.5 and now I receive this error in the log:
Payload is not integer within range: -1
I have them added like this:
- platform: mqtt
  state_topic: "shellies/shellyswitch25-xxxx/roller/0"
  command_topic: "shellies/shellyswitch25-xxxx/roller/0/command"
  position_topic: "shellies/shellyswitch25-xxxx/roller/0/pos"
  set_position_topic: "shellies/shellyswitch25-xxxx/roller/0/command/pos"
  payload_open: "open"
  payload_close: "close"
  payload_stop: "stop"
  state_open: "open"
  state_closed: "close"
  retain: false
  optimistic: false
  qos: 0
  position_open: 100
  position_closed: 0
Anyone else with this problem?thanks
SOLVED: positioning calibration had been reset
Hi , I got 3 shelly 2.5 using in home assistant and in shelly app. They are set to works as roller shutters and from app they works fine. In home assistant I got discovery entity showing only 1 shelly as ā€œcoverā€ meanwhile the others 2 are shown as simply ā€œswitchesā€ entity. I installed also shellyfor hass with no lucky.
How can I made HA discover the 2 ā€œswitchā€ shelly as cover to works in HA and into the shelly app.
Iā€™m a newbie so all suggestions are welcome.
The 1 ā€œcoverā€ roller shutters is well configured and working in hadashboard trough ā€œcoverā€ template, but the other two at the moment are useless.
Attached a screenshot of what discover shellyfor hass
Hi I use it but it discovers only one roller shutter instead of 3. The other two are recognized as switch entity. Any suggestion to have them as roller shutter?
Where they set up as roller shutters (instead of double really switch) before they were added to HA?
They are setted as roller shutters (all 3) in shelly app. Here they works flawlessy. Where should I set them otherwise?
Try uninstalling the Shelly component (HACS) and install again, see if they are detected correctly this time.
Are u checking Mqtt option on shelly app for all ur device?
Just add a cover for every one like I type before
I discover, thankfully to ShellyforHass author Hakana, that restricted logon at web interface of shelly app disable recognizment.
Now I unrestricted both the 2 shelly unrecognized as cover entities but only one change state from switch to cover. I tried uninstall the plugin (but Not HACS) Shellyfor Hass with not avail. Situation now 2 of 3 are in entities state of cover.
Something is missing for the last one.
EDIT remember to DISABLE RESTRICTED ACCES
EDIT 2 or how Hakana says ā€œEther you have to remove restricted login or you can enter a username and password under shelly in HASS config. You donā€™t need to uninstall/reinstall Shelly, just restart HASS after change in config or Shellyā€
Iā€™m brand new to Home Assistant, and learning as I go, I would love a step-by-step tutorial on how to do things and how things are organized, but Iā€™ve not found yet what Iā€™m looking for.
For now Iā€™m going as I can and I want to integrate my Shelly 2.5 on Home Assistant, but I do not want to loose cloud accessā€¦
When activating MQQT it sayā€™s Iā€™ll loose cloud accessā€¦ So Iā€™m thinking on REST APIā€¦ Have anyone already made that control with REST API instead of MQQT?
I know MQQT is better, but Iā€™d rather use not so good REST API and keep Cloud access with standard firmwareā€¦
I want to make something as shown above, up/stop/down and % slider for my rollers, anyone kind to give me a help on that?
Thanks,
Julio Silva
You can use everything together. Just install ShellyForHass. Here is the link:
It is very easy and will add all your shellys to home assistant. You can still use your cloud and anything.
Thanks for your answer, Iā€™ve got it working now very easy!
How can I add a slider with this configuration, since I do not have MQQT enable?
Thanks!
