Anyone else see an issue with the time on their Sinope thermostats being 4 hours ahead since the latest HA update? Just updated to 2024.8.0 yesterday and everything works fine, but all my Sinope thermostats show the wrong time. When I reset them they show the correct time for a few minutes, but eventually they go back to being 4 hours ahead. My timezone settings are correctly set in HA.
Hi @claudegel! Okay, so I shut my breaker off for a min and turned it back on. I haven’t received any warnings today. I logged into Neviweb and it says I have software version 3.7.3 which is the most current version available for the device (confirmed by sinopetech agent).
Maybe it just needed to be turned on and off to establish a new wifi connection? Maybe it finally updated to this version? I dunno! Either way, it seems to have resolved itself…for now. Thanks again for your assistance! Cheers!
@gabeguz I noticed the same issue today, after the recent HA update! Resetting / repairing the thermostats does not fix the issue.
If your thermostat are on Neviweb then it is Neviweb that is sending the date and time at least once a day. So the bug is on Neviweb. Neviweb130 do not send date/time to the thermostat and do not import that data from Neviweb via the device update. On my system the time is reported correctly.
If your thermostat are on ZHA, then zha is sending the date/time about once per hour. You can also make an automation to send that data to your devices. You need to check that HA report the correct time with the correct timezone.
Unfortunately the bug is on HA/ZHA. All my thermostats on ZHA are 4 hour ahead. Will need to check what is the problem. Look like the timezone is wrong.
@claudegel So I was wrong. The notification has appeared again. I’ve tried to get all the relevant logs for you using the debug function in the integration. Here’s what it shows (I have redacted my email and postal code):
8/9/2024 1:37:44.8 DEBUG (SyncWorker_1) [custom_components.neviweb130.climate] Updated attributes for neviweb130 climate Heat: ['drSetpoint', 'drStatus', 'outputPercentDisplay', 'roomSetpoint', 'roomSetpointMax', 'roomSetpointMin', 'roomTemperatureDisplay', 'roomTemperature', 'temperatureFormat', 'timeFormat', 'cycleLength', 'loadWattOutput1', 'loadWatt', 'wifiRssi', 'keyboardLock', 'config2ndDisplay', 'setpointMode', 'occupancyMode', 'backlightAutoDim', 'earlyStartCfg', 'roomSetpointAway']
8/9/2024 1:37:45.5 DEBUG (SyncWorker_1) [custom_components.neviweb130.climate] Updating neviweb130 climate Heat (0.742 sec): {'drStatus': {'drActive': 'off', 'optOut': 'off', 'setpoint': 'off', 'powerAbsolute': 'off', 'powerRelative': 'off', 'onOff': 'off'}, 'outputPercentDisplay': {'percent': 0, 'sourceType': 'heating'}, 'roomSetpoint': 14, 'roomTemperatureDisplay': {'status': 'on', 'value': 21}, 'temperatureFormat': 'celsius', 'setpointMode': 'manual', 'drSetpoint': {'status': 'off', 'value': None}, 'roomSetpointMax': 30, 'roomSetpointMin': 5, 'roomTemperature': {'error': None, 'value': 20.99}, 'timeFormat': '12h', 'cycleLength': 15, 'loadWattOutput1': 1653, 'loadWatt': {'value': 1653}, 'wifiRssi': -48, 'keyboardLock': 'unlock', 'config2ndDisplay': 'exteriorTemperature', 'occupancyMode': 'home', 'backlightAutoDim': 'alwaysOn', 'earlyStartCfg': 'off', 'roomSetpointAway': 15}
