Hi, sorry for not responding. Not getting the emails.
I appreciate your input but I think there are some terms I’m not using correctly.
Correct, I mean the four strings would not be outputting the exact same amount at any time.
Yes, all four strings are connected to one panel with a 240VAC connection to the utility meter that runs backwards.
I’m trying to find a way of monitoring each string separately.
I figure that when there is no sunlight, I’ll have a fixed base to start from which would be the power from the utility since it’s a grid tied system. When there is sunlight, I would see the difference above that base and would extract what I’ve generated. Basically, building a chart over time.
Since all four strings are tied into two legs of the 240VAC utility, it sounds like you’re saying there would not really be any way of monitoring each string, only the total and not with this device.
LOL, just can’t seem to find a way to monitor this thing.
Would the pro version do the trick?
I found this which seems interesting.
UPDATED SINCE LAST SEEN
What a weird and useless rule? New members can only post three times in a thread? The idea of throttling users is to make sure they aren’t spammers. It should not be to frustrate them into leaving.
Anyhow, hope you’ll notice this response…
I think we’re out of sync :).
The main thing I’m trying to understand and or do is to monitor both legs of the 240VAC.
It seems that is not possible with this shelly device as I would have to double the reading which is not accurate in my mind.
Since this is the case, I would need to use another model of the shelly that would allow me to do what I need or some other brand. I don’t know which model might handle what I need.
More importantly, I don’t understand why the shelly EM has two CTs since I can only use one. The marketing seemed to imply I could monitor 240VAC circuits but that doesn’t seem to be the case.
What is the point of this EM then? What can I use it for with two CT’s?
I have something called ‘current cost’ which comes with two CT’s and that’s always worked perfectly, showing the correct output which I can confirm since the loads are on UPS’s with their own metering.
