I run a SMA Tripower STP10.0-3SE-40 865 inverter and have it connected via modbus.
I would like to set up a logic which toggles a switch whenever I produce e.g. 3000W more than I use.
I have already managed to get the currently produced power (Register 30775) but I do not know where to find the total consumption or the grid feed.
Would be great if you could help me out!
See my yaml details below
Thanks,
Leiste
modbus:
- name: SMA
type: tcp
host: 192.168.2.33
port: 502
sensors:
- name: PV_Leistung
unit_of_measurement: W
slave: 3
address: 30775
data_type: int32
- name: PV_Tagesertrag
unit_of_measurement: kWh
slave: 3
address: 30517
scale: 0.001
precision: 3
data_type: uint64
- name: PV_Gesamtertrag
unit_of_measurement: MWh
slave: 3
address: 30513
scale: 0.000001
precision: 3
data_type: uint64
- name: Grid Voltage
unit_of_measurement: V
slave: 3
address: 30783
scale: 0.01
precision: 2
data_type: uint32
- name: Grid frequency
unit_of_measurement: Hz
slave: 3
address: 30803
scale: 0.01
precision: 2
data_type: uint32
- name: SMA_temp
unit_of_measurement: °C
slave: 3
address: 30953
scale: 0.1
precision: 1
data_type: int32
- name: SMA_status
slave: 3
address: 30201
data_type: uint32
- name: SMA_grid
slave: 3
address: 30217
data_type: uint32
- name: Insulation
slave: 3
address: 30225
scale: 0.001
unit_of_measurement: kOhms
data_type: uint32
- name: SMA_Residual_current
slave: 3
address: 31247
scale: 1
unit_of_measurement: mA
data_type: int32
- name: Apparent Power
unit_of_measurement: VA
slave: 3
address: 30813
scale: 1
precision: 0
data_type: int32
- name: Reactive Power
slave: 3
address: 30805
scale: 1
precision: 0
data_type: int32
