🔹 slider-entity-row - Add sliders to entities cards
Hey,
my goal is to have it like the attached image.
Thanks,
Stefan31-03-_2021_15-24-40
I’ve never tried it but I don’t think you can combine two custom entity rows like that.
I would have no idea what the syntax to make that work would even look like.
And besides, I’m confused about the point.
A boolean is a binary entity - on or off. There shouldn’t be a “slider” associated with a boolean because a slider implies an analog entity.
How would a slider interact with a boolean?
Hi, i’m using this slider to control motors, a video here: https://twitter.com/Clodo76/status/1377401794741997568
It’s possible to trigger the automation during slider movement?
My motors expect final position, not movement, and i need to send many mid steps as possible to avoid ‘brutal’ repositioning.
Maybe with an hack to apply to the JS directly?
Thanks!
Use an input_number and trigger the automations from that. Then you won’t even need slider-entity-row.
Sorry but i don’t understand what you mean, please be patience, i’m a newbie about HA
This (config below) show a slider in lovelace that allow me to simulate my motors, i need to trigger the automation, the send of MQTT, when my finger in mobile HA move the slider, currenty it’s triggered only one time when i release the finger
thx anyway for the reply
# configuration.yaml
input_number:
  holodeck_roll:
    min: -30
    max: 30
    step: 1
    initial: 0
    unit_of_measurement: "°"
    icon: mdi:angle-acute
    mode: slider
# automations.yaml
- alias: Holodeck Roll
    platform: state
    entity_id: input_number.holodeck_roll
    service: mqtt.publish
      topic: house/holodeck/roll/set
      retain: true
      payload: '{{ states(''input_number.holodeck_roll'') | float }}'
# lovelace card
type: entities
entities:
  - entity: input_number.holodeck_roll
Will it be possible to add a background to the volume slider? I’m using only the slider to put below a custom:button-card but the background of the slider-entity-row is transparant. Or even better, is there anyway to keep the same layout of my button-card and integrate the slider inside it. :slight_smile:
In a simple example;
Can I add padding to the left and or right side of a slider?
type: 'custom:slider-entity-row'
entity: light.kok
full_row: true
hide_state: true
That is really nic! can you share your automations as well :slight_smile: ?
Since about a week the slider-entity-row for my Shelly dimmer (through) the Shelly integration disappears when it’s turned off. My Tradfri bulb through Zigbee2MQTT does not. How can I fix this? Or should is it a bug in the Shelly integration and should I integrate the Shelly dimmer through MQTT for the time being?
I am only now seeing your reply. But that looks pretty clever. Thanks!
Have you integrated in a entities card? I am not sure how/if that can be done.
I have a problem see screenshot.
Only by the last group "Eetkamer " I see an slider.
Schermafbeelding 2021-05-27 om 21.28.04
Here is the code.yaml.
type: entities
title: Woonkamer
entities:
  - entities:
      - entity: light.hue_ambiance_spot_1
        hide_when_off: false
        hold_action:
          action: more-info
        icon: mdi:track-light
        name: Hue spot 1
        toggle: true
        type: custom:slider-entity-row
      - entity: light.hue_ambiance_spot_2
        hold_action:
          action: more-info
        name: Hue spot 2
        toggle: true
      - entity: light.hue_ambiance_spot_3
        hold_action:
          action: more-info
        name: Hue spot 3
        toggle: true
    head:
      entity: light.spots_achter
      hold_action:
        action: more-info
      toggle: true
    hold_action:
      action: more-info
    type: custom:fold-entity-row
  - entities:
      - entity: light.hue_ambiance_spot_4
        hold_action:
          action: more-info
        name: Hue spot 4
        toggle: true
      - entity: light.hue_ambiance_spot_5
        hold_action:
          action: more-info
        name: Hue spot 5
        toggle: true
      - entity: light.hue_ambiance_spot_6
        hold_action:
          action: more-info
        name: Hue spot 6
        toggle: true
    head:
      entity: light.spots_midden
      hold_action:
        action: more-info
      toggle: true
    hold_action:
      action: more-info
  - entities:
      - entity: light.schemerlamp_woonkamer
        hold_action:
          action: more-info
        icon: mdi:lamp
        toggle: true
    head:
      entity: light.schemerlampen
      hold_action:
        action: more-info
      icon: mdi:lamp
      toggle: true
    hold_action:
      action: more-info
  - entities:
      - entity: light.hue_ambiance_lamp_1
        hold_action:
          action: more-info
        icon: mdi:ceiling-light
        toggle: true
    head:
      hold_action:
        action: more-info
      toggle: true
    hold_action:
      action: more-info
And this are the warnings:
Configuration errors detected:
* Required key "entities.0.entity" is missing.
* Required key "entities.0.name" is missing.
* Required key "entities.0.tap_action" is missing.
* Required key "entities.0.view" is missing.
* Required key "entities.0.conditions" is missing.
* Required key "entities.0.url" is missing.
