For sure! Let me know if this wasn’t what you were looking for, but it does seem to match what you have in your code:
2022-11-01 03:18:16.740 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.SimpleDescRsp.Callback(Src=0xE60D, Status=<Status.SUCCESS: 0>, NWK=0xE60D, SimpleDescriptor=SizePrefixedSimpleDescriptor(endpoint=1, profile=260, device_type=769, device_version=1, input_clusters=[0, 3, 4, 5, 513, 516, 1026, 1794, 2820, 2821, 65281], output_clusters=[3, 10, 25]))
And some more excerpts:
022-11-01 03:18:16.901 INFO (MainThread) [zigpy.device] [0xe60d] Discovered basic device information for <Device model='TH1123ZB-G2' manuf='Sinope Technologies' nwk=0xE60D ieee=00:3c:84:ff:fe:96:6b:c0 is_initialized=True>
2022-11-01 03:18:16.902 DEBUG (MainThread) [zigpy.application] Device is initialized <Device model='TH1123ZB-G2' manuf='Sinope Technologies' nwk=0xE60D ieee=00:3c:84:ff:fe:96:6b:c0 is_initialized=True>
2022-11-01 03:18:16.906 DEBUG (MainThread) [zigpy.quirks.registry] Checking quirks for Sinope Technologies TH1123ZB-G2 (00:3c:84:ff:fe:96:6b:c0)
2022-11-01 03:18:16.907 DEBUG (MainThread) [zigpy.quirks.registry] Considering <class 'thermostat.SinopeG2Thermostats'>
2022-11-01 03:18:16.908 DEBUG (MainThread) [zigpy.quirks.registry] Found custom device replacement for 00:3c:84:ff:fe:96:6b:c0: <class 'thermostat.SinopeG2Thermostats'>
2022-11-01 03:18:16.925 DEBUG (MainThread) [homeassistant.components.zha.core.discovery] 'button' component -> 'ZHAIdentifyButton' using ['identify']
2022-11-01 03:18:16.925 DEBUG (MainThread) [homeassistant.components.zha.core.discovery] 'climate' component -> 'SinopeTechnologiesThermostat' using ['thermostat', 'sinope_manufacturer_specific']
2022-11-01 03:18:16.926 DEBUG (MainThread) [homeassistant.components.zha.core.discovery] 'sensor' component -> 'ElectricalMeasurement' using ['electrical_measurement']
2022-11-01 03:18:16.926 DEBUG (MainThread) [homeassistant.components.zha.core.discovery] 'sensor' component -> 'ElectricalMeasurementApparentPower' using ['electrical_measurement']
2022-11-01 03:18:16.927 DEBUG (MainThread) [homeassistant.components.zha.core.discovery] 'sensor' component -> 'ElectricalMeasurementRMSCurrent' using ['electrical_measurement']
2022-11-01 03:18:16.928 DEBUG (MainThread) [homeassistant.components.zha.core.discovery] 'sensor' component -> 'ElectricalMeasurementRMSVoltage' using ['electrical_measurement']
2022-11-01 03:18:16.928 DEBUG (MainThread) [homeassistant.components.zha.core.discovery] 'sensor' component -> 'ElectricalMeasurementFrequency' using ['electrical_measurement']
2022-11-01 03:18:16.929 DEBUG (MainThread) [homeassistant.components.zha.core.discovery] 'sensor' component -> 'ElectricalMeasurementPowerFactor' using ['electrical_measurement']
2022-11-01 03:18:16.929 DEBUG (MainThread) [homeassistant.components.zha.core.discovery] 'sensor' component -> 'Temperature' using ['temperature']
2022-11-01 03:18:16.930 DEBUG (MainThread) [homeassistant.components.zha.core.discovery] 'sensor' component -> 'RSSISensor' using ['basic']
2022-11-01 03:18:16.930 DEBUG (MainThread) [homeassistant.components.zha.core.discovery] 'sensor' component -> 'LQISensor' using ['basic']
2022-11-01 03:18:16.931 DEBUG (MainThread) [homeassistant.components.zha.core.discovery] 'sensor' component -> 'SmartEnergyMetering' using ['smartenergy_metering']
2022-11-01 03:18:16.931 DEBUG (MainThread) [homeassistant.components.zha.core.discovery] 'sensor' component -> 'SmartEnergySummation' using ['smartenergy_metering']
2022-11-01 03:18:16.932 DEBUG (MainThread) [homeassistant.components.zha.core.discovery] 'sensor' component -> 'SinopeHVACAction' using ['thermostat']
2022-11-01 03:18:16.939 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] device - 0xE60D:00:3c:84:ff:fe:96:6b:c0 entering async_device_initialized - is_new_join: True