8/9/2024 1:43:44.8 DEBUG (SyncWorker_45) [custom_components.neviweb130.climate] Updated attributes for neviweb130 climate Heat: ['drSetpoint', 'drStatus', 'outputPercentDisplay', 'roomSetpoint', 'roomSetpointMax', 'roomSetpointMin', 'roomTemperatureDisplay', 'roomTemperature', 'temperatureFormat', 'timeFormat', 'cycleLength', 'loadWattOutput1', 'loadWatt', 'wifiRssi', 'keyboardLock', 'config2ndDisplay', 'setpointMode', 'occupancyMode', 'backlightAutoDim', 'earlyStartCfg', 'roomSetpointAway']
8/9/2024 1:43:45.4 DEBUG (SyncWorker_45) [custom_components.neviweb130.climate] Updating neviweb130 climate Heat (0.646 sec): {'drStatus': {'drActive': 'off', 'optOut': 'off', 'setpoint': 'off', 'powerAbsolute': 'off', 'powerRelative': 'off', 'onOff': 'off'}, 'outputPercentDisplay': {'percent': 0, 'sourceType': 'heating'}, 'roomSetpoint': 14, 'roomTemperatureDisplay': {'status': 'on', 'value': 21}, 'temperatureFormat': 'celsius', 'setpointMode': 'manual', 'drSetpoint': {'status': 'off', 'value': None}, 'roomSetpointMax': 30, 'roomSetpointMin': 5, 'roomTemperature': {'error': None, 'value': 21.17}, 'timeFormat': '12h', 'cycleLength': 15, 'loadWattOutput1': 1653, 'loadWatt': {'value': 1653}, 'wifiRssi': -51, 'keyboardLock': 'unlock', 'config2ndDisplay': 'exteriorTemperature', 'occupancyMode': 'home', 'backlightAutoDim': 'alwaysOn', 'earlyStartCfg': 'off', 'roomSetpointAway': 15}
8/9/2024 1:49:44.8 DEBUG (SyncWorker_37) [custom_components.neviweb130.climate] Updated attributes for neviweb130 climate Heat: ['drSetpoint', 'drStatus', 'outputPercentDisplay', 'roomSetpoint', 'roomSetpointMax', 'roomSetpointMin', 'roomTemperatureDisplay', 'roomTemperature', 'temperatureFormat', 'timeFormat', 'cycleLength', 'loadWattOutput1', 'loadWatt', 'wifiRssi', 'keyboardLock', 'config2ndDisplay', 'setpointMode', 'occupancyMode', 'backlightAutoDim', 'earlyStartCfg', 'roomSetpointAway']
8/9/2024 1:49:45.7 DEBUG (SyncWorker_37) [custom_components.neviweb130.climate] Updating neviweb130 climate Heat (0.88 sec): {'drStatus': {'drActive': 'off', 'optOut': 'off', 'setpoint': 'off', 'powerAbsolute': 'off', 'powerRelative': 'off', 'onOff': 'off'}, 'outputPercentDisplay': {'percent': 0, 'sourceType': 'heating'}, 'roomSetpoint': 14, 'roomTemperatureDisplay': {'status': 'on', 'value': 21}, 'temperatureFormat': 'celsius', 'setpointMode': 'manual', 'drSetpoint': {'status': 'off', 'value': None}, 'roomSetpointMax': 30, 'roomSetpointMin': 5, 'roomTemperature': {'error': None, 'value': 20.89}, 'timeFormat': '12h', 'cycleLength': 15, 'loadWattOutput1': 1653, 'loadWatt': {'value': 1653}, 'wifiRssi': -48, 'keyboardLock': 'unlock', 'config2ndDisplay': 'exteriorTemperature', 'occupancyMode': 'home', 'backlightAutoDim': 'alwaysOn', 'earlyStartCfg': 'off', 'roomSetpointAway': 15}
