Skybell HD integration detection (push and motion) really slow to react
Hi, yesterday I installed my skybell hd. But I’m a bit disappointed as both the skybell integration of HA and IFTTT have a huge delay detecting motion and/or the button push. Is it me or it is really slow? Do you think this is normal behaviour?? Does someone have a workaround for this?? Thanks in advance!!
Same here. Just set this up today and it is very delayed. I was hoping to use Fully Browser and have it change to my camera view for 30 seconds or so when the button was pushed, but the sensors are so slow it doesn’t work well.
Hi @stallion11885, take a look at this thread with a few workarounds and other things like an answer I’ve just received from skyBell support regarding the issue:
That’s funny, I was just thinking about that. I tried using Tasker to watch for the skybell notification and from there I was able to send whatever commands I wanted immediately. Used it to open up the skybell app using the rest commands for fully Browser. Kind of a silly work around, but it does work!
Hello can you share how you did that with tasker.
I have Tasker watch for a skybell notification, then send an API call to fully kiosk to display my Cameras url. Here is the export of my Tasker profile-
Profile: Skybell Button Pushed
Event: Notification [ Owner Application:SkyBell Title:* Text:* Subtext:* Messages:* Other Text:* Cat:* New Only:Off ]
Enter: Tablet Cameras
A1: HTTP Post [ Server:Port:**TABLET_IP**:2323 Path:?cmd=loadURL&url=http%3A%2F%2F**SERVER_URL**%3A8123%2Fstates%2Fgroup.cameras_view&password=**SERVER_PASSWORD** Data / File: Cookies: User Agent: Timeout:10 Content Type: Output File: Trust Any Certificate:Off ]
Following up, on Thoukydides contributions if you can use skybell-sniff (requires a router in which you can ssh into) try my modification of Thoukydides gist
My github fork has an example bash script and Home Assistant instructions. The skybell sniffer detects when the request goes through your router to the skybell cloud servers, then triggers the bash script, which in turn publishes an mqtt topic. Then it’s a simple matter of setting up an mqtt sensor and automation in configuration.yaml. I have an example bash script with instructions in the comments of the script (some of which is also in the Readme file).
https://github.com/GeekVisit/Simple-Skybell-Sniffer
and GeekVisit Blog- Using Skybell without Wiring a New Doorbell
Many thanks to Thoukydides ! The skybell-sniff service has been rock solid ! I previousy used a google assistant notifer script but it had many bugs. The Home Assistant integration promises to be much more stable. I use this in conjunction with the regular Home Assistant skybell component so I can view the camera clips but don’t use the button or motion monitor as it is too slow. Now I can not only have it ring an mp3 file of a door bell, but use text to speech over my google home minis, "e.g., “Somone is at the door”, blink the lights, etc.
Thanks a lot @GeekVisit I’ll give this a try as it really seems the perfect solution.
I am already using @stallion11885 solution with Tasker and it was great (thank you too!!) but it depends upon your mobile with tasker installed and sometimes there are problems (mobile off or without being accesible at that moment or, sometimes not as quick, etc)
Any update on when this SkyBell HD Component timing issue might be fixed? I just installed a SkyBell specifically because it had a HA integration, but with the 1 - 2 minute delay before HA sees the event (if it sees it at all) makes trying to build any automation around this component pretty much out of the question. I see that some have found workarounds by using Tasker or a custom router sniffer, but neither of those options seem like long term solutions. It would be great if the developer of this component could help address this issue. Just curious if anyone has heard if it is being worked on?
I tried several times by contacting their support but although I always had good words from them, nothing was done. They really didn’t seem to care much. Sorry.
Thanks Jorge. I appreciate you following up. You would think with them being not in the good graces of Google that they would be eager to expand their customer base. I guess not. I have 30 days to decide if I want to return it. Please keep us updated if anything changes.
I’ve just tried to contact once more with skybell support regarding helping us with Skybell HD integration on HA. I’ll let you know their answer.
Honestly I’d ditch Skybell. I had one for a year and hated it. So many missed/delayed notifications or clips. It was total garbage. Switched to the Eufy doorbell cam and it’s great (and there’s a working alpha/beta of an integration for HASS being worked on/available for testing).
If you cannot use ‘the sniffer’ solution I agree with @AJ132 .
This is their answer to my latest question (after their latest one, 1 year ago) regarding helping with integration of home assistant. Good intentions, but he didn’t have a clue of what I was talking about: 0 mention to home assistant, talked about a GoogleAssistant integration that was not working (anyway it had never worked for reacting to button push neither for video casting, only for changing some options (like turning on/off its light and door chime muting)),…read here:
Thank you for contacting SkyBell Technical Support.
Although this is technical support and not product development, I have created a list of public requested integrations. The Google Assistant Integration existed and worked until now for some reason I cannot sign into my SkyBell account through Google Assistant to use it. I have sent this to our developers in hopes that this integration can be mended on our end and I’ve also included a recommendation that the SkyBell send video to Alexa Echo Show and Google Home Hub. I will let you know once I hear an update about these inquiries.