2022-11-01 03:18:16.940 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] device - 0xE60D:00:3c:84:ff:fe:96:6b:c0 has joined the ZHA zigbee network
2022-11-01 03:18:16.942 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0xE60D](TH1123ZB-G2): started configuration
2022-11-01 03:18:16.943 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:ZDO](TH1123ZB-G2): 'async_configure' stage succeeded
2022-11-01 03:18:16.959 DEBUG (MainThread) [zigpy.appdb] Error handling '_save_attribute' event with (00:3c:84:ff:fe:96:6b:c0, 1, 0, 4, 'Sinope Technologies') params: FOREIGN KEY constraint failed
2022-11-01 03:18:16.960 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0402]: Performing cluster binding
2022-11-01 03:18:16.962 DEBUG (MainThread) [zigpy_znp.zigbee.application] Sending packet ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), dst_ep=0, source_route=None, extended_timeout=False, tsn=38, profile_id=0, cluster_id=<ZDOCmd.Bind_req: 0x0021>, data=Serialized[b'&\xc0k\x96\xfe\xff\x84<\x00\x01\x02\x04\x03\xafe\xd1&\x00K\x12\x00\x01'], tx_options=<TransmitOptions.ACK: 1>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2022-11-01 03:18:16.964 DEBUG (MainThread) [zigpy_znp.api] Sending request: ZDO.ExtRouteChk.Req(Dst=0xE60D, RtStatus=<RouteStatus.ACTIVE: 1>, Options=<RouteOptions.NO_ROUTE_CACHE|MTO_ROUTE: 3>)
2022-11-01 03:18:16.966 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0702]: Performing cluster binding
2022-11-01 03:18:16.968 DEBUG (MainThread) [zigpy_znp.zigbee.application] Sending packet ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), dst_ep=0, source_route=None, extended_timeout=False, tsn=39, profile_id=0, cluster_id=<ZDOCmd.Bind_req: 0x0021>, data=Serialized[b"'\xc0k\x96\xfe\xff\x84<\x00\x01\x02\x07\x03\xafe\xd1&\x00K\x12\x00\x01"], tx_options=<TransmitOptions.ACK: 1>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2022-11-01 03:18:16.970 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0003]: Configuring cluster attribute reporting
2022-11-01 03:18:16.970 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0003]: finished channel configuration
2022-11-01 03:18:16.971 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0201]: Performing cluster binding
2022-11-01 03:18:16.973 DEBUG (MainThread) [zigpy_znp.zigbee.application] Sending packet ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), dst_ep=0, source_route=None, extended_timeout=False, tsn=40, profile_id=0, cluster_id=<ZDOCmd.Bind_req: 0x0021>, data=Serialized[b'(\xc0k\x96\xfe\xff\x84<\x00\x01\x01\x02\x03\xafe\xd1&\x00K\x12\x00\x01'], tx_options=<TransmitOptions.ACK: 1>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2022-11-01 03:18:16.975 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0b04]: Performing cluster binding
2022-11-01 03:18:16.977 DEBUG (MainThread) [zigpy_znp.zigbee.application] Sending packet ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), dst_ep=0, source_route=None, extended_timeout=False, tsn=41, profile_id=0, cluster_id=<ZDOCmd.Bind_req: 0x0021>, data=Serialized[b')\xc0k\x96\xfe\xff\x84<\x00\x01\x04\x0b\x03\xafe\xd1&\x00K\x12\x00\x01'], tx_options=<TransmitOptions.ACK: 1>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2022-11-01 03:18:16.978 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0xff01]: Performing cluster binding
2022-11-01 03:18:16.981 DEBUG (MainThread) [zigpy_znp.zigbee.application] Sending packet ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), dst_ep=0, source_route=None, extended_timeout=False, tsn=42, profile_id=0, cluster_id=<ZDOCmd.Bind_req: 0x0021>, data=Serialized[b'*\xc0k\x96\xfe\xff\x84<\x00\x01\x01\xff\x03\xafe\xd1&\x00K\x12\x00\x01'], tx_options=<TransmitOptions.ACK: 1>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2022-11-01 03:18:16.982 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0000]: Configuring cluster attribute reporting
