Smart Sump Pump Monitor with ESPHome & Home Assistant
I recently finished a sump pump monitoring project using ESPHome and Home Assistant, and wanted to share the setup and lessons learned in case it helps others designing something similar.
Goals
I wanted a solution that:
  • Tells me where the water level is, not just “dry” or “already flooded”
  • Complements my Aqara leak sensor
  • Counts how many times the pump actually drains
  • Uses simple, reliable, waterproof hardware
Hardware
  • Wemos D1 Mini
  • 2 LEDs
  • Lower float: mounted just below the pump’s normal trigger point
  • Upper float: mounted well above normal high water as an overflow warning
  • Floats mounted to the discharge pipe using 3D-printed brackets and zip ties
  • Simple wiring: GPIO → float → GND (INPUT_PULLUP)
Wiring:
Home Assistant
Dashboard Design
:green_circle: Drained – both floats OFF
:yellow_circle: High – lower float ON
:red_circle: Overflow – upper float ON
:1234: Drain Cycles – counter with double-tap reset
Derived “Drained” State (Green Indicator)
To get a clean “pump just ran / pit is empty” indicator, I added a Template Binary Sensor helper via the UI:
{{ is_state('binary_sensor.sump_pump_sump_rising', 'off')
and is_state('binary_sensor.sump_pump_sump_overflow_risk', 'off') }}
ON → pit drained (green)
OFF → water at or above a float
Esphome config:
captive_portal:
output:
  - platform: gpio
    pin: GPIO13   # D7
  - platform: gpio
    pin: GPIO4
  - platform: gpio
    pin: GPIO5    # D1
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO14 #D5
      mode: INPUT_PULLUP
      inverted: false
    filters:
      - delayed_on: 200ms
      - delayed_off: 500ms
    on_press:
      - output.turn_on: yellow_led
    on_release:
      - output.turn_off: yellow_led
  - platform: gpio
    name: "Sump Overflow Risk"
    pin:
      number: GPIO12 #D6
      mode: INPUT_PULLUP
      inverted: false
    filters:
      - delayed_on: 200ms
    on_press:
      - output.turn_on: red_led
    on_release:
      - output.turn_off: red_led
  - platform: status
    name: "Sump Pump Online"
Helpers
Drained Template:
Automations
#Increments the counter every time the lower sensor is on (closed).
alias: Sump pump-  Increment drain cycles
description: ""
triggers:
  - entity_id:
      - binary_sensor.sump_pump_sump_rising
    to:
      - "off"
    trigger: state
      - "on"
actions:
  - action: counter.increment
    data: {}
      entity_id: counter.sump_drain_cycles
mode: single
#High water phone notification
alias: Sump Pump – High Water Alert
mode: single
  - platform: state
    entity_id: binary_sensor.sump_pump_sump_rising
    to: "on"
    for: "00:00:10"
  - service: notify.mobile_app_xxxxx_s_s22
      title: "Sump Pump Alert"
      message: "Water reached the high-water float. Check the sump pit."
        priority: high
        ttl: 0
This setup has gives me more confidence in the sump system than a single “water detected” sensor does.
If you have any ideas on how to improve it or questions, feel free to ask any questions.
@nateokane , thank you for sharing your project. I installed a simple sensor in the sump a few years ago. It’s based on an WSP8266 but only uses one float. I like your idea of two floats and will be upgrading my Sump Monitor before winter thaw and spring rains start in March.
Everything looks cool for the most part but, if i may make a few recommendations do you??
First thing is I personally would’ve used a single double float switch sensor instead of using 2 individual ones juat for convenience and installation ease. They make these stainless steel double float sensors and ive had a couple in use for a while now and i like them personally FWIW. These double float sensors for if you want a High and a Low level, they come in all sorts of different lengths too.