8/9/2024 1:55:44.8 DEBUG (SyncWorker_61) [custom_components.neviweb130.climate] Updated attributes for neviweb130 climate Heat: ['drSetpoint', 'drStatus', 'outputPercentDisplay', 'roomSetpoint', 'roomSetpointMax', 'roomSetpointMin', 'roomTemperatureDisplay', 'roomTemperature', 'temperatureFormat', 'timeFormat', 'cycleLength', 'loadWattOutput1', 'loadWatt', 'wifiRssi', 'keyboardLock', 'config2ndDisplay', 'setpointMode', 'occupancyMode', 'backlightAutoDim', 'earlyStartCfg', 'roomSetpointAway']
8/9/2024 1:55:46.1 DEBUG (SyncWorker_61) [custom_components.neviweb130.climate] Updating neviweb130 climate Heat (1.305 sec): {'drStatus': {'drActive': 'off', 'optOut': 'off', 'setpoint': 'off', 'powerAbsolute': 'off', 'powerRelative': 'off', 'onOff': 'off'}, 'outputPercentDisplay': {'percent': 0, 'sourceType': 'heating'}, 'roomSetpoint': 14, 'roomTemperatureDisplay': {'status': 'on', 'value': 21}, 'temperatureFormat': 'celsius', 'setpointMode': 'manual', 'drSetpoint': {'status': 'off', 'value': None}, 'roomSetpointMax': 30, 'roomSetpointMin': 5, 'roomTemperature': {'error': None, 'value': 21.18}, 'timeFormat': '12h', 'cycleLength': 15, 'loadWattOutput1': 1653, 'loadWatt': {'value': 1653}, 'wifiRssi': -47, 'keyboardLock': 'unlock', 'config2ndDisplay': 'exteriorTemperature', 'occupancyMode': 'home', 'backlightAutoDim': 'alwaysOn', 'earlyStartCfg': 'off', 'roomSetpointAway': 15}
8/9/2024 2:01:44.8 DEBUG (SyncWorker_28) [custom_components.neviweb130.climate] Updated attributes for neviweb130 climate Heat: ['drSetpoint', 'drStatus', 'outputPercentDisplay', 'roomSetpoint', 'roomSetpointMax', 'roomSetpointMin', 'roomTemperatureDisplay', 'roomTemperature', 'temperatureFormat', 'timeFormat', 'cycleLength', 'loadWattOutput1', 'loadWatt', 'wifiRssi', 'keyboardLock', 'config2ndDisplay', 'setpointMode', 'occupancyMode', 'backlightAutoDim', 'earlyStartCfg', 'roomSetpointAway']
8/9/2024 2:01:44.9 DEBUG (SyncWorker_28) [custom_components.neviweb130.climate] Updating neviweb130 climate Heat (0.09 sec): {'error': {'code': 'DVCUNVLB', 'data': {'identifier': '246f28fffe89948c'}}}
8/9/2024 2:01:44.9 WARNING (SyncWorker_28)[custom_components.neviweb130.climate] Device neviweb130 climate Heat is disconected from Neviweb: DVCUNVLB...(SKU: TH1124WF)
8/9/2024 2:01:44.9 WARNING (SyncWorker_28)[custom_components.neviweb130.climate] This device neviweb130 climate Heat is de-activated and won't be updated for 20 minutes.
8/9/2024 2:01:44.9 WARNING (SyncWorker_28)[custom_components.neviweb130.climate] You can re-activate device neviweb130 climate Heat with service.neviweb130_set_activation or wait 20 minutes for update to restart or just restart HA.
8/9/2024 2:31:44.8 DEBUG (SyncWorker_17) [custom_components.neviweb130.climate] Updated attributes for neviweb130 climate Heat: ['drSetpoint', 'drStatus', 'outputPercentDisplay', 'roomSetpoint', 'roomSetpointMax', 'roomSetpointMin', 'roomTemperatureDisplay', 'roomTemperature', 'temperatureFormat', 'timeFormat', 'cycleLength', 'loadWattOutput1', 'loadWatt', 'wifiRssi', 'keyboardLock', 'config2ndDisplay', 'setpointMode', 'occupancyMode', 'backlightAutoDim', 'earlyStartCfg', 'roomSetpointAway']
8/9/2024 2:31:44.9 ERROR (SyncWorker_17) [custom_components.neviweb130] Session expired. Set a scan_interval lessthan 10 minutes, otherwise the session will end.
