Does the SMA Solar Integration work with the SMA Sunnyboy Inverter? If so how did you get it to work?
TIA, Jeff
TIA, Jeff
Yes it does.
It requires that your Inverter is connected to your network, either via wifi or Ethernet. You should also reserve it a static IP address in your routerās DHCP server.
Then just follow the documented configuration:
https://www.home-assistant.io/integrations/sma/#configuration
Thanks for your help.
I just had to get the user password from the installer.
Now what does everyone do with that information? Trying to come up with some idea as how to use it and not just display it.
If Iām producing a lot of extra solar power and it is either hot or cold inside I turn my reverse cycle heat pump on.
Good idea!
Now is there anybody else out there that does something with their solar integration?
New user here. Trying to add my SMA SunnyBoy 5.0 to HA.
I enter the IP address as Host and my password for user or installer
Iāve unchecked SSL since this older device doesnāt have SSL.
I get error āInvalid Authenticationā
From memory you do need to use SSL but you need it to not verify the certificate (the other option).
Have the exact same issue - Did you solve it and able to integrate your SMA SB 5.0 in HA ?
Still unsuccessfull from my side ā¦
Many thanks,
Itās been a while but for the records: Some SMA inverters neither have a web frontend to connect to, nor do they communicate modbus TCP or Speedwire (over Multicast). An example is the Sunny Boy 4000 (With green LC Display). These inverters cannot be integrated with the nice and stable SMA SOLAR integration provided by @emontnemery as those inverters are lacking a web server to poll. If your inverter is configured with the SUNNY EXPLORER application (as an idicator of legacy) you may need to use a physical RTU connection to ingest the legacy YASDI formatted data. See instructions here:
https://community.home-assistant.io/t/best-way-to-connect-sma-sb-4000tl-20-to-ha/390754
Does anybody know if this (or any other) integration will work with an SMA Windy Boy (5000) over RS485. The RS485 we can use as a virtual com port over IP if that helps.
RS485 is the only data comms mechanism available.
Another option might be an ESP8266 directly on the Windy Boy interface to MQTT but I canāt seem to find any information on the pinouts either.
Thank you in advance.
Chiming inā¦
I have a Sunny Tripower 5000TL-20 ⦠I donāt seem to be able to connect via the integration⦠message is always canāt connect⦠I tried with Cert, no Cert, User, Installer
Do I have to change any config parameter in the system?
I can read and receive data through the web access to www.sunnyportal.com⦠i.e. the access to my plant Web Interface
Any Hints?
PS: I canāt access the system though by entering the ip address directly in a browserā¦
e.g. 111.222.333.444 brings no connection (time out)
Good to read that Iām not alone. Same problem here.
I have Sunny Boy 5000TL-21 at which I attached a webconnect/speedwire module with ethernet.
I can ping the device, I can use it via Sunny Explorer and Sunny Portal, but it is refused with the Hass SMA addon and I canāt approach it directly via the browser either: connection time out.
Itās a mystery to me what it is Iām doing wrong or forgot to enable. The SMA documentation isnāt helpfull either.
So, I moved over to SBFspot over bluetooth. That works fine, but that feels silly when thereās a ethernet connection available. Besides, SBFspot requires HAOS-SBspot, MariaDB, Mosquitto MQTT broker, and phpMyAdmin. A lot of overhead, I think.
However, if anyone has a good idea to get the SMA add-on working, you would earn my gratitude!
Now I am in an even worse situation
I finally got someone to lend a windows pc (have only Macs) and installed Sunny Explorer.
Activated Modbus - because seemed the only wayā¦
And now the inverter is in NIRVANA ini 192.1168.0.XXX⦠so no tool can reach it???
I read that Config Assist van help but where the hell is the tool? no where can I find it?
Any hints PLEASE??
Same situation over hereā¦
I have acces to the info via the SMA energy IOS app, i got data in the homewizard- P1 meter app, I can acces it via the web portal
but Home Assistant doesnāt workā¦
I have the IP and tried to acces it with a browser ā no connection
When I use the windows app sunny explorer it can connect with that same ip address.
Anyone has a solution?
You must use the installer password. Hopefully they will give you their password
No, you donāt have to use the installer password! Select āUserā.
It was a bit of a struggle for me too, but this is what you have to do.
At host just give the ip addres, no http or https.
Select use SSL certificate, unselect Verify SSL certificate.
Group, select user. Then give your user password.
My problem was that I was unsure about my user password so I created a new one. For this you have to open a web browser and go to the inverters IP address. Select user and then forget password. Now you have to input your WPA2-PSK, this can be found on the sidepanel of your inverter.
Type this in and give a new password. After this, use this password for you integration. For me it worked. I have a SB3.0-1AV-41 manufacture 2020-11-27
This did it for me, thank you!
āAt host just give the ip addres, no http or https.
Group, select user. Then give your user password.ā
I did like you said, but it didnāt help.
I can acces the device with the IP in a browser, but when i put that IP in as Host and the rest you said. I still canāt connect. Anyone?
This is also important:
As is having a supported inverter. Which model are you trying to connect?
Until the v2025.1 update my integration worked fine.
I followed the setup an could connect to my Sunnyboy 4000. But since the v.2025.1 the integration doesnāt provide any info anymore. It canāt connect. I checked everything like IPs that setup as a static for my inverter. I didnāt change anything for years, and now this⦠any ideas what could be the problem?
