### The problem
Ever since updating to Home Assistant Core 2023.1.0, all device…s connected to my SkyConnect in the ZHA integration are unavailable.
Initially I got an error in the logs saying something among the lines of „ Couldn't start EZSP“, but after unplugging the SkyConnect and plugging it back in, and rebooting the RPi4, the logs are gone.
Rolling back to 2022.12.9 does not fix the issue.
All Zigbee devices connected through ZHA remain unavailable.
### What version of Home Assistant Core has the issue?
2023.1.0
### What was the last working version of Home Assistant Core?
2022.12.9
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
ZHA
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/zha/
### Diagnostics information
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.1.0",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.7",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/Helsinki",
"os_name": "Linux",
"os_version": "5.15.76-v8",
"supervisor": "2022.12.1",
"host_os": "Home Assistant OS 9.4",
"docker_version": "20.10.19",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"eero": {
"version": "1.1.4",
"requirements": [
"pypng==0.0.20",
"PyQRCode==1.2.1"
"adaptive_lighting": {
"version": "1.4.1",
"requirements": []
"eero_tracker": {
"version": "1.0.10",
"requirements": [
"requests>=2.13.0"
"hacs": {
"version": "1.29.0",
"requirements": [
"aiogithubapi>=22.10.1"
"alarmo": {
"version": "v1.9.7",
"requirements": []
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.34.5",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.90",
"zigpy-deconz==0.19.2",
"zigpy==0.52.3",
"zigpy-xbee==0.16.2",
"zigpy-zigate==0.10.3",
"zigpy-znp==0.9.2"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"type": "_slzb-06._tcp.local.",
"name": "slzb-06*"
"dependencies": [
"file_upload"
"after_dependencies": [
"onboarding",
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"config": {},
"config_entry": {
"entry_id": "2f9a3d05d73ef69f15803db3c292399b",
"version": 3,
"domain": "zha",
"title": "SkyConnect v1.0",
"data": {
"device": {
"path": "/dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_849dd944a518ec119e1eeb9a47486eb0-if00-port0",
"flow_control": "software",
"baudrate": 115200
"radio_type": "ezsp"
"options": {},
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "usb",
"unique_id": "**REDACTED**",
"disabled_by": null
"application_state": {
"node_info": {
"nwk": 0,
"ieee": "**REDACTED**",
"logical_type": 0
"network_info": {
"extended_pan_id": "**REDACTED**",
"pan_id": 36120,
"nwk_update_id": 0,
"nwk_manager_id": 0,
"channel": 15,
"channel_mask": 134215680,
"security_level": 5,
"network_key": "**REDACTED**",
"tc_link_key": {
"key": [
90,
105,
103,
66,
101,
101,
65,
108,
108,
105,
97,
110,
99,
101,
48,
57
"tx_counter": 65536,
"rx_counter": 0,
"seq": 0,
"partner_ieee": "**REDACTED**"
"key_table": [],
"children": [],
"nwk_addresses": {},
"stack_specific": {
"ezsp": {
"hashed_tclk": "f5888ed0226f6bbb66f3c112fbe95536"
"metadata": {
"ezsp": {
"manufacturer": "Nabu Casa",
"board": "SkyConnect v1.0",
"version": "7.1.1.0 build 273",
"stack_version": 9,
"can_write_custom_eui64": true
"source": "[email protected]"
"counters": {
"controller_app_counters": {
"unicast_rx": {
"__type": "<class 'zigpy.state.Counter'>",
"repr": "Counter(name='unicast_rx', _raw_value=16, reset_count=0, _last_reset_value=0)"