2022-11-01 03:18:16.983 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0000]: finished channel configuration
2022-11-01 03:18:16.984 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0019]: finished channel configuration
2022-11-01 03:18:16.990 DEBUG (MainThread) [zigpy.appdb] Error handling '_save_attribute' event with (00:3c:84:ff:fe:96:6b:c0, 1, 0, 5, 'TH1123ZB-G2') params: FOREIGN KEY constraint failed
2022-11-01 03:18:16.996 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.ExtRouteChk.Rsp(Status=<RoutingStatus.SUCCESS: 0>)
2022-11-01 03:18:16.998 DEBUG (MainThread) [zigpy_znp.api] Sending request: ZDO.ExtRouteChk.Req(Dst=0xE60D, RtStatus=<RouteStatus.ACTIVE: 1>, Options=<RouteOptions.NO_ROUTE_CACHE|MTO_ROUTE: 3>)
2022-11-01 03:18:17.002 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.ExtRouteChk.Rsp(Status=<RoutingStatus.SUCCESS: 0>)
2022-11-01 03:18:17.003 DEBUG (MainThread) [zigpy_znp.api] Sending request: ZDO.ExtRouteChk.Req(Dst=0xE60D, RtStatus=<RouteStatus.ACTIVE: 1>, Options=<RouteOptions.NO_ROUTE_CACHE|MTO_ROUTE: 3>)
2022-11-01 03:18:17.008 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.ExtRouteChk.Rsp(Status=<RoutingStatus.SUCCESS: 0>)
2022-11-01 03:18:17.009 DEBUG (MainThread) [zigpy_znp.api] Sending request: ZDO.ExtRouteChk.Req(Dst=0xE60D, RtStatus=<RouteStatus.ACTIVE: 1>, Options=<RouteOptions.NO_ROUTE_CACHE|MTO_ROUTE: 3>)
2022-11-01 03:18:17.014 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.ExtRouteChk.Rsp(Status=<RoutingStatus.SUCCESS: 0>)
2022-11-01 03:18:17.015 DEBUG (MainThread) [zigpy_znp.api] Sending request: ZDO.ExtRouteChk.Req(Dst=0xE60D, RtStatus=<RouteStatus.ACTIVE: 1>, Options=<RouteOptions.NO_ROUTE_CACHE|MTO_ROUTE: 3>)
2022-11-01 03:18:17.019 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.ExtRouteChk.Rsp(Status=<RoutingStatus.SUCCESS: 0>)
2022-11-01 03:18:17.021 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestExt.Req(DstAddrModeAddress=AddrModeAddress(mode=<AddrMode.NWK: 2>, address=0xE60D), DstEndpoint=0, DstPanId=0x0000, SrcEndpoint=0, ClusterId=33, TSN=38, Options=<TransmitOptions.SUPPRESS_ROUTE_DISC_NETWORK|ACK_REQUEST: 48>, Radius=0, Data=b'\x26\xC0\x6B\x96\xFE\xFF\x84\x3C\x00\x01\x02\x04\x03\xAF\x65\xD1\x26\x00\x4B\x12\x00\x01')
2022-11-01 03:18:17.029 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataRequestExt.Rsp(Status=<Status.SUCCESS: 0>)
2022-11-01 03:18:17.030 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestExt.Req(DstAddrModeAddress=AddrModeAddress(mode=<AddrMode.NWK: 2>, address=0xE60D), DstEndpoint=0, DstPanId=0x0000, SrcEndpoint=0, ClusterId=33, TSN=39, Options=<TransmitOptions.SUPPRESS_ROUTE_DISC_NETWORK|ACK_REQUEST: 48>, Radius=0, Data=b'\x27\xC0\x6B\x96\xFE\xFF\x84\x3C\x00\x01\x02\x07\x03\xAF\x65\xD1\x26\x00\x4B\x12\x00\x01')
2022-11-01 03:18:17.044 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataRequestExt.Rsp(Status=<Status.SUCCESS: 0>)
2022-11-01 03:18:17.046 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestExt.Req(DstAddrModeAddress=AddrModeAddress(mode=<AddrMode.NWK: 2>, address=0xE60D), DstEndpoint=0, DstPanId=0x0000, SrcEndpoint=0, ClusterId=33, TSN=40, Options=<TransmitOptions.SUPPRESS_ROUTE_DISC_NETWORK|ACK_REQUEST: 48>, Radius=0, Data=b'\x28\xC0\x6B\x96\xFE\xFF\x84\x3C\x00\x01\x01\x02\x03\xAF\x65\xD1\x26\x00\x4B\x12\x00\x01')
2022-11-01 03:18:17.072 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataRequestExt.Rsp(Status=<Status.SUCCESS: 0>)
