Hi guys,
so one of my Shelly Plugs just suddenly became unavailable. So I removed it and wanted to re-add it, which fails. I see a bunch of error messages though:
Logger: aioshelly.block_device
Source: /usr/local/lib/python3.9/site-packages/aioshelly/block_device.py:130
First occurred: 20:00:35 (272 occurrences)
Last logged: 21:17:48
device 192.168.70.134 initialize error - TimeoutError()
My environment:
version: core-2021.12.10
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.7
os_name: Linux
os_version: 5.10.63-v8
arch: aarch64
timezone: Europe/Berlin
host_os: Home Assistant OS 7.1
update_channel: stable
supervisor_version: supervisor-2021.12.2
docker_version: 20.10.9
disk_total: 28.3 GB
disk_used: 8.7 GB
healthy: true
supported: true
board: rpi4-64
supervisor_api: ok
version_api: ok
installed_addons: Mosquitto broker (6.0.1), Zigbee2mqtt (1.22.2-1), NGINX Home Assistant SSL proxy (3.1.1), Remote Backup (4.2.7), Network UPS Tools (0.9.1), Studio Code Server (4.1.0), Hyperion.NG (2.0.12), VLC (0.1.3)
dashboards: 6
resources: 6
mode: storage
There are four Shelly Plugs, all are the same model, three work, one does not. They are on a different subnet, but the firewall allows the traffic. Firmware is up to date on all of them
Did you make sure COAP is enabled on the plug?
I had this once with one of my Shelly Door Window sensors - if you do not see the COAP option within the configuration page at all check for firmware update
Hi Martin, thanks for your input.
Do you moan CoIoT? Because that is and has been enabled since day one.
Firmware is up-to-date, just updated before writing this post.
Update: I just checked from the command line: I can reach the plug on port 80 as any other plug. So it must be something below the HTTP protocol, right?
I am afraid I have to do a factory reset.
Thanks for your input @Eiphu5ae, but I both enabled CoIoT in unicast mode and I can rule out firewall issues. But I am still hopeful someone has a striking idea and I can avoid factory resetting the Shelly plug.
I actually do that for sensors, but for active devices which I want to control, I would like to stick to the integration.
I will probably do a factory reset, when I find time. Will update here, if that helps.
Thanks everyone for your input so far!
@lpt2007 Check the devices for firmware updates. Mine also had an older version and I needed to update their firmware before being able to connect them.
The most recent FW version for Shelly Plug S is: 20220209-094058/v1.11.8-g8c7bb8d.
If your device somehow cannot see it, you can force the update using this page: http://archive.shelly-tools.de/
Shelly plug S is identified with SHPLG-S identifier.
I see others having issues with Shelly Plug S devices, so I’ll pitch in with mine:
I have a couple of these now, both share a strange behaviour:
In HA, the devices seem to work ok, turn on and off as requested…
In Shelly APP however, the devices are unresponsive (partly). Partly in a sense that they allow edits, show good wifi signal, but won’t turn ON or OFF, unless I “wake them up” via HA first. Then they start working in the Shelly APP as well…for a while, after a couple of hours they are again (partly) unresponsive.