Double float
Sedond thing is Im not really sure if id agree with needing or use myself and that’s your counter for drain cycles and im not even sure what its purpose is other than just a counter. I would have instead chosen a flow meter and installed it in the outflow hose/pipe and that would give you more useful data because just knowing the pump cycled On/Off and how many times, it doesnt tell you if its still working correctly or potentially if a float sensor is sticking and causing excessive pump cycles or potentially if theres excessive water leaking and that’s the cause for the number of pump cycles. Idk if that makes sense, all im trying to say is as it is currently, the counter isnt able to tell you much useful information based on just an On/Off counter essentially. If you inatead used a flow meter then you could monitor for anything out of the norm, how much water is entering the sump and how quickly and then obviously you can totul up the amount of water being pumped out. Hell, you could even still make a counter from the flow meter based on when water starts/stops flowing through the meter which is the same as what you’re doing now basically.
Another idea/suggestion id suggest that you consider and thats adding some type of audible alert to draw attention in the event things arent working right or for example your pump doesnt turn off for some reason and theres basically no water in there to pump which will eventually burn out that pump. There are lots of examples i could think of too but, you just dont want to eventually find out something failed and youve got 2’ of standing water in your basement as an example… Something I did for my water heater is if any leak sensors get triggered and i fail to respond in HA that i acknowledge theres a leak then it will move onto flsshing red lights in rooms that have smart lights in an effort to get anyones attention and signal theres a problem but, you could lights, audible siren, or ise both as an alert if you wanted.
The last thing id say is the biggest one and an important one. My question first is, why in the loving hell did you use Esphome to create all of your controls and sensor entities and then go over to HA and say, "im gonna go whack and seperate the main device w/controls and sensors and put all the logic/automations in a completely seperate place that adds no benefit and does add lots of potential for failure and reliability issues. By doing that you’ve made it so that if either of the two, wifi or Homeassistant goes down then so does your sump pumps ability to follow your automations/instructions and maybe even do absolutely no pumping even if it desperately needs pumped out but, that depends more on your pump and if you left the built-in float switch inside and didn’t disable it from turning on automatically.
FYI you always want to keep your esphome projects/entities together with the logic/automations that control the esp board projects so that they are even more dependable than HA is and will remain working without internet, local wifi, and HA. Even at the very worst case scenario, you can always access a built-in web-based AP to access controls/sensors, data etc.
Please make your old buddy proud and make those automations using esphome and flash the board again!
Thanks for the thoughtful feedback — I appreciate you taking the time to look through the design and share your experience.
For this build, I intentionally kept the hardware simple and focused on reliable water-level state rather than flow analytics. The drain-cycle counter is meant to confirm successful water removal, not pump performance. Ultimately, I want to know the water level went down, not necessarily how quickly it drained although I could probably create a heuristic for that given how quickly it is filling.
I chose two floats since they have individual failure modes and was a little easier for me to mount on a pipe.
On the ESPHome vs HA split: The pump remains fully autonomous on its internal float, so there’s no pump logic dependent on Wi-Fi or Home Assistant. These sensors are only monitoring water level for sensing purposes, but agree that automating the actual pump would be pretty nuts.
I do like the idea of adding additional alerting (audible/visual) as a future enhancement. That is why I included a phone notification, but it wouldn’t hurt incase I don’t have my phone — good suggestion.
Thanks again for the input!
Where did you get the switch?
On the ESP, why not set a timer when the “full” switch is on to set off an alarm if the sump isn’t draining? (That’s my current plan). If I know it takes five seconds to drain the sump, and ten seconds elapsed and no “empty” condition, then something is wrong.
I had an episode last January when the temperature was in single-digits. The pump discharge froze and blocked any water from leaving. Such an alarm would have notified me long before my wife went to the basement to get dinner from the freezer.
Alternately, watch how long the pump motor runs.
I bought ones identical to the ones below. I don’t remember where exactly I bought them since this is a long time planned project.
Ali Express Link
I never thought of a frozen discharge lines before, but I could total see how that could happen since the water above the check valve is still.
I don’t have a way to detect if the pump is running an theoretically it could stay at the lower float for quite some time if it didn’t accumulate more water. Not having a lower float or a motor sensor is a limitation, but I didn’t want to keep the float submerged and also didn’t want to reach that far down into the pit lol. Lastly, that is what the upper float is for. Theoretically the upper float should NEVER trigger unless there is a big problem.
Appreciate the insight!
Smart switch with power monitoring.
I’m embarrassed I didn’t think of that lol… I was thinking about CT clamps from the ESPHome device which is way more complicated.