8/9/2024 2:31:44.9 DEBUG (SyncWorker_17) [custom_components.neviweb130.climate] Updating neviweb130 climate Heat (0.12 sec): {'error': {'code': 'USRSESSEXP'}}
8/9/2024 2:31:44.9 WARNING (SyncWorker_17)[custom_components.neviweb130.climate] Session expired... reconnecting...
8/9/2024 2:31:45.0 DEBUG (SyncWorker_17) [custom_components.neviweb130] Login response: {'user': {'id': 30033, 'role': 'owner', 'email': '[email protected]', 'locale': 'en', 'format': {'time': '12', 'temperature': 'c', 'distance': 'km'}, 'initialized': 1, 'dataPolicyConsent': 1}, 'account': {'id': 30249, 'interface': 'neviweb', 'type': 'free', 'category': None, 'betaLevel': None}, 'iat': 1723184999014, 'permissionContext': 'userNeviwebOwner1', 'session': 'f6fc1922ead4aad71618deb11de63afcc957f36d7e288a72', 'refreshToken': '8b0bf7279015ec4baf6304dbdeabd26b6b148f10efe6e9ab1416ec0a92b14e6536e1dd051473fafab97f004b4b29cc1b'}
8/9/2024 2:31:45.0 DEBUG (SyncWorker_17) [custom_components.neviweb130] Successfully logged in to: 30249
8/9/2024 2:31:45.1 DEBUG (SyncWorker_17) [custom_components.neviweb130] Number of networks found on Neviweb: 1
8/9/2024 2:31:45.1 DEBUG (SyncWorker_17) [custom_components.neviweb130] networks: [{'id': 36807, 'account$id': 30249, 'location$id': None, 'group$id': None, 'name': 'Home', 'postalCode': 'A1B2C3', 'address': None, 'mode': 'home', 'icon': 2, 'type': None, 'kwhCost': 0.0885, 'deviceListUpdate': '2024-01-05 13:42:45', 'modified': '2024-01-05 13:04:15', 'created': '2021-08-28 22:41:56'}]
8/9/2024 2:31:45.1 DEBUG (SyncWorker_17) [custom_components.neviweb130] Selecting Home network among: [{'id': 36807, 'account$id': 30249, 'location$id': None, 'group$id': None, 'name': 'Home', 'postalCode': 'A1B2C3', 'address': None, 'mode': 'home', 'icon': 2, 'type': None, 'kwhCost': 0.0885, 'deviceListUpdate': '2024-01-05 13:42:45', 'modified': '2024-01-05 13:04:15', 'created': '2021-08-28 22:41:56'}]
8/9/2024 2:31:45.1 DEBUG (SyncWorker_17) [custom_components.neviweb130] Received gateway data: [{'id': 377504, 'identifier': '246f28fffe89948c', 'name': 'Heat', 'family': '1124-WF', 'signature': {'model': 1510, 'modelCfg': 1, 'softBuildCfg': 0, 'softVersion': {'major': 3, 'middle': 7, 'minor': 3}, 'hardRev': 0}, 'location$id': 36807, 'parentDevice$id': None, 'group$id': 239287, 'orderIdx': 0, 'sku': 'TH1124WF', 'vendor': 'Sinopé', 'url_en': None, 'url_fr': None}]
8/9/2024 2:31:45.1 DEBUG (SyncWorker_17) [custom_components.neviweb130] Gateway_data : [{'id': 377504, 'identifier': '246f28fffe89948c', 'name': 'Heat', 'family': '1124-WF', 'signature': {'model': 1510, 'modelCfg': 1, 'softBuildCfg': 0, 'softVersion': {'major': 3, 'middle': 7, 'minor': 3}, 'hardRev': 0}, 'location$id': 36807, 'parentDevice$id': None, 'group$id': 239287, 'orderIdx': 0, 'sku': 'TH1124WF', 'vendor': 'Sinopé', 'url_en': None, 'url_fr': None}]
