Hello.
I got so much knowledge from this community that I want to share something what I did.
Below i present You the way which I made my window shutters fallow sun so it will not be dark in whole home but the sun will not heat up interior of house. IRL with outside shutter this drags temperatures by about 8 degrees.
I know there is probably elegant way of coding it but I did not touched my code since it started working.
Below is not including automation opening and closing shutters on sunrise or sundown since You probably already did it if You have shutters.
Here we go:
For simplifying thinking of automations I have crated adjusted azimuth. In simple words this is compensating what household is calling south and what actual south is You have to get this on Your own by doing some trigonometry on maps and change 27 in value template:
sensors:
sun_azimuth:
friendly_name: "Sun Azimuth"
unit_of_measurement: 'Ā°'
value_template: "{{ state_attr('sun.sun', 'azimuth')-27|round(0) }}"
Second thing is tu prepare input boolean that will be responsible for not allowing further automations to run for eg. while watching movies on screen or during winter when we are lacking sun. I made two separate for winter and watching movies but one should be enough.
I did this by adding two input booleans in Config > Helpers.
If you have shutters (dirven by mqtt) on balcony windows and contact snsors You will be interested in adding this kind of automations for each window ( by adjusting topic) . It simply blocks tasmota device for executing orders:
- id: "1601917502766"
alias: Roleta NG blokada
description: ""
- platform: state
entity_id: binary_sensor.dws_okno_garaz_contact
condition: []
- choose:
- conditions:
- condition: state
state: "on"
sequence:
- service: mqtt.publish
topic: cmnd/roleta/RolNG/Backlog
payload: ShutterLock1 1
- conditions:
- condition: state
state: "off"
sequence:
payload: ShutterLock1 0
default: []
mode: single
max_exceeded: silent
Next thing You want to do is to group shutters by āso calledā/household
cardinal directions since we compensated that in first step. This can be don wherever you have Your cvers configured:
- platform: group
name: wschod # east
entities:
- cover.rolepw
- cover.rolelw
- platform: group
entities:
- cover.roleng
- platform: group
entities:
- cover.rolelbw
- platform: group
entities:
- cover.rolegos
- cover.rolept
- cover.rolelt
- cover.rolepbw
Main part: I have divided sun azimuth to diffrent directions and this is what triggers shutters. Shutters that are perpendicular (or almost) to sun rays are closed other one are slightly opened and those which are in shadow are opened.
- alias: Rolety 67,5
platform: numeric_state
entity_id: sensor.sun_azimuth
above: 67
below: 90
condition:
condition: and
conditions:
- condition: state
entity_id: sun.sun
state: above_horizon
- condition: state
entity_id: input_boolean.kino_rolety
state: "off"
- condition: state
entity_id: input_boolean.zima_rolety
state: "off"
- condition: time
after: 07:00:00
- service: COVER.SET_COVER_POSITION
entity_id: cover.polnoc
position: 50
entity_id: cover.wschod
position: 0
entity_id: cover.poludnie
position: 100
entity_id: cover.zachod
position: 100
- alias: Rolety 90
above: 90
below: 112
condition:
condition: and
conditions:
- condition: state
entity_id: sun.sun
- condition: state
state: "off"
- condition: state
state: "off"
- condition: time
after: 07:00:00
position: 100
position: 0
position: 100
position: 100
- alias: Rolety 112
above: 112
below: 135
condition:
condition: and
conditions:
- condition: state
entity_id: sun.sun
- condition: state
state: "off"
- condition: state
state: "off"
- condition: time
after: 07:00:00
position: 100
position: 0
position: 50
position: 100
- alias: Rolety 135
above: 135
below: 157
condition:
condition: and
conditions:
- condition: state
entity_id: sun.sun
- condition: state
state: "off"
- condition: state
state: "off"
- condition: time
after: 07:00:00
position: 100
position: 20
position: 20
position: 100
- alias: Rolety 157
above: 157
below: 180
condition:
condition: and
conditions:
- condition: state
entity_id: sun.sun
- condition: state
state: "off"
- condition: state
state: "off"
- condition: time
after: 07:00:00
position: 100
position: 50
position: 0
position: 100
- alias: Rolety 180
above: 180
below: 202
condition:
condition: and
conditions:
- condition: state
entity_id: sun.sun
- condition: state
state: "off"