I have a bunch of these ‘Thirdreality ZigBee Smart Plug 4 Pack with Real-time Energy Monitoring’. I plan to cut one open to short out the relay contacts to turn it into a power monitor-only device. The relays in these and other smart switches are not rated for inductive loads, and the sump is one place that a relay failure would be bad.
I tried this with the YoLink smart plug that measures “Current”, but like you said the inrush amperage from the pump coming on was too much for it. It didn’t damage it, but also didn’t work. and repurposed it for a washer cycle done notification.
I went back to my longer term solution of using a Functional Devices RIB power sensor (RIB 1 21AJ46) around the hot to the pump. That does take some light electrical work to install. It provides dry contacts when adjusted for the sump pump. I use a YoLink contact sensor to get that out HA but have to believe ESP offers that as well. No batteries or maint for the RIB
That works very reliably to provide not only On/Off but also cycle time. I used high school geometry to measure the volume of my cylindrical sump, subtracted the volume of the pump so can use daily cycles to calc gallons pumped out each day / month in notifications.
https://www.functionaldevices.com/category/RIB-Current-Sensor-Products
Thanks for the reminder- I have a clamp-on current sensor from another project that never finished…
Well… That’s why everyone always calls me a genius! Well, at least they do in my dreams but, im working on convincing them! ; )
Its always a good idea to add/include backups for as much as possible or else the whole automation is basically a Fail if everything works other than the Action that sends you a SMS message.
Hi. Would you be willing to share the STL or a link? Thanks!
It took a little longer than I’d hoped, but my version of a sump pump monitor is finally up and running! I’ve finished the code and the build using the great advice shared here. Thanks so much to everyone who chimed in—I really appreciate the insight.
Following is a schematic, code for an ESP8266, code for a dashboard and a build and user manual.
ESP8266 - Sump Pump High Water Level Warning With Flow Monitor
substitutions:
  software_version: "2026.04.12.V118"
  devicename: sump-water-level-flow-monitor
  friendly_devicename: "Sump Water Level Monitor with Flow Detection"
  esphome_project_name: "robert.sump_monitor_with_flow"
globals:
  - id: cycle_start_time
    type: uint32_t
    initial_value: '0'
  - id: cycle_start_volume
    type: float
    initial_value: '0.0'
esphome:
  friendly_name: ${friendly_devicename}
  comment: "Sump Well High Water Level Monitor"
  project:
  on_boot:
    priority: -10
    then:
      - output.turn_on: led_power
      - output.turn_on: buzzer_output      # <-- Test the buzzer
      - delay: 100ms                       # <-- Wait 1/10th of a second
      - output.turn_off: buzzer_output
      # CRITICAL BOOT SYNC: Check if basement is already flooded when power returns
      - if:
          condition:
            binary_sensor.is_on: high_water_switch
          then:
            - output.turn_on: led_high_water
            - script.execute: high_water_alarm
esp8266:
  board: d1_mini
wifi:
  ssid: !secret wifi_ssid
  min_auth_mode: WPA2
  reboot_timeout: 15min    # <-- Auto-heals dropped connections
  ap:
    ssid: "Sump-Monitor-Fallback-With-Flow"
    password: !secret wifi_ap_password
captive_portal:
logger:
  level: DEBUG
  logs:
    pulse_counter: INFO
api:
  encryption:
    key: !secret api_encryption
ota:
  platform: esphome
  password: !secret ota_password
web_server:
  port: 80
time:
  - platform: homeassistant
# OUTPUTS (Grouped on Right Side of PCB)
output:
  - platform: gpio
    pin: D0
    id: led_power # WHITE LED - Power
  - platform: gpio
    pin:
      number: D5
      inverted: true
    id: buzzer_output # ACTIVE BUZZER
  - platform: gpio
    pin: TX
    id: led_mute # YELLOW LED - Mute Status
  - platform: gpio
    pin: D6
    id: led_high_water # RED LED - High Water
  - platform: gpio
    pin: D7
    id: led_pump_running # GREEN LED - Flow Active
# WIFI STATUS INDICATOR (Right Side)
status_led:
  pin:
    number: D8 # BLUE LED (Boot Safe - Pulls LOW)
    inverted: true
# DASHBOARD & LOGIC
switch:
    name: "Mute Sump Alarm"
    icon: "mdi:volume-off"
    optimistic: true