8/9/2024 2:31:45.2 DEBUG (SyncWorker_17) [custom_components.neviweb130] Received signature data: {'signature': {'model': 1510, 'modelCfg': 1, 'softBuildCfg': 0, 'softVersion': {'major': 3, 'middle': 7, 'minor': 3}, 'hardRev': 0, 'protocol': 'sinopcom'}}
8/9/2024 2:37:44.8 DEBUG (SyncWorker_61) [custom_components.neviweb130.climate] Updated attributes for neviweb130 climate Heat: ['drSetpoint', 'drStatus', 'outputPercentDisplay', 'roomSetpoint', 'roomSetpointMax', 'roomSetpointMin', 'roomTemperatureDisplay', 'roomTemperature', 'temperatureFormat', 'timeFormat', 'cycleLength', 'loadWattOutput1', 'loadWatt', 'wifiRssi', 'keyboardLock', 'config2ndDisplay', 'setpointMode', 'occupancyMode', 'backlightAutoDim', 'earlyStartCfg', 'roomSetpointAway']
8/9/2024 2:37:46.2 DEBUG (SyncWorker_61) [custom_components.neviweb130.climate] Updating neviweb130 climate Heat (1.452 sec): {'drStatus': {'drActive': 'off', 'optOut': 'off', 'setpoint': 'off', 'powerAbsolute': 'off', 'powerRelative': 'off', 'onOff': 'off'}, 'outputPercentDisplay': {'percent': 0, 'sourceType': 'heating'}, 'roomSetpoint': 14, 'roomTemperatureDisplay': {'status': 'on', 'value': 21}, 'temperatureFormat': 'celsius', 'setpointMode': 'manual', 'drSetpoint': {'status': 'off', 'value': None}, 'roomSetpointMax': 30, 'roomSetpointMin': 5, 'roomTemperature': {'error': None, 'value': 20.79}, 'timeFormat': '12h', 'cycleLength': 15, 'loadWattOutput1': 1653, 'loadWatt': {'value': 1653}, 'wifiRssi': -46, 'keyboardLock': 'unlock', 'config2ndDisplay': 'exteriorTemperature', 'occupancyMode': 'home', 'backlightAutoDim': 'alwaysOn', 'earlyStartCfg': 'off', 'roomSetpointAway': 15}
8/9/2024 2:43:44.8 DEBUG (SyncWorker_47) [custom_components.neviweb130.climate] Updated attributes for neviweb130 climate Heat: ['drSetpoint', 'drStatus', 'outputPercentDisplay', 'roomSetpoint', 'roomSetpointMax', 'roomSetpointMin', 'roomTemperatureDisplay', 'roomTemperature', 'temperatureFormat', 'timeFormat', 'cycleLength', 'loadWattOutput1', 'loadWatt', 'wifiRssi', 'keyboardLock', 'config2ndDisplay', 'setpointMode', 'occupancyMode', 'backlightAutoDim', 'earlyStartCfg', 'roomSetpointAway']
8/9/2024 2:43:45.6 DEBUG (SyncWorker_47) [custom_components.neviweb130.climate] Updating neviweb130 climate Heat (0.834 sec): {'drStatus': {'drActive': 'off', 'optOut': 'off', 'setpoint': 'off', 'powerAbsolute': 'off', 'powerRelative': 'off', 'onOff': 'off'}, 'outputPercentDisplay': {'percent': 0, 'sourceType': 'heating'}, 'roomSetpoint': 14, 'roomTemperatureDisplay': {'status': 'on', 'value': 21}, 'temperatureFormat': 'celsius', 'setpointMode': 'manual', 'drSetpoint': {'status': 'off', 'value': None}, 'roomSetpointMax': 30, 'roomSetpointMin': 5, 'roomTemperature': {'error': None, 'value': 21.07}, 'timeFormat': '12h', 'cycleLength': 15, 'loadWattOutput1': 1653, 'loadWatt': {'value': 1653}, 'wifiRssi': -47, 'keyboardLock': 'unlock', 'config2ndDisplay': 'exteriorTemperature', 'occupancyMode': 'home', 'backlightAutoDim': 'alwaysOn', 'earlyStartCfg': 'off', 'roomSetpointAway': 15}
