I hope to be in the right place here.
I have a problem using an entity on Zigbee smart plugs. It is some “Tuya zigbee smart plug” from Aliexpress.
I use Tube’s ZB coordinator and Zigbee Home Automation in HAOS.
All entities are updating fine excepting one : “smartenergy_metering_summation_delivered” on both of my smart plugs.
This entity value only updates when I restart HA.
Each “step” is a HA restart.
But “live” power usage is fine.
I don’t really know which information can I bring to help on this “bug”, or how can I resolve it myself.
Here are “Zigbee information” of this plug :
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x010a",
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0702",
"0x0b04",
"0xe000",
"0xe001"
"out_clusters": [
"0x000a",
"0x0019"
"manufacturer": "_TZ3000_gjnozsaz",
"model": "TS011F",
"class": "zhaquirks.tuya.ts011f_plug.Plug"
Thank you a lot for helping.
Flo