    restore_mode: ALWAYS_OFF
    on_turn_on:
      then:
        - if:
            condition:
              binary_sensor.is_on: high_water_switch  # <-- Checks if there is an actual emergency
            then:
              - script.execute: flash_mute_led
              - script.execute: mute_timeout
            else:
              - switch.turn_off: mute_alarm           # <-- Instantly turns back OFF if pressed by mistake
    on_turn_off:
      then:
        - script.stop: mute_timeout
        - script.stop: flash_mute_led
        - output.turn_off: led_mute
script:
  - id: high_water_alarm
    mode: restart
    then:
      - while:
          condition:
          then:
            - if:
                condition:
                  switch.is_off: mute_alarm
                then:
                  - delay: 1s
                  - delay: 2s
                else:
                  - delay: 3s
  - id: flash_mute_led
    mode: restart
    then:
      - while:
          condition:
            switch.is_on: mute_alarm
          then:
            - output.turn_on: led_mute
            - delay: 1s
            - delay: 1s
  - id: mute_timeout
    mode: restart
    then:
      - delay: 15min
# SENSORS (Flow and Volume) - DOES NOT SEND MESSAGES WHEN FLOW IS 0.0
  - platform: pulse_counter
    pin:
      number: D2
      mode: INPUT_PULLUP
    name: "Sump Flow Rate"
    unit_of_measurement: "L/min"
    icon: "mdi:water-pump"
    update_interval: 500ms                 # <-- CHANGED: Now updates twice a second for faster response
    filters:
      - multiply: 0.033333
      # 1. THE GATEKEEPER & DEADZONE
      - lambda: |-
          // If the low water float is DOWN (pit empty), flow must be 0
          if (id(low_water_switch).state) {
            return 0.0;
          // If the float is UP, but flow is tiny, ignore the electrical noise
          if (x < 0.5) {                   // <-- CHANGED: Lowered deadzone to instantly match trigger threshold
            return 0.0;
          return x;
      # 2. THE PAUSE (Only output when the value changes)
      - delta: 0.001
  - platform: integration
    name: "Total Sump Volume Discharged"
    sensor: flow_rate
    time_unit: min
    unit_of_measurement: "L"
    icon: "mdi:chart-waterfall"
  # Diagnostic Sensors
  - platform: wifi_signal
    name: "WiFi Signal Strength"
    update_interval: 60s
  - platform: uptime
    name: "Last Cycle Average Flow Rate"
    icon: "mdi:chart-bell-curve-cumulative"
    update_interval: never
# BINARY SENSORS (Inputs)
binary_sensor:
# Physical Mute Button
  - platform: gpio
    pin:
      number: D3
      mode: INPUT_PULLUP
      inverted: true
    name: "Physical Mute Button"
    on_press:
      then:
        - if:
            condition:
              binary_sensor.is_on: high_water_switch  # <-- Only allows toggling if water is HIGH
            then:
              - switch.toggle: mute_alarm
  # Low Water Float (Moved to Left Side)
  - platform: gpio
    pin:
      number: D1  # MOVED FROM D7
      mode: INPUT_PULLUP
      inverted: true
    name: "Low Water Switch"
    filters:
      - delayed_on: 500ms
  # High Water Float
  - platform: gpio
    pin:
      number: RX
      mode: INPUT_PULLUP
      inverted: true
    name: "High Water Switch"
    filters:
      - delayed_on: 500ms
    on_press:
      then:
    on_release:
      then:
        - output.turn_off: led_high_water
        - script.stop: high_water_alarm
  # Pump Running Trigger
    name: "Pump Running Trigger"
    lambda: |-
      return id(flow_rate).state > 0.5;
    filters:
      - delayed_off: 2s
    on_press:
      then:
        - output.turn_on: led_pump_running
        # START THE STOPWATCH
        - lambda: |-
            id(cycle_start_time) = millis();
            id(cycle_start_volume) = id(total_sump_volume).state;
    on_release:
      then:
        - output.turn_off: led_pump_running
        # STOP THE WATCH & DO THE MATH
        - lambda: |-
            float duration_min = (millis() - id(cycle_start_time)) / 60000.0;
            float volume_pumped = id(total_sump_volume).state - id(cycle_start_volume);
            // Prevent dividing by zero, then calculate and publish the average
            if (duration_min > 0) {
              float avg_flow = volume_pumped / duration_min;
              id(last_cycle_average_flow).publish_state(avg_flow);