8/9/2024 2:49:44.8 DEBUG (SyncWorker_0) [custom_components.neviweb130.climate] Updated attributes for neviweb130 climate Heat: ['drSetpoint', 'drStatus', 'outputPercentDisplay', 'roomSetpoint', 'roomSetpointMax', 'roomSetpointMin', 'roomTemperatureDisplay', 'roomTemperature', 'temperatureFormat', 'timeFormat', 'cycleLength', 'loadWattOutput1', 'loadWatt', 'wifiRssi', 'keyboardLock', 'config2ndDisplay', 'setpointMode', 'occupancyMode', 'backlightAutoDim', 'earlyStartCfg', 'roomSetpointAway']
8/9/2024 2:49:45.8 DEBUG (SyncWorker_0) [custom_components.neviweb130.climate] Updating neviweb130 climate Heat (0.957 sec): {'drStatus': {'drActive': 'off', 'optOut': 'off', 'setpoint': 'off', 'powerAbsolute': 'off', 'powerRelative': 'off', 'onOff': 'off'}, 'outputPercentDisplay': {'percent': 0, 'sourceType': 'heating'}, 'roomSetpoint': 14, 'roomTemperatureDisplay': {'status': 'on', 'value': 21}, 'temperatureFormat': 'celsius', 'setpointMode': 'manual', 'drSetpoint': {'status': 'off', 'value': None}, 'roomSetpointMax': 30, 'roomSetpointMin': 5, 'roomTemperature': {'error': None, 'value': 20.83}, 'timeFormat': '12h', 'cycleLength': 15, 'loadWattOutput1': 1653, 'loadWatt': {'value': 1653}, 'wifiRssi': -48, 'keyboardLock': 'unlock', 'config2ndDisplay': 'exteriorTemperature', 'occupancyMode': 'home', 'backlightAutoDim': 'alwaysOn', 'earlyStartCfg': 'off', 'roomSetpointAway': 15}
See my workaround here, until the ZHA bug is fixed: Zigbee Thermostats Incorrect Time Zone - #11 by mshamash
In your log I see USRSESSEXP. This is when your scan intervall is too long. Neviweb will close the session and HA will have to reconnect, which is done automatically. But it is possible that during this period some update are failing.
How do I shorten the scan interval? Is this something in HAss? I checked Neviweb and there’s nothing there that says “scan interval”.
I noticed this line with code DVCUNVLB in it:
Does this mean anything?
It’s in your neviweb130 parameter in configuration.yaml
neviweb130:
username: !secret climate_username
password: !secret climate_password
network: !secret climate_gateway130
scan_interval: 360
stat_interval: 600
Scan_interval is the number of seconds between each access to Neviweb to update device state. Sinopé asked for a minimum of 5 minutes between polling, so you can reduce scan_interval to 300. Don’t go over 600, the session will expire.
As for DVCUNVLB error message this is what give you the notification message about device disconnected. When HA receive that error message from Neviweb it stop polling for 20 minutes then restart automatically to see if connection is back.
Today I got a 2 seconds power lost that freeze the Videotron rooter. That affect the GT130 and Communication was lost with Neviweb so I got plenty of notifications. 20 minutes later everything came back normal. This way I can know the comm lost and check if some automations didn’t succeed.
I see in the documentation file, it shows scan being 360 and stat being 1800. I only copied those settings originally.