"unicast_tx_success": {
"repr": "Counter(name='unicast_tx_success', _raw_value=14, reset_count=0, _last_reset_value=0)"
"broadcast_tx_success": {
"repr": "Counter(name='broadcast_tx_success', _raw_value=1, reset_count=0, _last_reset_value=0)"
"unicast_tx_failure": {
"repr": "Counter(name='unicast_tx_failure', _raw_value=4, reset_count=0, _last_reset_value=0)"
"unicast_tx_failure_duplicate": {
"repr": "Counter(name='unicast_tx_failure_duplicate', _raw_value=3, reset_count=0, _last_reset_value=0)"
"watchdog_reset_requests": {
"repr": "Counter(name='watchdog_reset_requests', _raw_value=1, reset_count=0, _last_reset_value=0)"
"ezsp_counters": {
"MAC_RX_BROADCAST": {
"repr": "Counter(name='MAC_RX_BROADCAST', _raw_value=20, reset_count=0, _last_reset_value=0)"
"MAC_TX_BROADCAST": {
"repr": "Counter(name='MAC_TX_BROADCAST', _raw_value=27, reset_count=0, _last_reset_value=0)"
"MAC_RX_UNICAST": {
"repr": "Counter(name='MAC_RX_UNICAST', _raw_value=21, reset_count=0, _last_reset_value=0)"
"MAC_TX_UNICAST_SUCCESS": {
"repr": "Counter(name='MAC_TX_UNICAST_SUCCESS', _raw_value=24, reset_count=0, _last_reset_value=0)"
"MAC_TX_UNICAST_RETRY": {
"repr": "Counter(name='MAC_TX_UNICAST_RETRY', _raw_value=8, reset_count=0, _last_reset_value=0)"
"MAC_TX_UNICAST_FAILED": {
"repr": "Counter(name='MAC_TX_UNICAST_FAILED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"APS_DATA_RX_BROADCAST": {
"repr": "Counter(name='APS_DATA_RX_BROADCAST', _raw_value=1, reset_count=0, _last_reset_value=0)"
"APS_DATA_TX_BROADCAST": {
"repr": "Counter(name='APS_DATA_TX_BROADCAST', _raw_value=1, reset_count=0, _last_reset_value=0)"
"APS_DATA_RX_UNICAST": {
"repr": "Counter(name='APS_DATA_RX_UNICAST', _raw_value=16, reset_count=0, _last_reset_value=0)"
"APS_DATA_TX_UNICAST_SUCCESS": {
"repr": "Counter(name='APS_DATA_TX_UNICAST_SUCCESS', _raw_value=14, reset_count=0, _last_reset_value=0)"
"APS_DATA_TX_UNICAST_RETRY": {
"repr": "Counter(name='APS_DATA_TX_UNICAST_RETRY', _raw_value=0, reset_count=0, _last_reset_value=0)"
"APS_DATA_TX_UNICAST_FAILED": {
"repr": "Counter(name='APS_DATA_TX_UNICAST_FAILED', _raw_value=4, reset_count=0, _last_reset_value=0)"
"ROUTE_DISCOVERY_INITIATED": {
"repr": "Counter(name='ROUTE_DISCOVERY_INITIATED', _raw_value=5, reset_count=0, _last_reset_value=0)"
"NEIGHBOR_ADDED": {
"repr": "Counter(name='NEIGHBOR_ADDED', _raw_value=3, reset_count=0, _last_reset_value=0)"
"NEIGHBOR_REMOVED": {
"repr": "Counter(name='NEIGHBOR_REMOVED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"NEIGHBOR_STALE": {
"repr": "Counter(name='NEIGHBOR_STALE', _raw_value=0, reset_count=0, _last_reset_value=0)"
"JOIN_INDICATION": {
"repr": "Counter(name='JOIN_INDICATION', _raw_value=0, reset_count=0, _last_reset_value=0)"
"CHILD_REMOVED": {
"repr": "Counter(name='CHILD_REMOVED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"ASH_OVERFLOW_ERROR": {
"repr": "Counter(name='ASH_OVERFLOW_ERROR', _raw_value=0, reset_count=0, _last_reset_value=0)"
"ASH_FRAMING_ERROR": {
"repr": "Counter(name='ASH_FRAMING_ERROR', _raw_value=0, reset_count=0, _last_reset_value=0)"
"ASH_OVERRUN_ERROR": {
"repr": "Counter(name='ASH_OVERRUN_ERROR', _raw_value=0, reset_count=0, _last_reset_value=0)"
"NWK_FRAME_COUNTER_FAILURE": {
"repr": "Counter(name='NWK_FRAME_COUNTER_FAILURE', _raw_value=0, reset_count=0, _last_reset_value=0)"
