🔆 Smart Light - Entity - Sun Elevation - Ambient & Time Triggers
GitHub Link Click Here
Smart Lighting: Your Lights, Your Way - Take Control and Customize it to Perfection! :bulb: :sparkles:
Like this blueprint? Consider hitting the :heart: button below :+1:
Version: 3.6 :fire:
Need help? :eyes: See our FAQ: Click Here
:newspaper: The Automation Process:
  • Trigger Options:
    • Activate lights, switches, scenes, and scripts when the automation is triggered.
  • Entity State:
    • Turn lights ON when an entity changes from OFF to ON.
    • Turn lights OFF when an entity changes from ON to OFF.
  • Press Button:
    • Turn lights ON when you press a button.
    • Turn lights OFF when you press a button.
  • Sun Elevation:
    • Turn lights ON when the sun’s elevation falls below a set value.
    • Turn lights OFF when the sun’s elevation rises above a set value.
  • Ambient Light:
    • Turn lights ON when ambient light falls below a set LUX value.
    • Turn lights OFF when ambient light rises above a set LUX value.
  • Time-Based Option:
    • Define start and end times to turn lights ON and OFF.
  • Light Control Options:
    • Utilize “Light Control” to adjust brightness, colour temperature, colour, and transition times.
  • Dynamic Lighting Options:
    • Opt for ‘Dynamic Lighting’ to automatically adjust brightness based on lux values, and/or adjust brightness and colour temperature according to the sun’s position or the time of day.
    • Opt to use the ‘State Control Option,’ allowing you to toggle between dynamic lighting and normal lighting based on the entity’s activation state.
  • Night Lights Mode:
    • Enable ‘Night Lights’ for softer illumination during night time activities, automatically enabled based on conditions.
  • Manual Override:
    • Use “Bypass Options” for manual bypassing of trigger sensors, providing manual control and additional customization.
  • Weekdays Condition Option:
    • Specify the weekday selections to define when the automation can run.
:rocket: CHANGELOG
  • Version: 3.6 - 12 Aug-26 - Added 3 new options to dynamic lighting and fixed some DL bugs.
  • Version: 3.5 - 22 Feb-26 - Added ambient low and high time delay. Fixed possible error log when using ambient trigger and restarting HA.
  • Version: 3.4 - 1 Feb-26 - Fixed bug related to time trigger.
  • Version: 3.3 - 21 Sep-25 - Dynamic Lighting with sun elevation removed fixed cutoff of -10°.
  • Version: 3.2 - 27 Aug-25 - Added an option to use a button as the trigger.
  • Version: 3.1 - 22 Aug-25 - Added an option to enable or disable the HA restart safeguard option.
  • Version: 3.0 - 19 May-25 - Fixed bug related to Dynamic Lighting lux controlled options.
  • Version: 2.9 - 25 April-25 - Fixed bugs related to Dynamic Lighting and some maintenance items.
  • Version: 2.8 - 25 Jan-25 - Fixed bug that would still turn OFF lights when weekday was disabled.
  • Version: 2.7 - 19 Jan-25 - Added ‘State Control Option’ and next-day time settings to dynamic lighting. Fixed bugs related to RAM usage and bypass resets.
  • Version: 2.6 - 16 Jan-25 - A bug affecting dynamic lighting options 10, 11, 12, and 13 has been fixed.
  • Version: 2.5 - 7 Jan-25 - Added 4 new time controlled options to dynamic lighting. Bug fixes.
  • Version: 2.4 - 14 Dec-24 - Added time delay to night lights crossover to normal lights. Update to Home Assistant YAML standards and coding practices.
  • Version: 2.3 - 1 Sep-24 - Fixed bugs in sun elevation and bypass.
  • Version: 2.2 - 12 Aug-24 - Added new option for dynamic lighting.
  • Version: 2.1 - 1 Aug-24 - This is not just an upgrade; it’s a complete transformation all-new :high_brightness: Smart Light blueprint!
  • Version: 2.0 - 26 May-24 - Update to description to show labels are excluded.
  • Version: 1.9 - 26 May-24 - Fixed a bug in sun options. Sun Elevation Rising would not turn entities OFF.