  # Failsafe Logic (Restored!)
    name: "Float Sensor Fault Alert"
    device_class: problem
    lambda: |-
      return id(high_water_switch).state && !id(low_water_switch).state;
Dashboard Code
type: vertical-stack
cards:
  - type: markdown
    content: >
      # Sump Status:  {% if
      is_state('binary_sensor.sump_water_level_monitor_with_flow_detection_high_water_switch',
      'on') %}
        <font color="red">**⚠️ CRITICAL: HIGH WATER**</font>
      {% elif
      is_state('binary_sensor.sump_water_level_monitor_with_flow_detection_pump_running_trigger',
      'on') %}
        <font color="yellow">**⚡ ACTIVE: Pumping Water**</font>
      {% else %}
        <font color="green">**✅ NORMAL: All Systems Clear**</font>
      {% endif %}
      **Last Pump Activity:** {{
      as_timestamp(states.binary_sensor.sump_water_level_monitor_with_flow_detection_pump_running_trigger.last_changed)
      | timestamp_custom('%Y-%m-%d %H:%M') }}
  - type: horizontal-stack
    cards:
      - type: entity
        entity: >-
        state_color: true
        icon: mdi:waves-arrow-up
      - type: entity
        entity: >-
        state_color: true
        icon: mdi:water-pump
  - type: gauge
    entity: sensor.sump_water_level_monitor_with_flow_detection_sump_flow_rate
    name: Current Flow Rate
    min: 0
    max: 150
    needle: true
    severity:
      green: 1
      yellow: 0
      red: 120
  - type: entities
    title: Sump Statistics
    entities:
      - entity: >-
          sensor.sump_water_level_monitor_with_flow_detection_monthly_sump_discharge
        name: Monthly Volume Discharged
        icon: mdi:chart-waterfall
  - type: entities
    title: Controls & Failsafes
    state_color: true
    show_header_toggle: false
    entities:
      - entity: switch.sump_water_level_monitor_with_flow_detection_mute_sump_alarm
        name: Mute Audible Buzzer (15m)
        icon: mdi:volume-off
      - entity: >-
          binary_sensor.sump_water_level_monitor_with_flow_detection_low_water_switch
        name: Low Water Level (Pit Empty)
        icon: mdi:waves-arrow-down
      - entity: >-
          binary_sensor.sump_water_level_monitor_with_flow_detection_float_sensor_fault_alert
        name: Sensor Logic Check
        icon: mdi:sync-alert
  - type: history-graph
    entities:
      - entity: sensor.sump_water_level_monitor_with_flow_detection_sump_flow_rate
    hours_to_show: 24
    title: 24-Hour Pump Activity
  - type: entities
    title: System Diagnostics
    state_color: true
    entities:
      - entity: >-
          sensor.sump_water_level_monitor_with_flow_detection_wifi_signal_strength
      - entity: sensor.sump_water_level_monitor_with_flow_detection_system_uptime
Dashboard View
Installation - Shows completed monitor and flow meter
Build and User Manual
Software Version: 2026.04.12.V118
Hardware: Wemos D1 Mini (ESP8266)
Integration: Home Assistant / ESPHome
The Sump Water Level Monitor with Flow Detection (V118) is a custom-engineered, ESP8266-based failsafe device. It continuously monitors the water level and discharge volume of a residential sump pit. It features local visual and audible alarms, dual physical fail-safes, and deep integration with Home Assistant for remote telemetry and alerts.
:hammer_and_wrench: Parts List & Hardware
Microcontroller & Core Components
  • 1x Wemos D1 Mini (ESP8266): The core processor running the ESPHome firmware.
  • 1x 5V Power Supply: Micro-USB or direct 5V pin power for the D1 Mini.
  • 1x PCB or Breadboard: For mounting and wiring the components securely.
