Silver Crest ( Lidl) smart Button
I found a Solution:
First create a custom quirks direction like described here.:
Then create a file there with .py as file extension (name of file doesnt matter) and paste in this code:
"""Lidl TS004F Smart Button SSBM A1"""
from zigpy.profiles import zha
from zigpy.quirks import CustomDevice
from zigpy.zcl.clusters.general import (
    Basic,
    Groups,
    Identify,
    LevelControl,
    OnOff,
    Ota,
    PowerConfiguration,
    Scenes,
    Time,
from zigpy.zcl.clusters.lightlink import LightLink
from zhaquirks.const import (
    BUTTON,
    BUTTON_1,
    BUTTON_2,
    BUTTON_3,
    BUTTON_4,
    CLUSTER_ID,
    COMMAND,
    COMMAND_MOVE,
    COMMAND_MOVE_SATURATION,
    COMMAND_OFF,
    COMMAND_ON,
    COMMAND_STEP,
    COMMAND_STOP,
    COMMAND_STOP_MOVE_STEP,
    COMMAND_TOGGLE,
    DEVICE_TYPE,
    DIM_DOWN,
    DIM_UP,
    DOUBLE_PRESS,
    ENDPOINT_ID,
    ENDPOINTS,
    INPUT_CLUSTERS,
    LEFT,
    LONG_PRESS,
    LONG_RELEASE,
    MODEL,
    MODELS_INFO,
    OUTPUT_CLUSTERS,
    PARAMS,
    PROFILE_ID,
    RIGHT,
    SHORT_PRESS,
    TURN_OFF,
    TURN_ON,
from zhaquirks.tuya import TuyaZBOnOffAttributeCluster, TuyaZBExternalSwitchTypeCluster
class LidlSmartRemote004F(CustomDevice):
    """Lidl one button smart remote - model SSBM A1"""
    signature = {
        # "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
        # SizePrefixedSimpleDescriptor(endpoint=1, profile=260, device_type=2080, device_version=1, input_clusters=[0, 1, 3, 4, 4096, 57345], output_clusters=[3, 4, 5, 6, 8, 10, 25, 4096])
        MODEL: "TS004F",
        ENDPOINTS: {
            1: {
                PROFILE_ID: zha.PROFILE_ID,
                DEVICE_TYPE: zha.DeviceType.DIMMER_SWITCH,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    PowerConfiguration.cluster_id,
                    Identify.cluster_id,
                    Groups.cluster_id,
                    OnOff.cluster_id,
                    LightLink.cluster_id,
                    TuyaZBExternalSwitchTypeCluster.cluster_id,
                OUTPUT_CLUSTERS: [
                    Ota.cluster_id,
                    Time.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    OnOff.cluster_id,
                    LevelControl.cluster_id,
    replacement = {
        ENDPOINTS: {
            1: {
                DEVICE_TYPE: zha.DeviceType.NON_COLOR_CONTROLLER,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,  # Is needed for adding group then binding is not working.
                    TuyaZBExternalSwitchTypeCluster,
                OUTPUT_CLUSTERS: [
                    Ota.cluster_id,
                    Time.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
    device_automation_triggers = {
        (SHORT_PRESS, BUTTON): {COMMAND: COMMAND_ON, ENDPOINT_ID: 1},
        (DOUBLE_PRESS, BUTTON): {COMMAND: COMMAND_OFF, ENDPOINT_ID: 1},
        (LONG_PRESS, BUTTON): {COMMAND: COMMAND_STEP, ENDPOINT_ID: 1},
        (LONG_RELEASE, BUTTON): {COMMAND: COMMAND_STOP, ENDPOINT_ID: 1},
Save and restart. After that there should be new options for the button. See here:
