🔹 slider-entity-row - Add sliders to entities cards
I have noticed that when the slider-entity-row is combined with a conditional entity row the state values is not displayed.
type: entities
entities:
  - type: custom:slider-entity-row
    entity: input_number.download_speed_threshold
    full_row: true
    max: 50
    step: 1
    card_mod:
      style: |
        .state {
          font-weight: 600;
          font-size: 120%;
  - type: conditional
    conditions:
      - entity: input_number.download_speed_threshold
        state_not: '0'
    row:
      full_row: true
      max: 50
      step: 1
title: Sliders
show_header_toggle: false
This is how it looks like.
However if I set the hide_state parameter, the state is shown.
type: entities
entities:
    full_row: true
    max: 50
    step: 1
    card_mod:
      style: |
        .state {
          font-weight: 600;
          font-size: 120%;
  - type: conditional
    conditions:
        state_not: '0'
    row:
      full_row: true
      hide_state: false
      max: 50
      step: 1
      card_mod:
        style: |
          .state {
            font-weight: 600;
            font-size: 120%;
title: Sliders
The state is shown on the conditional row. However, the formatting is done correctly.
By playing around with card-mod, I was able to format the state value for the conditional row.
type: entities
entities:
    full_row: true
    max: 50
    step: 1
    card_mod:
      style: |
        .state {
          font-weight: 600;
          font-size: 120%;
  - type: conditional
    card_mod:
      style:
        slider-entity-row$ div: |
          .state {
            font-weight: 600;
            font-size: 120%;
    conditions:
        state_not: '0'
    row:
      full_row: true
      hide_state: false
      max: 50
      step: 1
title: Sliders
Just thought of sharing this.
Hi there,
I want to use the slider inline within a multiple-entity-row. But the input_number I want to see as slider just shows up as number:
What am I doing wrong?
        - type: horizontal-stack
          style: |
            ha-card {margin-top: -15px; }
          cards:
            - type: entities
              entities:
                - type: custom:multiple-entity-row
                  entity: binary_sensor.irrigation_unlimited_c2_z1
                  show_state: false
                  secondary_info: last-changed
                  entities:
                    - icon: mdi:toggle-switch-outline
                      state_color: true
                      tap_action:
                        action: call-service
                        service: irrigation_unlimited.toggle
                        service_data:
                          entity_id: binary_sensor.irrigation_unlimited_c2_z1
                      entity: input_number.iu_zone_1_run_time
                      full_row: true
                      max: 60
                      step: 1
                      card_mod:
                        style: |
                          .state {
                            font-weight: 600;
                            font-size: 120%;
                    - icon: mdi:gesture-tap
                      state_color: true
                      tap_action:
                        service: script.iu_start_bewaesserung
                        service_data: {}
                        target: {}
Any help would be greatly appreciated!
Cheers,
Hauke
Maybe that will help you further
type: entities
entities:
    style:
      hui-generic-entity-row:
          state-badge {
            display: none;
          .info.pointer {
            color: #018752;
            font-size: 16px;
            font-weight: bold !important;
            text-overflow: unset !important;
            white-space: unset !important;
      ha-entity-toggle:
          ha-switch {
            --switch-unchecked-button-color: #018752;
            --switch-checked-button-color: #bf5e5e;
    entity: binary_sensor.irrigation_unlimited_c1_z1
    state_color: true
    show_state: false
    entities:
      - attribute: current_duration
        hide_unavailable: true
      - attribute: time_remaining
      - attribute: percent_complete
        unit: '%'
      - entity: input_number.iu_zone_1_run_time
        format: precision0
      - entity: switch.zone_1
        toggle: true
    full_row: true
    step: 1
    hide_state: true
state_color: true
Thank’s for that… I will give it a try…
Meanwhile I tried this:
The first button activates/deactivates the zone, the second contains the slider and the last one fires the event to run and starts blinking in a different color… Still missing the remaining % and duration… So I will try to combine your approach with mine… :wink:
Since last HA update, the slider does not appear if the light is off.
How can I fix it?
I would love a bigger and better cover control. Then it will be easier to hit. Please see attached screenshot for a mock up. Thank you!
bigger better cover control resize again
Shutter card is very elegant but it is a bit big and sliding it down or up is a bit difficult when the rest of the page scroll vertically. It is also not possible to just tap a place at the icon and have the cover go to that point. You have to grab the edge and slide it:
With a light dimmer. Would it be possible to have clicking the light bulb to the left toggle the light instead of opening the menu? This would eliminate the need for toggle switch to the right of the slider and give me more resolution on the slider.