2022-11-01 03:18:17.073 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestExt.Req(DstAddrModeAddress=AddrModeAddress(mode=<AddrMode.NWK: 2>, address=0xE60D), DstEndpoint=0, DstPanId=0x0000, SrcEndpoint=0, ClusterId=33, TSN=41, Options=<TransmitOptions.SUPPRESS_ROUTE_DISC_NETWORK|ACK_REQUEST: 48>, Radius=0, Data=b'\x29\xC0\x6B\x96\xFE\xFF\x84\x3C\x00\x01\x04\x0B\x03\xAF\x65\xD1\x26\x00\x4B\x12\x00\x01')
2022-11-01 03:18:17.075 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.SrcRtgInd.Callback(DstAddr=0xE60D, Relays=[])
2022-11-01 03:18:17.081 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.SrcRtgInd.Callback(DstAddr=0xE60D, Relays=[])
2022-11-01 03:18:17.213 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataRequestExt.Rsp(Status=<Status.SUCCESS: 0>)
2022-11-01 03:18:17.214 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestExt.Req(DstAddrModeAddress=AddrModeAddress(mode=<AddrMode.NWK: 2>, address=0xE60D), DstEndpoint=0, DstPanId=0x0000, SrcEndpoint=0, ClusterId=33, TSN=42, Options=<TransmitOptions.SUPPRESS_ROUTE_DISC_NETWORK|ACK_REQUEST: 48>, Radius=0, Data=b'\x2A\xC0\x6B\x96\xFE\xFF\x84\x3C\x00\x01\x01\xFF\x03\xAF\x65\xD1\x26\x00\x4B\x12\x00\x01')
2022-11-01 03:18:17.217 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.SrcRtgInd.Callback(DstAddr=0xE60D, Relays=[])
2022-11-01 03:18:17.219 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.SrcRtgInd.Callback(DstAddr=0xE60D, Relays=[])
2022-11-01 03:18:17.220 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.SrcRtgInd.Callback(DstAddr=0xE60D, Relays=[])
2022-11-01 03:18:17.222 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.BindRsp.Callback(Src=0xE60D, Status=<Status.SUCCESS: 0>)
2022-11-01 03:18:17.223 DEBUG (MainThread) [zigpy_znp.api] Command was not handled
2022-11-01 03:18:17.224 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.BindRsp.Callback(Src=0xE60D, Status=<Status.SUCCESS: 0>)
2022-11-01 03:18:17.224 DEBUG (MainThread) [zigpy_znp.api] Command was not handled
2022-11-01 03:18:17.227 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.BindRsp.Callback(Src=0xE60D, Status=<Status.SUCCESS: 0>)
2022-11-01 03:18:17.228 DEBUG (MainThread) [zigpy_znp.api] Command was not handled
2022-11-01 03:18:17.234 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.BindRsp.Callback(Src=0xE60D, Status=<Status.SUCCESS: 0>)
2022-11-01 03:18:17.234 DEBUG (MainThread) [zigpy_znp.api] Command was not handled
2022-11-01 03:18:17.236 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.MsgCbIncoming.Callback(Src=0xE60D, IsBroadcast=<Bool.false: 0>, ClusterId=32801, SecurityUse=0, TSN=38, MacDst=0x0000, Data=b'\x00')
2022-11-01 03:18:17.237 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=38, profile_id=0, cluster_id=32801, data=Serialized[b'&\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2022-11-01 03:18:17.239 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.MsgCbIncoming.Callback(Src=0xE60D, IsBroadcast=<Bool.false: 0>, ClusterId=32801, SecurityUse=0, TSN=39, MacDst=0x0000, Data=b'\x00')
2022-11-01 03:18:17.240 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.MsgCbIncoming.Callback(Src=0xE60D, IsBroadcast=<Bool.false: 0>, ClusterId=32801, SecurityUse=0, TSN=40, MacDst=0x0000, Data=b'\x00')
2022-11-01 03:18:17.241 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=39, profile_id=0, cluster_id=32801, data=Serialized[b"'\x00"], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2022-11-01 03:18:17.242 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=40, profile_id=0, cluster_id=32801, data=Serialized[b'(\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2022-11-01 03:18:17.243 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.MsgCbIncoming.Callback(Src=0xE60D, IsBroadcast=<Bool.false: 0>, ClusterId=32801, SecurityUse=0, TSN=41, MacDst=0x0000, Data=b'\x00')
2022-11-01 03:18:17.244 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataRequestExt.Rsp(Status=<Status.SUCCESS: 0>)