If you would like to call us, please contact us at :
Our Technical Support number is: 1 (888)423-9194
Hours of Operation:
Monday-Friday 7:00AM - 5:00PM PST
Saturday 8:00AM - 2:00PM PST
Sunday – Closed
Feels like an ending story. Still surprised their cloud sever is still running. Every time I only read bad customer support stories. I love the idea that there is no costs for using their cloud server, but maybe I should have a look at some local data solution with a NAS or something. Don’t know about Eufy. But will have a look.
I tried to get the skybelll-sniff to work with my EdgeRouter ER-4, but was unable to get to work after configuring the router to allow ssh login without a password, e.g. by adding your public key to theauthorized_keys. I guess, I was not sure how to get HA to use the private key to logon to the router, plus I did not find the log file on the router that the sniffer was looking for when I ssh’d into the router. I gave up and decided to go with ErikNL solution https://www.tindie.com/stores/ErikLemcke/ mentioned in another post. I liked his solution because it didn’t require any modifications to the existing doorbell wiring, which might interfere with the SkyBell. Hopefully they can both work on the same circuit.
I’m now completely fed up with the attrocious delay in HA notifications from Skybell. So I’ve been trying to implement your HA-tweaked skybell packet sniffer but I’m not getting the expected packet captures from tcpdump. When idle, I see repeating UDP packet lengths of 369… 97… 177. @thouky documents the pattern as 321…97…113 but this difference should not matter to the sniffer logic.
The show stopper that has me perplexed is that I have only once seen a doorbell button press or motion trigger packet lengths of 465 followed by 49. All that tcpdump shows is a longer delay before the idle loop resumes, which I assume is the video upload delay. Notifications via the SB app are happening right away, so it’s not missing anything.
Note: I am not actually running the sniffer yet, but just running tcpdump directly on an ASUSWRT router in a terminal window to confirm proper behavior. My doorbell is the Skybell HD trimplus, firmware version 7045. Connection quality 100%.
Any idea how Skybell packets can be going to/from AWS that aren’t showing via tcpdump? I doubt there is an additional port involved.
tcpdump -lpnttti eth0 port 5683
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
00:00:00.000000 IP xxx.141.41.146.5683 > 54.187.184.145.5683: UDP, length 369
00:00:00.076988 IP 54.187.184.145.5683 > xxx.141.41.146.5683: UDP, length 97
00:00:31.540919 IP xxx.141.41.146.5683 > 54.187.184.145.5683: UDP, length 177
00:00:00.077149 IP 54.187.184.145.5683 > xxx.141.41.146.5683: UDP, length 97
00:01:35.562197 IP xxx.141.41.146.5683 > 35.160.98.165.5683: UDP, length 369
00:00:00.078320 IP 35.160.98.165.5683 > xxx.141.41.146.5683: UDP, length 97
00:00:31.126583 IP xxx.141.41.146.5683 > 35.160.98.165.5683: UDP, length 177
00:00:00.079365 IP 35.160.98.165.5683 > xxx.141.41.146.5683: UDP, length 97
00:00:30.188096 IP xxx.141.41.146.5683 > 35.160.98.165.5683: UDP, length 369
00:00:00.078986 IP 35.160.98.165.5683 > xxx.141.41.146.5683: UDP, length 97
       <sometimes UDP packets dropped, but this is expected>
00:00:33.507298 IP xxx.141.41.146.5683 > 35.160.98.165.5683: UDP, length 177
00:00:00.079261 IP 35.160.98.165.5683 > xxx.141.41.146.5683: UDP, length 97
00:00:33.256207 IP xxx.141.41.146.5683 > 54.187.184.145.5683: UDP, length 369
00:00:00.076595 IP 54.187.184.145.5683 > xxx.141.41.146.5683: UDP, length 97
        <Doorbell button pressed.  2.5minutes later, idle loop resumes>
00:02:26.607990 IP xxx.141.41.146.5683 > 34.221.83.88.5683: UDP, length 369
00:00:00.077718 IP 34.221.83.88.5683 > xxx.141.41.146.5683: UDP, length 97
00:00:33.126161 IP xxx.141.41.146.5683 > 34.221.83.88.5683: UDP, length 177
Update to my last post… The tcpdump command was specifying the “eth0” interface on the router and that needed to be changed to either “br0” or “any”. With eth0, it was only capturing my public WAN IP UDP traffic on port 5683. Now, it is showing the internal IP traffic of the Skybell as it should.
I have tried your skybell-sniffer code and Thouky’s and they both work fine and catch a 465/49 length sequences to trigger a motion/button press notification. However, my problem still remains that only rarely will an actual doorbell press create a 465 length packet in the tcpdump listing.
On the other hand, Skybell push notifications to my mobile device happen immediately and never miss.
I have not been able to figure out why in the heck tcpdump on this Asus RT86U router is missing these button press UDP packets.