- condition: state
state: "off"
- condition: time
after: 07:00:00
position: 100
position: 100
position: 0
position: 20
- alias: Rolety 202,5
above: 202
below: 225
condition:
condition: and
conditions:
- condition: state
entity_id: sun.sun
- condition: state
state: "off"
- condition: state
state: "off"
position: 100
position: 100
position: 0
position: 0
- alias: Rolety 225
above: 225
below: 247
condition:
condition: and
conditions:
- condition: state
entity_id: sun.sun
- condition: state
state: "off"
- condition: state
state: "off"
position: 100
position: 100
position: 20
position: 20
- alias: Rolety 247
above: 247
below: 270
condition:
condition: and
conditions:
- condition: state
entity_id: sun.sun
- condition: state
state: "off"
- condition: state
state: "off"
position: 100
position: 100
position: 100
position: 20
- alias: Rolety 270
above: 270
below: 292
condition:
condition: and
conditions:
- condition: state
entity_id: sun.sun
- condition: state
state: "off"
- condition: state
state: "off"
position: 100
position: 100
position: 100
position: 0
- alias: Rolety 292
above: 292
below: 315
condition:
condition: and
conditions:
- condition: state
entity_id: sun.sun
- condition: state
state: "off"
- condition: state
state: "off"
position: 100
position: 100
position: 100
position: 0
- alias: Rolety 315
above: 315
below: 350
condition:
condition: and
conditions:
- condition: state
entity_id: sun.sun
- condition: state
state: "off"
- condition: state
state: "off"
position: 100
position: 100
position: 100
position: 20
If You have some automations that will block above ones by input_booleans you can use this to get them to actual state. This is what I use when I am done watchng movies on projector:
- id: "1591476305397"
alias: Koniec seansu
description: ""
- entity_id: input_boolean.kino
platform: state
to: "off"
condition: []
#bunch of other things happening not related to this topic
- service: automation.trigger
data_template:
entity_id:
"{% if states('sensor.sun_azimuth') | float >= 45 and states('sensor.sun_azimuth')\
\ | float < 67 and is_state('sun.sun', 'above_horizon') %} \n automation.rolety_45\n\
{% elif states('sensor.sun_azimuth') | float >= 67 and states('sensor.sun_azimuth')\
\ | float < 90 and is_state('sun.sun', 'above_horizon') %} \n automation.rolety_675\t\
\n{% elif states('sensor.sun_azimuth') | float >= 90 and states('sensor.sun_azimuth')\
\ | float < 112 and is_state('sun.sun', 'above_horizon') %} \n automation.rolety_90\t\
\n{% elif states('sensor.sun_azimuth') | float >= 112 and states('sensor.sun_azimuth')\
\ | float < 135 and is_state('sun.sun', 'above_horizon') %} \n automation.rolety_112\t\
\n{% elif states('sensor.sun_azimuth') | float >= 135 and states('sensor.sun_azimuth')\
\ | float < 157 and is_state('sun.sun', 'above_horizon') %} \n automation.rolety_135\t\
\n{% elif states('sensor.sun_azimuth') | float >= 157 and states('sensor.sun_azimuth')\
\ | float < 180 and is_state('sun.sun', 'above_horizon') %} \n\
\ automation.rolety_157\t\n{% elif states('sensor.sun_azimuth') | float >=\
\ 180 and states('sensor.sun_azimuth') | float < 202 and is_state('sun.sun',\
\ 'above_horizon') %} \n automation.rolety_180\t\n{% elif states('sensor.sun_azimuth')\
\ | float >= 202 and states('sensor.sun_azimuth') | float < 225 and is_state('sun.sun',\
\ 'above_horizon') %} \n automation.rolety_2025\t\n{% elif states('sensor.sun_azimuth')\
\ | float >= 225 and states('sensor.sun_azimuth') | float < 247 and is_state('sun.sun',\
\ 'above_horizon') %} \n automation.rolety_225\t\n{% elif states('sensor.sun_azimuth')\
\ | float >= 247 and states('sensor.sun_azimuth') | float < 270 and is_state('sun.sun',\
\ 'above_horizon') %} \n automation.rolety_247\t\n{% elif states('sensor.sun_azimuth')\
\ | float >= 270 and states('sensor.sun_azimuth') | float < 292 and is_state('sun.sun',\
\ 'above_horizon') %} \n automation.rolety_270\t\n{% elif states('sensor.sun_azimuth')\
\ | float >= 292 and states('sensor.sun_azimuth') | float < 315 and is_state('sun.sun',\
\ 'above_horizon') %} \n automation.rolety_292\t\n{% elif states('sensor.sun_azimuth')\
\ | float >= 315 and states('sensor.sun_azimuth') | float < 350 and is_state('sun.sun',\
\ 'above_horizon') %} \n automation.rolety_315\t\n{% else %} \n automation.rolety_zamkniecie_zachod\n\
{% endif %} \n"
Well it is pretty much all of You hope It will be usefull and let me know that do You think about it.