2022-11-01 03:18:17.246 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0402]: bound 'temperature' cluster: Status.SUCCESS
2022-11-01 03:18:17.247 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0402]: Configuring cluster attribute reporting
2022-11-01 03:18:17.248 DEBUG (MainThread) [zigpy.zcl] [0xE60D:1:0x0402] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=43, command_id=<GeneralCommand.Configure_Reporting: 6>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
2022-11-01 03:18:17.249 DEBUG (MainThread) [zigpy.zcl] [0xE60D:1:0x0402] Sending request: Configure_Reporting(config_records=[AttributeReportingConfig(direction=0, attrid=0x0000, datatype=41, min_interval=30, max_interval=900, reportable_change=50)])
2022-11-01 03:18:17.250 DEBUG (MainThread) [zigpy_znp.zigbee.application] Sending packet ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), dst_ep=1, source_route=None, extended_timeout=False, tsn=43, profile_id=260, cluster_id=1026, data=Serialized[b'\x00+\x06\x00\x00\x00)\x1e\x00\x84\x032\x00'], tx_options=<TransmitOptions.ACK: 1>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2022-11-01 03:18:17.252 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=41, profile_id=0, cluster_id=32801, data=Serialized[b')\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2022-11-01 03:18:17.254 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestExt.Req(DstAddrModeAddress=AddrModeAddress(mode=<AddrMode.NWK: 2>, address=0xE60D), DstEndpoint=1, DstPanId=0x0000, SrcEndpoint=1, ClusterId=1026, TSN=43, Options=<TransmitOptions.SUPPRESS_ROUTE_DISC_NETWORK|ACK_REQUEST: 48>, Radius=0, Data=b'\x00\x2B\x06\x00\x00\x00\x29\x1E\x00\x84\x03\x32\x00')
2022-11-01 03:18:17.256 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0702]: bound 'smartenergy_metering' cluster: Status.SUCCESS
2022-11-01 03:18:17.256 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0702]: Configuring cluster attribute reporting
2022-11-01 03:18:17.257 DEBUG (MainThread) [zigpy.zcl] [0xE60D:1:0x0702] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=44, command_id=<GeneralCommand.Configure_Reporting: 6>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
2022-11-01 03:18:17.258 DEBUG (MainThread) [zigpy.zcl] [0xE60D:1:0x0702] Sending request: Configure_Reporting(config_records=[AttributeReportingConfig(direction=0, attrid=0x0400, datatype=42, min_interval=5, max_interval=900, reportable_change=1), AttributeReportingConfig(direction=0, attrid=0x0000, datatype=37, min_interval=30, max_interval=900, reportable_change=1), AttributeReportingConfig(direction=0, attrid=0x0200, datatype=24, min_interval=1, max_interval=900, reportable_change=1)])
2022-11-01 03:18:17.259 DEBUG (MainThread) [zigpy_znp.zigbee.application] Sending packet ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), dst_ep=1, source_route=None, extended_timeout=False, tsn=44, profile_id=260, cluster_id=1794, data=Serialized[b'\x00,\x06\x00\x00\x04*\x05\x00\x84\x03\x01\x00\x00\x00\x00\x00%\x1e\x00\x84\x03\x01\x00\x00\x00\x00\x00\x00\x00\x02\x18\x01\x00\x84\x03'], tx_options=<TransmitOptions.ACK: 1>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2022-11-01 03:18:17.260 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0201]: bound 'thermostat' cluster: Status.SUCCESS
2022-11-01 03:18:17.261 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0201]: Configuring cluster attribute reporting
2022-11-01 03:18:17.262 DEBUG (MainThread) [zigpy.zcl] [0xE60D:1:0x0201] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=45, command_id=<GeneralCommand.Configure_Reporting: 6>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
