Shelly Blu Beacon Problem!
I can’t get my Shelly Blu to work as a beacon tracker. I have entered the configuration.yaml
Example configuration.yaml entry
device_tracker:
  • platform: bluetooth_le_tracker
Then restarted HA.
Where can I find the know_devices.yaml file? I cannot find the /Config folder.
known_devices.yaml is deprecated.
Is the documentation out of date?
Is there another alternative to incorporating a Shelly Beacon? I don’t understand the information on the link.
If the documentation refers to known_devices.yaml then it is out of date. You haven’t shown what documentation you are refering to.
Bluetooth LE Tracker - Home Assistant (home-assistant.io)
