Hi, I want to ask, why when I want to add a device or edit a device, the sidebar takes so long to appear? is something wrong? thankyou
This usually indicates a timeout while contacting Home Assistant.
Please, take a look at the log
sorry, can you show me how can i see the log? thankyou
did you mean this log? i donât know what the errors mean. but when i click the button to add a device or edit a device, there is no change in the log.
Depends of which version of the addon you are using. In the 2.0 beta version you open the log with the 2nd button near the title. In the official 0.64/0.65 you find the log in the addon configuration
okay thankyou for the information.
Hello, again issue with mqtt: when restart system, the mqtt entities arenât availables. A further addon restart Is needed in order to have them
How much time do you wait? Usually can take 5-10 minutes for MQTT to reconnect.
Hi!
Trying to get this addon running but it does not start.
I tried rebuild, uninstall, reinstallâŚsame errors in the logs.
Any idea how to proceed?
Sorry, my bad.
Fixed in 2.0.47
I waited more than a day
Whatâs the MQTT status in the status bar?
Try to disable o enable one scheduling from frontend. Do the switches become available?
MQTT status was enabled, if i change status on frontend (if i remember right) I need ti restart addon⌠So After worksâŚ
Futhermore backend config seems doesnât working and disaligned fron frontend
You shouldnât have backend config anymore. Should be an empty pageâŚ
Thank you all beta tester!
I finally publish the beta to the main repository.
You can uninstall the beta addon and remove the beta repository
Then you can install again the official one.
There are already some fixes added in the official (2.0.49) that are not available in the beta repository!
Thanks again and hurry up!
New tentative, I have Just update HA
Entities not availables, mqtt running.
If I change state about a single schedule, all come back available via mqtt
As I predictedâŚ
Thatâs odd.
I ask you to do this test because when you change any scheduler, the addon sends again via MQTT, beside the state you changed, the configuration of all of the schedulers.
So basically it is a refresh.
What is odd is that the switches became unavailable, which is usually due to the ungraceful disconnection of the MQTT client (aka the addon) from the Mosquitto server.
The MQTT statusbar indicator is updated every time you reload the page, and I get the connection status directly from the python library (which, btw, I tested shutting on and off Mosquitto and I got the right status value)
I will try to reproduce the issue, otherwise I cannot fix it.
Meanwhile, have you switched to the latest version 2.0.49 ?
Yes I am on stabile version
Try the latest version 2.0.50
I removed options from the config file many releases ago. If you still see the backend options, there is definitively something wrong in your supervisorâŚ
This is what you should get:
now it is all good, many thanks again for your code & support