2022-11-01 03:18:17.263 DEBUG (MainThread) [zigpy.zcl] [0xE60D:1:0x0201] Sending request: Configure_Reporting(config_records=[AttributeReportingConfig(direction=0, attrid=0x0000, datatype=41, min_interval=30, max_interval=900, reportable_change=25), AttributeReportingConfig(direction=0, attrid=0x0011, datatype=41, min_interval=30, max_interval=900, reportable_change=25), AttributeReportingConfig(direction=0, attrid=0x0012, datatype=41, min_interval=30, max_interval=900, reportable_change=25)])
2022-11-01 03:18:17.264 DEBUG (MainThread) [zigpy_znp.zigbee.application] Sending packet ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), dst_ep=1, source_route=None, extended_timeout=False, tsn=45, profile_id=260, cluster_id=513, data=Serialized[b'\x00-\x06\x00\x00\x00)\x1e\x00\x84\x03\x19\x00\x00\x11\x00)\x1e\x00\x84\x03\x19\x00\x00\x12\x00)\x1e\x00\x84\x03\x19\x00'], tx_options=<TransmitOptions.ACK: 1>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2022-11-01 03:18:17.268 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0b04]: bound 'electrical_measurement' cluster: Status.SUCCESS
2022-11-01 03:18:17.268 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0b04]: Configuring cluster attribute reporting
2022-11-01 03:18:17.269 DEBUG (MainThread) [zigpy.zcl] [0xE60D:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=46, command_id=<GeneralCommand.Configure_Reporting: 6>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
2022-11-01 03:18:17.271 DEBUG (MainThread) [zigpy.zcl] [0xE60D:1:0x0b04] Sending request: Configure_Reporting(config_records=[AttributeReportingConfig(direction=0, attrid=0x050B, datatype=41, min_interval=5, max_interval=900, reportable_change=1), AttributeReportingConfig(direction=0, attrid=0x050D, datatype=41, min_interval=30, max_interval=900, reportable_change=1), AttributeReportingConfig(direction=0, attrid=0x050F, datatype=33, min_interval=5, max_interval=900, reportable_change=1)])
2022-11-01 03:18:17.272 DEBUG (MainThread) [zigpy_znp.zigbee.application] Sending packet ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), dst_ep=1, source_route=None, extended_timeout=False, tsn=46, profile_id=260, cluster_id=2820, data=Serialized[b'\x00.\x06\x00\x0b\x05)\x05\x00\x84\x03\x01\x00\x00\r\x05)\x1e\x00\x84\x03\x01\x00\x00\x0f\x05!\x05\x00\x84\x03\x01\x00'], tx_options=<TransmitOptions.ACK: 1>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2022-11-01 03:18:17.281 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.SrcRtgInd.Callback(DstAddr=0xE60D, Relays=[])
2022-11-01 03:18:17.288 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.SrcRtgInd.Callback(DstAddr=0xE60D, Relays=[])
2022-11-01 03:18:17.288 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataRequestExt.Rsp(Status=<Status.SUCCESS: 0>)
2022-11-01 03:18:17.290 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestExt.Req(DstAddrModeAddress=AddrModeAddress(mode=<AddrMode.NWK: 2>, address=0xE60D), DstEndpoint=1, DstPanId=0x0000, SrcEndpoint=1, ClusterId=1794, TSN=44, Options=<TransmitOptions.SUPPRESS_ROUTE_DISC_NETWORK|ACK_REQUEST: 48>, Radius=0, Data=b'\x00\x2C\x06\x00\x00\x04\x2A\x05\x00\x84\x03\x01\x00\x00\x00\x00\x00\x25\x1E\x00\x84\x03\x01\x00\x00\x00\x00\x00\x00\x00\x02\x18\x01\x00\x84\x03')
2022-11-01 03:18:17.312 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataRequestExt.Rsp(Status=<Status.SUCCESS: 0>)
2022-11-01 03:18:17.314 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestExt.Req(DstAddrModeAddress=AddrModeAddress(mode=<AddrMode.NWK: 2>, address=0xE60D), DstEndpoint=1, DstPanId=0x0000, SrcEndpoint=1, ClusterId=513, TSN=45, Options=<TransmitOptions.SUPPRESS_ROUTE_DISC_NETWORK|ACK_REQUEST: 48>, Radius=0, Data=b'\x00\x2D\x06\x00\x00\x00\x29\x1E\x00\x84\x03\x19\x00\x00\x11\x00\x29\x1E\x00\x84\x03\x19\x00\x00\x12\x00\x29\x1E\x00\x84\x03\x19\x00')
2022-11-01 03:18:17.315 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.SrcRtgInd.Callback(DstAddr=0xE60D, Relays=[])
