You should be able to follow the github issue if you have a github account. If I were to take a guess it should be in 0.88. There is an interim workaround on github
Thanks Kellerza Iāll take a look at getting a github account.
Hi @monkey-house ! I have a sunny island 4.4m device ! I tried the above configuration you posted to integrate the device to HA but I am not able to read the values of the device. The values remains unknown. The errors that I get are āDuplicate SMA sensor key 6100_00465700ā. Is there something that I am missing ? Could you kindly help me out ?
ā¦I am having the same error (actually for three oy SMA sensors). But this does not prevent HA from receiving data. I recon to ignore this mistake and search for the errror someshere else on HA side since obviously the communication to the sma is working. Start with only one sensor (try all of them ) and then epand. Indents are super crtical in congf.yaml.
For me the SMA integration is one of the most stable now after a learning curve.
I also have a sunny island 4.4 with speedwire card energy meter and sunny home manager. I believe that the last part, the home manager is the issue. It only seems to send data to SMA servers.
I dislike SMAās current methods and will not be using them in the future.
Iāll add my question to this thread: Iāve got an SUNNY TRIPOWER 6.0 (https://www.sma.de/produkte/solar-wechselrichter/sunny-tripower-30-40-50-60.html) and am trying to get data into Homeassistant. This works half way though.
This is what the website of the inverter does display:
(Both DC inputs ([A] and [B]) are being used as you can see in the screenshot above)
I was able to find out the SMA sensor keys:
Using 6380_40251E00 will only return the first value (2.787W) to HomeAssistant. How can we retrieve the second one, too (730W)?
Thanks!
Could not start session, Session ID expected [result.sid], got {āresultā: {āsidā: None}}
I get this error, anyone suggestions?
Solved it SUNNY TRIPOWER 6.0 / Inputs [A] and [B] / Home Assistant Ā· Issue #20 Ā· kellerza/pysma Ā· GitHub
Did you get this to work?
Here is a way to get the data directly from the SMA Energy Meter or from the SMA Home Manager 2.0 by using Node Red. Why Node Red? It has all we need to intercept the udp multicast messages the Energy Meter sends out every second.
I assume a hass.io environment with installed Node-RED & Mosquitto broker Add-on
We use a function to extract data from the buffer containing the broadcast and feeding them via MQTT to HA.
- start a new Flow in Node-Red and call it SMA
- drag a āudp inā node (from the network section) on the canvas and configure it like this
sorry about the German localization in the pic. We need to receive multicast data from the ip 239.12.255.254 using port 9522 to be passed on in a buffer which btw. will contain 608 Bytes per message with the actual firmware of the SMA device.
see also here: http://www.eb-systeme.de/wp-content/uploads/2019/12/EMETER-Protokoll-TI-de-10.pdf
If you connect a debug node to the output of the udp node you should already see the 608 Bytes message coming in every second. If you donāt see any activity it might be that the device you are running Node-Red on is blocking udp multicast messages. This can be the case if you run your instance on a NAS System. It will work perfectly on a PI running HASS.io
- drag a function node to the canvas and connect the output from the udp node to the input of the function node.
- Configure the function node to have 4 outputs and add the following code
var count = context.get('count')||0;
count += 1;
IF you do not want to update HA every second you can set the fuction to pass
the data less often - see below
if (count < 30) { /* process data only every 30 seconds */
context.set('count',count);
return null;
count = 0;
var msg1 = { payload:"actual consumption" };
var msg2 = { payload:"actual gridfeed" };
var msg3 = { payload:"consumption counter" };
var msg4 = { payload:"gridfeed counter" };
/* to get the actual grid consumption in W we need the offset 0.1.4.0 */
offset = msg.payload.indexOf("00010400", 0, "hex")+ 4;
var consumption = parseInt((msg.payload[offset+0]*0x1000000 +
msg.payload[offset+1]*0x10000 +
msg.payload[offset+2]*0x100 +
msg.payload[offset+3]) / 10);
/* to get the actual grid consumption counter in Wh we need the offset 0.1.8.0 */
offset = msg.payload.indexOf("00010800", 0, "hex")+ 4;
var consumption_c = parseInt((msg.payload[offset+0]*0x100000000000000 +
msg.payload[offset+1]*0x1000000000000 +
msg.payload[offset+2]*0x10000000000 +
msg.payload[offset+3]*0x100000000 +
msg.payload[offset+4]*0x1000000 +
msg.payload[offset+5]*0x10000 +
msg.payload[offset+6]*0x100 +
msg.payload[offset+7]) / 3600);
/* to get the actual grid feed in W we need the offset 0.2.4.0 */
offset = msg.payload.indexOf("00020400", 0, "hex")+ 4;
var gridfeed = parseInt((msg.payload[offset+0]*0x1000000 +
/* to get the actual grid feed counter in Wh we need the offset 0.2.8.0 */
offset = msg.payload.indexOf("00020800", 0, "hex")+ 4;
var gridfeed_c = parseInt((msg.payload[offset+0]*0x100000000000000 +
if (consumption >= 0 && consumption < 100000 ) {
msg1.payload = consumption.toString();
} else msg1 = null;
if (consumption_c >= 0 && consumption_c < 50000000 ) {
msg2.payload = consumption_c.toString();
} else msg2 = null;
if (gridfeed >= 0 && gridfeed < 100000 ) {
msg3.payload = gridfeed.toString();
} else msg3 = null;
if (gridfeed_c >= 0 && gridfeed_c < 5000000 ) {
msg4.payload = gridfeed_c.toString();
} else msg4 = null;
return [msg1, msg2, msg3, msg4 ];
now the 4 outputs will push every 30s the following measurements:
output 1: actual grid consumption in W
output 2: grid consumption counter in Wh
output 3: actual grid feed in W
output 4: grid feed counter in Wh -
push this data back into HA using āMQTT outā nodes of your choosing.
define corresponding mqtt sensors in HA to retrieve the data
Hey,
could it be that the smartmeter sends only data when the inverter is on? I tried it right now, but I couldnāt see any message and right now the inverter is probably switched off since it is dark outside ā¦
I am referring to the SMA Energy Meter or the SMA Home Manager 2.0 which has a Energy Meter built-in. These devices measure the power consumption from the grid and the feed into the grid. If your inverter is inactive during the night you will still get power from the grid. It is therefore active 24/7.
