In the same style of the ZHA Philips Hue Dimmer blueprint that I shared here, and the TRADFRI On/off switch blueprint I shared here, I’ve made one for the LIVARNO/SilverCrest/Lidl Smart Button as well.
The actions are mapped to the zha events associated with the specific device, and the blueprint will only let you select this device in particular.
Please note that as the title says, this only works for ZHA.
In addition, usage of this blueprint requires the quirk made by @Drauboss to ignore the on/off state of the button. This quirk is available here
Without the quirk, the button will NOT respond to successive single press or double press actions.
This is what the blueprint looks like:
Get it using this link:
Manual install:
SilverCrest LIVARNO Button Config.yaml (github.com)
Please let me know if there’s anything that doesn’t work, though it should be pretty simple and it works fine from my experience using it over the last month.