* Required key "entities.0.attribute" is missing.
* Required key "entities.0.service" is missing.
* Required key "entities.1.entity" is missing.
* Required key "entities.1.name" is missing.
* Required key "entities.1.tap_action" is missing.
* Required key "entities.1.view" is missing.
* Required key "entities.1.conditions" is missing.
* Required key "entities.1.url" is missing.
* Required key "entities.1.attribute" is missing.
* Required key "entities.1.service" is missing.
* Required key "entities.2.entity" is missing.
* Required key "entities.2.name" is missing.
* Required key "entities.2.tap_action" is missing.
* Required key "entities.2.view" is missing.
* Required key "entities.2.conditions" is missing.
* Required key "entities.2.url" is missing.
* Required key "entities.2.attribute" is missing.
* Required key "entities.2.service" is missing.
* Required key "entities.3.entity" is missing.
* Required key "entities.3.name" is missing.
* Required key "entities.3.tap_action" is missing.
* Required key "entities.3.view" is missing.
* Required key "entities.3.conditions" is missing.
* Required key "entities.3.url" is missing.
* Required key "entities.3.attribute" is missing.
* Required key "entities.3.service" is missing.
What I’m doing wrong?
Did you update to core-2021.0.6b1? I started having the same issue after testing out the beta
using the beta 2 now, but hadnt seen the issues you report, and all sliders behave properly.
you seem to use an odd config though, with double entities:
change that first to single use and report back?
type: entities
title: Woonkamer
entities:
    hold_action:
      action: more-info
    name: Hue spot 1
    toggle: true
    hold_action:
      action: more-info
    name: Hue spot 2
    toggle: true
etc etc
Seems like several others are having the same issue, there are a few issues open on the Github. Here is the more active one:
Since the last update it’s works again.
Hi All.
Here code to high customize sliders:
type: entities
debug_cardmod: true
entities:
  - type: 'custom:slider-entity-row'
    entity: light.blablabla
    full_row: true
    toggle: false
    hide_state: true
style:
    ha-card {   --ha-card-box-shadow: 0px;
    background-color: rgba(255, 255, 255, 0.4);
    border: 1px solid rgba(100, 100,100, 0.4);
    border-radius: 10px;
    box-shadow: -1px -1px 7px 3px
    #fff, 2px 1px 7px 2px   rgba(0, 0, 0, 0.5);
    text-shadow: 1px 1px rgba(255, 255, 255, 0.9);
    color: rgba(0, 0, 0, 0.7);
    height: 16px;
  '#states div':
    slider-entity-row:
        ha-slider {
           height: 37px;
           border: 1px solid rgba(255, 255,255, 0.8);
           box-shadow: inset 3px 3px 10px 5px rgba(0,0,0, 0.1), inset -3px -3px 10px 5px rgba(255,255,255, 0.4);
           padding: 0px 12px 10px 2px;
           color: black;
           paper-progress-container-color: black;
           paper-progress-height: 1px;
           --paper-progress-container-color: rgba(0, 0, 0, 0.0);
           --paper-progress-height: 0px;
  slider-entity-row:
      ha-slider:
          '#sliderKnob': >
            .slider-knob {border-radius: 7px} .slider-knob {padding: 40px 40px
            0px 0px} .slider-knob {border: 1px solid rgba(100, 100,100, 0.4)}
            .slider-knob {background-color: rgba(255, 255,255, 0.9)}
            .slider-knob {width: 0px}    .slider-knob {height: 0px}
            .slider-knob {box-shadow: inset 2px 2px 2px 1px rgba(0,0,0, 0.05),
            inset -2px -2px 7px 1px rgba(255,255,255, 0.9)} .slider-knob-inner
            {border: 0px} .slider-knob-inner {background-color: rgba(0, 0,0,
            0.0)} .slider-knob-inner::after  {background-color: rgba(0, 0,0,
            0.0)} .slider-knob-inner::before  {background-color: rgba(0, 0,0,
            0.6)} .slider-knob-inner::before  {border: 0px)}
          paper-progress:
              #progressContainer {background-color: rgba(0, 0, 0, 0.0)}
              #primaryProgress {background-color: rgba(0, 0, 0, 0.0)}
Effect:
Can this be added as a resource directly from GitHub?
Example: https://raw.githubusercontent.com/thomasloven/lovelace-slider-entity-row/master/slider-entity-row.js
(I’ve tried and it doesn’t seem to work)
Wow.
I never thought of this, but you actually CAN do that!
You’ll need a mirror that sets the correct MIME-type, though.
Try https://cdn.jsdelivr.net/gh/thomasloven/lovelace-slider-entity-row/slider-entity-row.js instead.
I wouldn’t recommend it, for a variety of reasons, though. But it does work most of the time.
Thanks! Can you explain why it’s not recommended?
  • Latency
  • More things that can break, e.g. your internet connection, jsdelivr, github or anything in between.
  • Updates may be forced on you
  • Updates may not fall through correctly due to caching.
