I have some switches setup in HA that work perfectly fine. but they are using the “lightning” on and off buttons, how do I make them use the slide switches as I think they look better???
Many Thanks
Lee
Many Thanks
Lee
You mean to be able to dim a light without bringing up an info panel? You could set up an input_slider component with a range between 0 to 255. You simply set up something in automation section:
[code]input_slider:
slider_switch1
initial: 0
min: 0
max: 255
step: 1
automation:
…which calls the script:
shell_command:
switch1_dimmer: ~/shell_script/switch1_dimmer
And here’s the heart of the script:
#!/bin/bash
SWITCH1_BRI=$(curl -X GET http://localhost:8123/api/states/input_slider.slider_switch1 2> /dev/null | \
tail -n2 | head -n1 | awk '{print $2}' | sed -e 's/"//g' )
-X POST http://localhost:8123/api/states/light.switch1 -d '{"state": "on", "attributes": {"brightness": '$SWITCH1_BRI', "transition": 1}}'
However, it does not look like it will work. I tried executing a statement to set the brightness of a light:
curl -X POST http://localhost:8123/api/states/light.bedroom_lamp_l -d '{"state": "on", "attributes": {"brightness": 100, "transition": 1}}'
It simply returned a result:
"attributes": {
"brightness": 100,
"transition": 1
"entity_id": "light.bedroom_lamp_l",
"last_changed": "22:31:53 14-04-2016",
"last_updated": "22:31:53 14-04-2016",
"state": "on"
And it did nothing.
But even if it did, every time you restart Home Assistant, the state of the brightness for input_slider.slider_switch1 won’t be saved.
So at any rate, it does not seem possible to change the switch into a slider.
Hi!
I think @grooml means the two buttons that are shown if an entity has assumed state set to true. If assumed state is set to false, a slider button for on/off will show instead.
Depending on the type of device, it might be possible to change a config option to make the entity not show as to have an assumed state. For MQTT and MySensors this option is called “optimistic” in the config. See for example:
Martin is correct, I think its down to the assumed state thing…If I remove the persistence line in the conf the switches turn into slide switches but they don’t work.(i.e. they will not slide to the on position) ill have another bash tonight…
