Has anyone successfully paired Siemens RDS110.R thermostat to Home Assistant. I’m moving to a new house (Europe) and looking for a smart floor thermostat options that could be paired to Home Assistant. You can also propose another good options. Thermostat can have it own cloud service but connection to Home Assistant is required.
I would be actually interested in the Siemens RDS Integration for home assistant… There is already something (not tested by me) for Openhab…
That sounds great. I will be moving in after six weeks and most likely get these Siemens RDS thermostats. They seem to be very powerful and together with home assistant even better. I will update the status here as soon I know more.
There is no Alexa integration, which is a bit disappointment…
Great to see others looking into the integration of the RDS110 thermostats. We are currently building a new house and plan to have 2 of these controlling the hydronic underfloor heating. I did notice the binding for OpenHAB, and hoped that there is a way to make it work in HA. Once the build is complete I will be able to spend more time working on a solution.
I have three of them and integration would be very welcome.
I have purchased an Siemens RDS110 and I am really excited. Lot of features, money saver, etc. Home assistant integration will be awesome.
Anyone could get this work based on the Openhab solution in HA?
I finally started installing these thermostats. Data can be easily accessed from Siemens Climatix IC cloud so let see how much work it would require to get the data to home assistant.
Hi, how easy is to get this supported by hass since it’s already supported by the openhab?
if anybody is interested to give this a shot i found the following:
climatix site where you login with your siemens rds credentials and you are able to view details/dashboards/statistics for your devices:
https://www.climatixic.com/#/Home
for example:
additionally there’s this site where you can request for an API: https://portal.api.climatixic.com/
but it needed a different login and i am not sure if it can fetch your details. i didn’t manage to get a token and use the api. anybody can assist?
Ah great to see others are keen on this - about to put one in here too.
i have setup an openhab and i intend to do mqtt sync between OH and HA just for this specific component that OH has already support. THe problem is that the “thing” of OH requires API key from climatics IC. THere’s no way to generate that. i sent them an email and i am waiting…
Strange…if I’m not mistaken there were some more detailed description on the openhab thing integration page on how to get the API key…but I can’t see it now.
This mqtt sync looks interesting. I don’t have my thermostat(s) yet installed.
Maybe if you succeed with this approach can you share some how-to on it?
… in OpenHAB I just opened a Pull Request to improve the binding documentation …
Hello to all,
Someone found a way to integrate Siemens RDS110 in Home Assistant?
In my new house I’ll have one and it would be great if it works in HA.
Hello there,
Is there any update since 2022 March on this topic? In the meanwhile the openHAB integration is no longer available in Home Assistant, thus the workaround described above seems to be obsolete…
Thanks.
Unfortunately no. Also Siemens has discontinued the product. Furthermore, I have already two that are broken…
Hello!
In the meanwhile, the openHAB - HomeAssistant integration no longer exists, so I’ve started to play around with the climatix info, shown in an above post.
I’ve made progress on this topic, what I can do now:
- Read out every state of the thermostat, which is present on the climatix server
- Use these values in integration
Limitations:
- Cannot set the required temperature (yet)
- The Bearer token, which is used experies in about 6-7 days, and currently cannot refresh it automatically
Steps:
You’ll need to obtain the API key and the Bearer token through Charles, which was previously described here: Siemens RDS110 support - #22 by andrewfg
Use an online API tester, such as https://reqbin.com to replay the REST command which you see in Charles in the following way:
From this, you’ll be able to get your plant ID, and also the state names for you requeired data (such as Room temperature, or Room Humidity, etc…). Replay the shortened REST command in the following way to test it:
Finally, in HomeAssistant in the configuration.yaml you can use these information to be displayed as entity in the following way:
rest:
- resource: https://api.climatixic.com/DataPoints/<your_Plant_id>;<thermosatData>
headers:
Authorization: !secret Siemens_RDS_auth_token
Ocp-Apim-Subscription-Key: !secret Siemens_RDS_api_key
scan_interval: 30
- name: "Living Room Temperature"
value_template: "{{ value_json['values']['<your_Plant_id>;<thermosatData>']['value']['value'] }}"
device_class: temperature
state_class: measurement
unique_id: <your_Plant_id>;<thermosatData>
Note, the Authorization token and the API key are stored in a seperate secret.yaml file. You dont need to do this, but since now I’m copy-pasting the token every week or so, this method was easier.
As you see, this is quite a work in progress, surely nicer method shall be worked out, where also the token can be obtained in an automatic way, but currently I don’t have the knowledge, need to reaserach it.
Hopefully this post will help you all!
Have a look here … the RdsHandler.java class shows how to command the target temperature, and the RdsHandler.java and RdsAccessToken.java classes show how to refresh the token.
Really helped thanks. Did you managed to do any further development apart from fetching data? I have seen the put commands and able to command the thermostat but haven’t done it through HA yet. do you have anything done not to start from scratch?