There is an iOS app in the Appstore called āEnergy Meterā it finds your SMA Device and reports all details . Unfortunately it costs 3 bucks but it is worth the money in my opinion (I am not affiliated with the author).
I donāt know why but it was related to the fact that I had node-red running on my QNAP NAS. I configured the noodes but didnāt see the messages coming in. I then scanned the network with Wireshark and saw that the message are send even if the inverter is switched of - as you already stated. I tested it then with a spare Pi I had laying around. As soon as I deployed the nodes I saw the messages coming in. So I guess that my NAS is blocking this udp messages somehowā¦
Btw: which mdi icons are you using in HA?
Hi azrael,
glad that it worked for you. I added a comment in my description. I think the Synology NAS devices are also blocking the udp multicast messages.
and regarding the mdi icons have a look at mdi:counter and mdi:solar-power. Additionally if you also have data from your inverter about the solar power generation I recommend the power-wheel card. It is available via HACS and works really great
If you own a SMA Inverter this post might help you to get the the actual power generation and the counter out of the device directly in HA via the modbus integration.
Just set this up as a potential replacement for Modbus. Itās working great. Thanks for taking the time to share this.
Can you obtain other parameters via this method? Things that interest me include yield, yield counter, battery %, battery power, etc. Not sure how after looking at the debug packets⦠Any help would be welcome.
Hi monkey-house. The UDP multicast message contains data from the SMA Energy Meter. In this document page 4 Section 3.1 you get a list of the available data:
In my example I just used the first two entries.
To get data from your inverter like yield and yield counter use modbus. See this document page 28 Section 5.4.1 for the available data for SMA Inverters: http://files.sma.de/dl/2585/WEBBOX-MODBUS-TB-en-19.pdf
Thanks for chiming in. Iām already using modbus for yield, battery, etc. as such:
- platform: modbus
registers:
# SI
- name: Modbus SI Battery Charge
hub: 1
slave: 3
register: 30845
unit_of_measurement: '%'
precision: 1
count: 2
data_type: int
# # - name: Modbus SI Battery Voltage
# # hub: 1
# # slave: 3
# # register: 30851
# # unit_of_measurement: V''
# # scale: 0.01
# # precision: 1
# # count: 2
# # data_type: int
- name: Modbus SI Grid Frequency
hub: 1
slave: 3
register: 30803
unit_of_measurement: 'Hz'
scale: 0.01
precision: 2
count: 2
data_type: int
- name: Modbus SI Grid Voltage
hub: 1
slave: 3
register: 30783
unit_of_measurement: 'V'
scale: 0.01
precision: 1
count: 2
data_type: int
- name: Modbus SI Battery Charging
hub: 1
slave: 3
register: 31393
unit_of_measurement: 'W'
count: 2
data_type: int
- name: Modbus SI Battery Discharging
hub: 1
slave: 3
register: 31395
count: 2
data_type: int
# # - name: Modbus SI Load Power
# # slave: 3
# # register: 30861
# # unit_of_measurement: 'W'
# # count: 2
# # data_type: int
- name: Modbus SI Grid Today Raw
hub: 1
slave: 3
register: 30577
unit_of_measurement: 'kWh'
count: 2
scale: 0.001
precision: 3
data_type: int
- name: Modbus SB Daily Yield
hub: 2
slave: 3
register: 30517
count: 4
data_type: int
scale: 0.001
precision: 3
- name: Modbus SB Total Yield
hub: 2
slave: 3
register: 30513
count: 4
data_type: int
scale: 0.001
precision: 3
- name: Modbus SB PV Yield
hub: 2
slave: 3
register: 30775
count: 2
data_type: uint
- name: Modbus SB Grid Consumption
hub: 2
slave: 3
register: 30865
count: 2
data_type: uint
- name: Modbus SB Grid Feed
hub: 2
slave: 3
register: 30867
count: 2
data_type: uint
Iād love to get more frequent updates on some sensors (consumption, feed-in and yield amongst others), but do worry about overloading the inverter and battery charger. This is why Iām looking at this UDP path via the Home Manager 2ā¦
From the doc of the Energy Manager Protocol, the only other useful sensor I can find is:
32 1:32.4.0 ā Voltage
I just have no idea how to code for this sensor. Can you help?
to decode the voltage from Phase1 (Parameter 32.4.0) you can do it similar to the actual grid consumption 1.4.0 the offset is then 0.32.4.0 (in hex 00200400).
So add a 5. output and the code below
/* to get the actual Voltage of Phase1 we need the offset 0.32.4.0 note 32 = 0x20 in hex*/
offset = msg.payload.indexOf("00200400", 0, "hex")+ 4;
var voltage_p1 = parseInt((msg.payload[offset+0]*0x1000000 +
msg.payload[offset+3]) / 1000);
msg5.payload = voltage_p1.toString();
and of course add msg5 to the return statement at the end
return [msg1, msg2, msg3, msg4, msg5 ];
Wow, thank you so much. I will try today.