  • Connecting Wires: Jumper wires or permanent solid core/stranded wire.
Sensors & Inputs
  • 2x Liquid Level Float Switches: Mechanical or optical; triggers LOW (Ground). Used for High/Low water detection.
  • 1x Hall Effect Flow Sensor: Pulse-based sensor (e.g., Gredia G1-1/2" or YF-S201) to measure water discharge.
  • 1x Push Button: Momentary, normally open button for the physical Mute switch.
Outputs & Indicators
  • 1x Active Buzzer Module: Must trigger on a LOW signal (the code uses inverted logic).
  • 5x Standard LEDs (5mm/3mm): 1x White, 1x Yellow, 1x Red, 1x Green, 1x Blue.
  • 5x Current Limiting Resistors: 1x 22Ω (Blue), 3x 120Ω (White, Yellow, Green), 1x 150Ω (Red).
:building_construction: Build Instructions
Important Note on Inputs: All input pins (D1, D2, D3, RX) use INPUT_PULLUP and are inverted in the code. This means the switches and buttons should be wired directly between the specified GPIO pin and Ground (GND). No external pull-up resistors are required.
Wiring the Inputs (Sensors & Buttons)
Component ESP8266 Pin Secondary Connection
Low Water Float D1 Ground (GND)
Flow Sensor (Pulse) D2 5V (Power) and Ground (GND)
Mute Button D3 Ground (GND) Note: Do not press during boot.
High Water Float RX Ground (GND)
Wiring the Outputs (LEDs & Buzzer)
Wire each LED’s positive leg (anode) to the ESP pin, and the negative leg (cathode) through its specific matching resistor to Ground (GND).
Component ESP8266 Pin Color / Function Resistor
Power LED D0 White 120Ω
Buzzer D5 Signal to D5, VCC to 3.3V/5V, GND to GND N/A
High Water LED D6 Red 150Ω
Pump Running LED D7 Green 120Ω
Wi-Fi Status LED D8 Blue (Must be wired to GND to ensure safe boot) 22Ω
Mute LED TX Yellow 120Ω
:test_tube: Test Instructions
Once the firmware is flashed and the hardware is wired, verify functionality using these steps:
  1. Boot Test:
  • Plug in the device.
  • Expected Result: The White LED (D0) turns on. The buzzer (D5) beeps briefly for 100ms. The Blue Wi-Fi LED (D8) lights up solid once connected.
  1. Low Water & Flow Gatekeeper Test:
  • Ensure the Low Water Float (D1) is in the “Down” (empty) position.
  • Blow air into or manually trigger the Flow Sensor (D2).
  • Expected Result: Nothing happens. The code suppresses flow readings when the pit is empty.
  1. Pump / Flow Test:
  • Lift the Low Water Float (D1) to the “Up” position. Trigger the Flow Sensor (D2) rapidly.
  • Expected Result: The Green LED (D7) turns on (flow > 0.5 L/min). When you stop, the device calculates and publishes the “Last Cycle Average Flow Rate”.
  1. High Water Alarm Test:
  • Lift the High Water Float (RX) to the “Up” position.
  • Expected Result: The Red LED (D6) turns on. The buzzer sounds an alarm (1s on, 2s off).
  1. Mute Button & Lockout Test:
  • Drop the High Water Float to the “Down” position and press the Mute button.
  • Expected Result: Nothing happens (Strict Mute Lockout).
  • Lift the High Water Float back “Up” (Alarm sounds). Press the Mute button.
  • Expected Result: The buzzer stops. The Yellow Mute LED (TX) begins flashing continuously for 15 minutes.
  1. Emergency Override Test:
  • While the Mute LED is flashing, drop the High-Water Float “Down”, then immediately lift it back “Up”.
  • Expected Result: The mute is forcefully cancelled, and the siren immediately resumes.
  1. Sensor Fault (Failsafe) Test:
  • Drop the Low Water Float (D1) to the “Down” position. Lift the High-Water Float (RX) to the “Up” position.
  • Expected Result: The “Sensor Logic Check” entity triggers in Home Assistant, alerting to a physically impossible hardware state.