2022-11-01 03:18:17.329 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataRequestExt.Rsp(Status=<Status.SUCCESS: 0>)
2022-11-01 03:18:17.330 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestExt.Req(DstAddrModeAddress=AddrModeAddress(mode=<AddrMode.NWK: 2>, address=0xE60D), DstEndpoint=1, DstPanId=0x0000, SrcEndpoint=1, ClusterId=2820, TSN=46, Options=<TransmitOptions.SUPPRESS_ROUTE_DISC_NETWORK|ACK_REQUEST: 48>, Radius=0, Data=b'\x00\x2E\x06\x00\x0B\x05\x29\x05\x00\x84\x03\x01\x00\x00\x0D\x05\x29\x1E\x00\x84\x03\x01\x00\x00\x0F\x05\x21\x05\x00\x84\x03\x01\x00')
2022-11-01 03:18:17.349 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.SrcRtgInd.Callback(DstAddr=0xE60D, Relays=[])
2022-11-01 03:18:17.350 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.BindRsp.Callback(Src=0xE60D, Status=<Status.SUCCESS: 0>)
2022-11-01 03:18:17.351 DEBUG (MainThread) [zigpy_znp.api] Command was not handled
2022-11-01 03:18:17.377 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.MsgCbIncoming.Callback(Src=0xE60D, IsBroadcast=<Bool.false: 0>, ClusterId=32801, SecurityUse=0, TSN=42, MacDst=0x0000, Data=b'\x00')
2022-11-01 03:18:17.378 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=42, profile_id=0, cluster_id=32801, data=Serialized[b'*\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2022-11-01 03:18:17.381 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0xff01]: bound 'sinope_manufacturer_specific' cluster: Status.SUCCESS
2022-11-01 03:18:17.382 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0xff01]: Configuring cluster attribute reporting
2022-11-01 03:18:17.382 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0xff01]: finished channel configuration
2022-11-01 03:18:17.384 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataRequestExt.Rsp(Status=<Status.SUCCESS: 0>)
2022-11-01 03:18:17.384 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.SrcRtgInd.Callback(DstAddr=0xE60D, Relays=[])
2022-11-01 03:18:17.387 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.SrcRtgInd.Callback(DstAddr=0xE60D, Relays=[])
2022-11-01 03:18:17.393 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.SrcRtgInd.Callback(DstAddr=0xE60D, Relays=[])
2022-11-01 03:18:17.414 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataConfirm.Callback(Status=<Status.SUCCESS: 0>, Endpoint=1, TSN=43)
2022-11-01 03:18:17.417 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.IncomingMsg.Callback(GroupId=0x0000, ClusterId=1026, SrcAddr=0xE60D, SrcEndpoint=1, DstEndpoint=1, WasBroadcast=<Bool.false: 0>, LQI=153, SecurityUse=<Bool.false: 0>, TimeStamp=2774025, TSN=0, Data=b'\x18\x2B\x07\x00', MacSrcAddr=0xE60D, MsgResultRadius=29)
2022-11-01 03:18:17.418 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xE60D), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=1026, data=Serialized[b'\x18+\x07\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=153, rssi=None)
2022-11-01 03:18:17.419 DEBUG (MainThread) [zigpy.zcl] [0xE60D:1:0x0402] Received ZCL frame: b'\x18+\x07\x00'
2022-11-01 03:18:17.419 DEBUG (MainThread) [zigpy.zcl] [0xE60D:1:0x0402] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=43, command_id=7, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-11-01 03:18:17.421 DEBUG (MainThread) [zigpy.zcl] [0xE60D:1:0x0402] Decoded ZCL frame: TemperatureMeasurement:Configure_Reporting_rsp(status_records=[ConfigureReportingResponseRecord(status=<Status.SUCCESS: 0>)])
2022-11-01 03:18:17.423 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0402]: Successfully configured reporting for '{'measured_value': (30, 900, 50)}' on 'temperature' cluster: [ConfigureReportingResponseRecord(status=<Status.SUCCESS: 0>)]
2022-11-01 03:18:17.424 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xE60D:1:0x0402]: finished channel configuration
