Smart Lighting: Your Lights, Your Way - Take Control and Customize it to Perfection!
Dynamic Lighting Update
We’ve listened to your feedback and made the Sun Elevation options truly dynamic.
Previously, Dynamic Lighting with sun elevation was locked to a fixed cutoff of -10°. This meant it couldn’t run below that hard-coded limit. Now, the system adapts to your input values instead of being restricted.
Dynamic Lighting will automatically use:
- Sun Elevation Rising - Start Point when the sun is rising
- Sun Elevation Descending - End Point when the sun is setting
This makes the feature fully flexible. Want Dynamic Lighting to run down to -30°? Just enter it in your input, and it works… no extra setup or new options required.
If you like this blueprint? Consider hitting the
button in the top post ![]()
If you like my blueprints, and would like to show your support or just say thank you? Click Here ![]()
Enjoy
Blacky ![]()
