Shelly devices are not updating Energy entity (kWh) ?!
I have a small problem with my Shelly integration : i have more than 120 devices and only 3 of them have a working Energy entity. The rest stay at 0 since a couple of days ago.
I don’t know what broke because it was working before.
The Energy (kWh) entity is here for all devices but stay at 0.
The Power (W) entity is working fine.
Thanks.
Interesting. This post was just made too:
https://community.home-assistant.io/t/shelly-em-power-kwh-always-zero-but-wattage-kw-reading-fine-why/434004
I suggest you make the same checks as detailed there. What devices are you using?
Ok thanks for your link, i found the solution !
I use a firewall rule to restrict internet access to my Shelly and they need internet to get time and calculate kWh.
Thanks !
Thanks for reporting your solution. It might help the other person with the issue.
