hey, thanks for making this very useful scheduler.
sorry, I want to ask, I’ve managed to use this scheduler to my home assistant.
It is correct that at such an hour and such a day it can light up. However, sometimes it cannot turn off according to the off time that has been entered in the form when creating the scheduler for the smart breaker / smart switch.
Then, sometimes I don’t know why the smart breaker / smart switch that I use is sometimes unavailable when it’s close to off time / between the time it’s on until it’s off, I check the history logbook, it’s always sometimes unavailable
Apart from that, I checked the history logbook, sometimes the turn off / turn on appears not only once, even though the smart breaker / smart switch is on.
Maybe I make mistakes or are there settings that I haven’t done?
Probably this is the cause.
Please check the addon log: if the device is unavailable the addon will retry 3 times (by default, but you can change that) and after that, the addon gives up.
You can read all of this in the addon log.
If you are not sure or you have any doubts, you could post the log here, so I can help you to understand the issue.
The first attempt happens after 5 seconds, all the others are every minute.
Eg:
14:30:00 - Original schedule timer that fails
14:30:05 - 1st attempt
14:31:00 - 2nd attempt
14:32:00 - 3rd attempt
Sorry for the late response. I miss the notification.
That basically means that the addon is unable to communicate with HA.
Usually, you get that error when you restart or update HA.
Should be only temporary.
[2023-04-19 17:45:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 17:46:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 17:47:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 17:48:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 17:49:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 17:50:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 17:51:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 17:52:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 17:53:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 17:54:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 17:55:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 17:56:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 17:57:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 17:58:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 17:59:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 18:00:01] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 18:01:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 18:02:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 18:03:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 18:04:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 18:05:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 18:06:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 18:07:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 18:08:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 18:09:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 18:10:00] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 18:13:13] STATUS: Starting scheduler
[2023-04-19 18:13:13] STATUS: Starting main program
[2023-04-19 18:13:15] STATUS: Starting WebServer
[2023-04-19 18:13:35] ERROR: Unable to obtain entities info from Home Assistant
[2023-04-19 18:13:35] ERROR: Unable to obtain entities names from Home Assistant
[2023-04-19 18:13:40] ERROR: Unable to obtain entities info from Home Assistant
I’ve restarted a few time but the same errors keep appearing and the entities don’t update.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: Simple Scheduler
Simple timer on weekly base
Add-on version: 2.11
You are running the latest version of this add-on.
System: Home Assistant OS 10.0 (amd64 / qemux86-64)
Home Assistant Core: 2023.4.5
Home Assistant Supervisor: 2023.04.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[20:19:42] INFO: Starting service.d [Interface]
[20:19:42] INFO: Starting service.d [Scheduler]
[20:19:42] INFO: Running scheduler.sh
[20:19:42] INFO: Running interface.sh
It does, I did have to manually edit the json to add the entity, but it does seems to turn off and on. So it appears to be working just none of the entities are populating in the drop down.
Ok, I think we found the cause.
There is probably some entity name that blew the routine.
This is not affecting the schedules.
We need to find the entity name that causes the issue, so I can correct the bug.
To do it quickly just think if you have added/renamed some entities when the problem started.
Otherwise, we should find a way to export your entity names and send them to me.
Thanks - have not added/renamed anything in a while - I can’t confirm when it became a problem, the schedule has been running without issue, I only noticed it when I tried to add a new schedule.
I can look through the entities, what should I be looking for, something malformed? Strange characters?
Any non-alphanumeric character.
If you have some clues, just rename them one at a time trying to add a new scheduler each time.
When the list will finally populates, you find the cause.