Same is happening to me… any update about it?
It returned to normal after a few days. Maybe a cache problem …
Hi!
Sorry for a noob question but how can I add slider also to color-temp?
Hi everyone
I am trying to populate the slider using auto-entities but it seems unsupported. Anybody ever tried this before?
type: vertical-stack
cards:
  - type: custom:auto-entities
    filter:
      include:
        - entity_id: climate.eq_3_*
          options:
            entity: this.entity_id
    card:
results in
No entity specified.
entities:
  • entity: climate.eq_3_living_room
  • entity: climate.eq_3_dining_room
  • entity: climate.eq_3_master_bedroom
  • entity: climate.eq_3_office
  • entity: climate.eq_3_guest_toilet
  • entity: climate.eq_3_kitchen
  • entity: climate.eq_3_master_bathroom
  • entity: climate.eq_3_walk_in
This works for me:
cards:
    filter:
      include:
        - entity_id: light.*
          options:
    card:
      type: entities
A slider-entity-row is replacement for an entity row item in an entities card. It can’t be used elsewhere.
Is it possible to modify your example to show just one slider that then controls all the entities at once?
i.e. set all thermostats to 18 °C when I go out etc.?
Edit: I do know there is the possibility of using groups, but I am trying to avoid static groups. Otherwise, everytime I add a device that fits a profile, I have to manually add it to the respective group(s).
Not that I know of. You’ll either need to manually manage a group (at least for this example case, how often will you be adding/removing thermostats?) or write some script or automation that can select these entities and use a number input helper. Off the top of my head, I’m not immediately sure how you’d do that, although I think it’s possible without actually trying first :slight_smile:
FWIW, groups can be really useful, and although you have to manually add/remove things to them from yaml, you can reload the groups from the Server Controls section of the Configuration ui without having to restart Home Assistant entirely, so it’s not THAT much a pain… just the same, if the HA devs ever do another month of “What the heck”, editing groups/group entities from the UI would be a good request.
I’ve been using slider-entity-row for a long time, but recently I’ve been having issues with it loading. When I load the page with slider-entity-row in a browser (Firefox - Desktop or Mobile, Chrome Desktop) the page loads fine and I can see the sliders, but then after a second they disappear and I get the dreaded red box “Custom element doesn’t exist: slider-entity-row.” When this happens, in the log I see:
hacsfiles/lovelace-slider-entity-row/slider-entity-row.js:1:1 SyntaxError: redeclaration of let o
I had a similar problem with state-switch and I got that to go away by removing it and reinstalling it. Unfortunately with slider-entity-row I’ve done that and I still have the same issue. And now as I’m writing this I tried one other thing (while working in Chrome Desktop)…enabling the debug tools and then doing an “Empty Cache and Hard Reload” gets slider-entity-row to load, but then state-switch doesn’t load. Tried this repeatably and still the same. Closed the debug tools and repeatably reloading the page causes one to load and the other to fail with the “element doesn’t exist” error. And in the log I see the “Uncaught SyntaxError: Identifier ‘e’ has already been declared” for whichever component didn’t load. It seems there might be a conflict between these two components. I’m running current versions of both components via HACS and I’m currently running HA 2021.11.3
@thomasloven What’s your take on this? It seems when I reload the page either slider-entity-row or state-switch initially shows up, but then one or the other disappears. The behavior is pretty consistent in either Chrome or Firefox. Which ever one doesn’t load always shows a “Uncaught SyntaxError: Identifier ‘e’ has already been declared” error in the log. I’m presuming there’s a conflict between these two components when they are in the same scope. (?) Thanks.
Hi
How can i get the buttons for L M H on a fan like you have?
fan
Fan Control Entity Row in HACS will give you the card.
but make sure you are using the correct version of that plugin.
Fan control entity row is for the older HA Fan implementation that uses a speed list.
the new HA requires you to use either percentages or modes. there are plugins available for those as well in HACS.
sorry in advance for this super silly post, but I can’t seems to get the slider working at all.
I did add through HACS, which automatically added the resources (/hacsfiles/lovelace-slider-entity-row/slider-entity-row.js?hacstag=1448997001721) inside /settings/dashboards/resources
when I add a light or my IKEA blinds
  - entity: light.downstaire
    toggle: true
    type: 'custom:slider-entity-row'
this return “No card type found”