:balance_scale: Calibration (Bucket Test)
The default flow multiplier is calibrated to the Gredia G1-1/2" specification of exactly 30 pulses per Liter. To ensure precise tracking for your plumbing setup:
  1. Pump exactly 20 Liters of water through the sensor into a measured container.
  2. Check the Home Assistant metrics to see what the ESPHome device recorded.
  3. If the value is incorrect, adjust the multiply: 0.033333 filter in the YAML code using this formula:
New Multiplier = Current Multiplier × (Actual Volume / Sensor Volume)
Example: If the sensor read 18L instead of 20L: 0.033333 × (20 / 18) = 0.037036.
:open_book: User Manual
Overview
The Sump Water Level Monitor tracks discharge volume, monitors pit water levels, evaluates pump cycle efficiency, and provides immediate failsafe alerts if the water level becomes dangerously high.
Understanding the Status Lights
  • :white_circle: White Light (Power): The system is receiving power.
  • :blue_circle: Blue Light (Wi-Fi): Indicates the network status of the device.
  • :green_circle: Green Light (Pump Running): Illuminates whenever water is actively flowing.
  • :red_circle: Red Light (High Water): Illuminates when the water reaches a critical level.
  • :yellow_circle: Yellow Light (Mute): Flashes to indicate the audible alarm is temporarily silenced.
Emergency State (High Water Event)
If the primary pump fails or is overwhelmed:
  • Immediate Trigger: The Red LED turns on instantly.
  • Audible Alarm: The active buzzer begins an indefinite emergency loop.
  • Home Assistant: The Command Dashboard banner turns red, and push notifications can be triggered to mobile devices.
  • Resolution: The alarm will scream indefinitely until the water drops or the user manually overrides it.
Mute Override Functionality
To allow for safe maintenance or to silence a known emergency while a backup pump is deployed:
  • Activation Lockout: The Mute button is completely disabled during normal operation to prevent accidental silencing prior to an emergency.
  • Activation: During an active High-Water event, pressing the physical Mute Button (or the Home Assistant dashboard toggle) starts a 15-minute countdown.
  • Behavior: The buzzer is silenced, but the Red LED remains ON. The Yellow Light flashes continuously.
  • Cancellation: Pressing the button a second time kills the timer. If the water drops and rises again, the system forcefully kills the timer and resumes the siren.
Built-In Logic Failsafe’s
  • The Hardware Chirp: On boot, the buzzer fires for 100ms to confirm speaker health.
  • The Boot Sync: If power drops and returns while the basement is flooded, the D1 Mini will evaluate the float states the microsecond it boots, bypassing delays to instantly trigger the alarm.
  • Float Fault Detection: Identifies jammed floats or severed wires by checking for physically impossible switch combinations.
  • Network Auto-Heal & Fallback: Reboots the network stack after 15 minutes of disconnection. If the local network is permanently down, broadcasts a secure fallback AP (Sump-Monitor-Fallback-With-Flow) for local smartphone access.
Telemetry & Command Dashboard
The system feeds a custom Home Assistant Vertical Stack Dashboard featuring a dynamic color-coded Markdown banner and the following metrics:
  • Real-time Sump Flow Rate: Measured in L/min.
  • Last Cycle Average Flow Rate: Calculates the pump’s exact efficiency (L/min) from the moment it turns on to the moment it turns off.
  • Monthly Volume Discharged: A resilient Utility Meter in Home Assistant that tracks lifetime/monthly discharge without losing data during power outages.
  • System Health: Wi-Fi Signal Strength (dBm) and ESP Uptime.
Well done rcblackwell ! I love the fail-safes built-in, and the setup looks clean. Up for building it as a kit? Asking for a friend of course :wink:
Looks really good @rcblackwell ! Way more professional than mine. I like your strain relief cable knots too. Good thinking.
@nateokane, thanks for the feedback. In addition to the strain reliefs (knots), I placed a dab of hot glue at the point where each sensor, switch or power wire passed through the top side of the project board to the solder side.
That little trick came to mind after a finding a broken sensor wire on another project.
I hadn’t thought of that! Given the number of other projects on the table, I doubt I’d undertake such.
Feel free to utilize what I’ve published here. I’m a hobbyist and won’t take responsibility for any errors or omission’s you or anyone else may come across.