So I can change them both to be 300 and 600 as you just outlined?
yes this is what I have
Done. Thank you! Let’s hope this stops the notifications.
Hi @claudegel! Just following up, and I am not receiving any more notifications (after I downgraded the interaction and then re-upgraded it to the newest release, after I tried changing those settings you mentioned and it not making a difference. But so far so good!
I checked my log and see I am still received a debug warning (no notification about it, just something I can see in the log.
For ‘roomTemperature’, is it supposed to say <‘error’: None>? It’s the only thing I can see might be causing the debug warning.
Here’s the log:
2024-08-13 21:13:52.335 DEBUG (SyncWorker_3) [custom_components.neviweb130.climate] Updated attributes for neviweb130 climate heat: ['drSetpoint', 'drStatus', 'outputPercentDisplay', 'roomSetpoint', 'roomSetpointMax', 'roomSetpointMin', 'roomTemperatureDisplay', 'roomTemperature', 'temperatureFormat', 'timeFormat', 'cycleLength', 'loadWattOutput1', 'loadWatt', 'wifiRssi', 'keyboardLock', 'config2ndDisplay', 'setpointMode', 'occupancyMode', 'backlightAutoDim', 'earlyStartCfg', 'roomSetpointAway']
2024-08-13 21:13:53.077 DEBUG (SyncWorker_3) [custom_components.neviweb130.climate] Updating neviweb130 climate heat (0.743 sec): {'drStatus': {'drActive': 'off', 'optOut': 'off', 'setpoint': 'off', 'powerAbsolute': 'off', 'powerRelative': 'off', 'onOff': 'off'}, 'outputPercentDisplay': {'percent': 0, 'sourceType': 'heating'}, 'roomSetpoint': 14, 'roomTemperatureDisplay': {'status': 'on', 'value': 21.5}, 'temperatureFormat': 'celsius', 'setpointMode': 'manual', 'drSetpoint': {'status': 'off', 'value': None}, 'roomSetpointMax': 30, 'roomSetpointMin': 5, 'roomTemperature': {'error': None, 'value': 21.48}, 'timeFormat': '12h', 'cycleLength': 15, 'loadWattOutput1': 1653, 'loadWatt': {'value': 1653}, 'wifiRssi': -24, 'keyboardLock': 'unlock', 'config2ndDisplay': 'exteriorTemperature', 'occupancyMode': 'home', 'backlightAutoDim': 'alwaysOn', 'earlyStartCfg': 'off', 'roomSetpointAway': 15}
The error: None for roomTemperature is in case the thermostats encounter error with the temperature sensor or bad reading. In that case there will be an error number displayed error: xx.
So error: None is ok and everything is fine.
Thanks!!
Neviweb is not loading anymore and getting me this error after I did the latest home assistant core upgrade last night. How do I fix this?
I just got some more details… Hopefully this is helpful.
My GT125 integration is still working fine. It is just my Neviweb that has went south.
Logger: homeassistant.setup
Source: setup.py:416
First occurred: 10:17:59 AM (1 occurrences)
Last logged: 10:17:59 AM
Error during setup of component neviweb
File "/usr/src/homeassistant/homeassistant/setup.py", line 416, in _async_setup_component
result = await task
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/config/custom_components/neviweb/__init__.py", line 78, in setup
data = NeviwebData(hass_config[DOMAIN])
File "/config/custom_components/neviweb/__init__.py", line 102, in __init__
self.neviweb_client = NeviwebClient(username, password, network, network2)
File "/config/custom_components/neviweb/__init__.py", line 133, in __init__
self.__post_login_page()
File "/config/custom_components/neviweb/__init__.py", line 156, in __post_login_page
raise PyNeviwebError("Cannot log in")
custom_components.neviweb.PyNeviwebError: Cannot log in
Ya, they have a fix ready to be pushed but you can manually edit your init.py file yourself and reboot HAss and it will work. Change line 215 (see attached). It worked for me!
Found it… that worked.