"APS_FRAME_COUNTER_FAILURE": {
"repr": "Counter(name='APS_FRAME_COUNTER_FAILURE', _raw_value=0, reset_count=0, _last_reset_value=0)"
"UTILITY": {
"repr": "Counter(name='UTILITY', _raw_value=0, reset_count=0, _last_reset_value=0)"
"APS_LINK_KEY_NOT_AUTHORIZED": {
"repr": "Counter(name='APS_LINK_KEY_NOT_AUTHORIZED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"NWK_DECRYPTION_FAILURE": {
"repr": "Counter(name='NWK_DECRYPTION_FAILURE', _raw_value=0, reset_count=0, _last_reset_value=0)"
"APS_DECRYPTION_FAILURE": {
"repr": "Counter(name='APS_DECRYPTION_FAILURE', _raw_value=0, reset_count=0, _last_reset_value=0)"
"ALLOCATE_PACKET_BUFFER_FAILURE": {
"repr": "Counter(name='ALLOCATE_PACKET_BUFFER_FAILURE', _raw_value=0, reset_count=0, _last_reset_value=0)"
"RELAYED_UNICAST": {
"repr": "Counter(name='RELAYED_UNICAST', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PHY_TO_MAC_QUEUE_LIMIT_REACHED": {
"repr": "Counter(name='PHY_TO_MAC_QUEUE_LIMIT_REACHED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PACKET_VALIDATE_LIBRARY_DROPPED_COUNT": {
"repr": "Counter(name='PACKET_VALIDATE_LIBRARY_DROPPED_COUNT', _raw_value=0, reset_count=0, _last_reset_value=0)"
"TYPE_NWK_RETRY_OVERFLOW": {
"repr": "Counter(name='TYPE_NWK_RETRY_OVERFLOW', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PHY_CCA_FAIL_COUNT": {
"repr": "Counter(name='PHY_CCA_FAIL_COUNT', _raw_value=0, reset_count=0, _last_reset_value=0)"
"BROADCAST_TABLE_FULL": {
"repr": "Counter(name='BROADCAST_TABLE_FULL', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PTA_LO_PRI_REQUESTED": {
"repr": "Counter(name='PTA_LO_PRI_REQUESTED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PTA_HI_PRI_REQUESTED": {
"repr": "Counter(name='PTA_HI_PRI_REQUESTED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PTA_LO_PRI_DENIED": {
"repr": "Counter(name='PTA_LO_PRI_DENIED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PTA_HI_PRI_DENIED": {
"repr": "Counter(name='PTA_HI_PRI_DENIED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PTA_LO_PRI_TX_ABORTED": {
"repr": "Counter(name='PTA_LO_PRI_TX_ABORTED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PTA_HI_PRI_TX_ABORTED": {
"repr": "Counter(name='PTA_HI_PRI_TX_ABORTED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"ADDRESS_CONFLICT_SENT": {
"repr": "Counter(name='ADDRESS_CONFLICT_SENT', _raw_value=0, reset_count=0, _last_reset_value=0)"
"EZSP_FREE_BUFFERS": {
"repr": "Counter(name='EZSP_FREE_BUFFERS', _raw_value=251, reset_count=0, _last_reset_value=0)"
"broadcast_counters": {},
"device_counters": {},
"group_counters": {}
"versions": {
"bellows": "0.34.5",
"zigpy": "0.52.3",
"zigpy_deconz": "0.19.2",
"zigpy_xbee": "0.16.2",
"zigpy_znp": "0.9.2",
"zigpy_zigate": "0.10.3",
"zhaquirks": "0.0.90"
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
```txt
Logger: homeassistant.components.sensor
Source: components/sensor/__init__.py:980
Integration: Sensor (documentation, issues)
First occurred: 5 January 2023 at 21:06:10 (6 occurrences)
Last logged: 5 January 2023 at 21:06:14
Entity sensor.bathroom_occupancy_sensor_lqi (<class 'homeassistant.components.zha.sensor.LQISensor'>) is using native unit of measurement 'None' which is not a valid unit for the device class ('signal_strength') it is using; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
### Additional information
_No response_