  • Version: 1.8 - 5 May-24 - Update light control to include colour temperature & transition. Sun option has falling and rising set values & update to new layout.
  • Version: 1.7 - 14 Oct-23 - Update ambient option to have ON and OFF value.
  • Version: 1.6 - 6 Oct-23 - Update binary sensor to entity state. Added option to add any global condition.
  • Version: 1.5 - 21 Sep-23 - Update deprecated code.
  • Version: 1.4 - 28 March-28 - Select any entity you like.
  • Version: 1.3 - 13 March-23 - Update typo in variables.
  • Version: 1.2 - 31 Jan-23 - Made weekdays a global option.
  • Version: 1.1 - 30 Jan-23 - Fixed time trigger.
  • Version: 1.0 - 30 Jan-23 - Initial release.
:shield: MY OTHER BLUEPRINTS
:bulb: Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time
:infinity: Sensor Light Add On - Media & Movie Lights - House Alarm Lights - Smoke Alarm Lights & Exhaust Fans + More
:airplane: Holiday & Away Lighting
:shower: Bathroom Humidity Exhaust Fan
:low_battery: Low Battery Notifications & Actions
:vibration_mode: Appliance Notifications & Actions - Washing Machine - Clothes Dryer - Dish Washer - ETC
:loudspeaker: Notifications & Announcements
:calendar: Calendar Notifications & Actions
:round_pushpin: State Notifications & Actions
:battery: Battery Charger Notifications & Actions
:puzzle_piece: ESPHome Device Update
:blue_book: Blueprint Update Notifications
:stop_button: Manual Control Status Tracker
:globe_with_meridians: Zone Presence of People & Devices
:honeybee: Bee In The Hive Sensor
:robot: Android Notification Channel Manager
:toilet: Toilet Exhaust Fan with time delay
:hourglass_flowing_sand: Entity - Run ON Timer
:stopwatch: Trigger - Run ON Timer
:magic_wand: Manual light control with auto OFF
:door: Closet, Pantry, and Cupboard Lighting
:timer_clock: Timer
:thermometer: Temperature Control Fan
:snowflake: Temperature Control Exhaust Fan - Inverted
:eight_spoked_asterisk: Toggle Switch - Turn ON & OFF Entities
:nazar_amulet: Press Button - Turn ON & OFF Entities
:on: Switch - Turn ON & OFF Entities
đŸȘ« Low Battery Notifications & Actions
:magic_wand: Manual Light Control With Auto OFF
:timer_clock: Timer
📱 Notifications & Announcements
:thermometer: Temperature Control Fan + Ceiling Fan Mode
đŸšȘ Closet, Pantry, and Cupboard Lighting
Simple schedule On/Off Lights
:bulb: Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time - Light Control - Device Tracker - Night Lights
Cover Control Automation (CCA) - Intelligent Automation for Blinds, Awnings & Shutters | Calendar, Sun Shading, Force Functions
:timer_clock: Timer
Q: How do I use the triggers?
A: Please Click Here
Q: What are the primary differences between the Smart Light and Sensor Light Blueprints?
Q: Why did you choose sun elevation as the sun option and not sunrise and sunset.
Q: I would like to set a different value but the slider is not letting me?
A Just simply type the number value you would like in the field and click save. A red line will appear under the number you have entered but once you click save, exit the automation and go back into it the red line will not be there.
New update 1.2
  • Fixed time trigger
  • Made weekdays a global option for all trigger conditions.
Enjoy
Blacky :grinning:
This is looking great after a first quick glance, thanks for sharing!
I will test this tonight in combination with an existing automation that turns a night light on permanently between sunset and midnight.
Cheers,
Uwe
Thanks for your kind words.
Please make sure you update to V1.2 if you haven’t already. As I just fixed the time triggers just for what you are trying to do.
Edit: Tip, your settings for this would be the sun condition and the time would be, “On Time” could be any time between sunset and just before midnight (say 11:30 PM) and “Off Time” would be midnight.
That was fast. Even with time travel! Or are you in a time zone where it’s already Jan. 31st? :wink:
Just discovered your earlier “Sensor Light” blueprint and might switch over to this one, though. Still the same use case, but involving a motion sensor, so that looks more suitable to me.
Yep, already 31st. :+1:
Can you add Numeric state aswell of an entity?
IE - condition: numeric_Stare
entity_id:
above:
below:
@cbothma Hi Christoff
Could you give me your use case?
Help.
I’m new to HA and for the life of me i can’t get the on and off times to work.
I have the trigger as a light sensor but only want it to trigger between 9-5 if it gets too dark in the house for the plants. But it seems to trigger randomly outside of these times.
Hi @Stevie , firstly welcome to the community :+1:.
This automation works when it passes through or over the trigger condition. So if you have a light sensor every time it passes over the set point it will turn the light ON and or OFF. If you have also set the time trigger then every time it passes over the set time it will turn ON and or OFF. The only global condition is weekdays.
The automation was developed as a lot of people just wanted a simple ON / OFF for a light with time. I added extra options to choose from when developing it if time was not your thing, like LUX, sun & binary sensor. You can choose weekday as a global setting so it could be used in a office environment were Monday to Friday you need the lights ON and OFF. Example: If using time option set the time to turn the lights ON at 8 am and OFF at 6 pm Monday to Friday.
Normally you would choose just one option.
So for what your trying to do, this automation will not work.
This works fantastic, really appreciate the blueprint!! I might tweak it to add the ability to control entities (door locks, garage etc) so I can have schedules like lock the door, shut the garage and turn off all the lights at a set time and unlock the doors and turn on lights in the morning. That would basically make this an all in one starter for any automation, really.
@jclendineng
Hi Joel, I will do an update to include any entity you like. Just update to Version: 1.4 and you will be good to go.
New update 1.4
  • You can now select any entity you like to turn ON and OFF not just lights, switches or scenes.
Enjoy
Blacky :grinning:
Hello, thanks for the script and the continued support!
I have played around with both the time for it to be active and the sun position, but it appears the light will turn on regardless of the time of day, instead of only when i am trying to define it. unless i am drastically misinterpreting it
which from an earlier post: The automation was developed as a lot of people just wanted a simple ON / OFF for a light with time. I added extra options to choose from when developing it if time was not your thing, like LUX, sun & binary sensor. You can choose weekday as a global setting so it could be used in a office environment were Monday to Friday you need the lights ON and OFF. Example: If using time option set the time to turn the lights ON at 8 am and OFF at 6 pm Monday to Friday.
It looks like it might not do what i was hoping (basically when a event in frigate is logged to turn on a light) I only want to turn on a light if a person is seen, not the millions of bugs in florida :slight_smile:
@mykpoz
Hi Michael, firstly welcome to the community.
This blueprint works with the actual trigger points (crosses over your setting). Example
You mentioned time and sun.
When the sun drops below the sun elevation or the “ON time” it will turn the light ON. If you enabled the option.
When the sun rises above the sun elevation or the “Off Time” it will turn the light OFF at that point. It is not a condition to only work when the sun is below the sun elevation.
It is the same for “Binary Sensor” and “Ambient Light Sensor”.
So the sun could turn the light ON when it goes below the sun elevation and then the time can turn it off. Example if you let the sun turn it ON and then you would like it off at 11:30pm you would set the sun elevation at say -1.5 and the light would come ON when it passes over this setting. Then if you would like it OFF at 11:30pm you would use the time and set the ON time to 11:29pm (the light is already ON so nothing changes) and the off time to 11:30pm. Light turns OFF. When the sun goes above the sun elevation it will turn it OFF but it is already OFF so nothing happens.
What I think your after is for the light to only come ON when it is dark or below the sun elevation. For this you would need to use my other blueprint called :bulb: Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time.
This is tricky
 but if you have a CCTV camera that can detect humans and then send triggers for this and not the millions of bugs you have in florida it should work with my other blueprint.
Hope the helps you.
Blacky :smiley:
It is actually working pretty much as I want now. :+1:
I would like to see a timer option for switching off lights. Now it needs two?? automations that might interfere as I see it but please correct me if I am wrong.
I want to use it with a ‘presence sensor group’ switch light groups on but when no occupancy it should switch of after X time.
Hi Stevie, that is good news :+1:
@zebrahosting
I think you may be after my other blueprint. Have a look at this one.
