Smart Water Controller
Hi!
So, previously I posted about a Home Assistant Integration that I created which is the Solem Toolkit, for controlling the watering of Solem BL2IP models. Then I created Solem Bluetooth Watering Controller Integration which manages the scheduling of watering and can take into account how frequent (hence how much water is used) you water and if it rains when should you water again.
Then I changed my controller for a Rainbird but it just creates a switch for each station. So I decided to create an integration that is able to use Solem BL2IP but also switch based sensors, as well as services in HA (it can use a sprinkle, stop sprinkle, turn on and turn off controller).
You can install this integration as any other custom component, through HACS adding the repo. You can also take a look at smart-water-controller-schedule-card which enables you to build your schedule.
The ones using the Solem integration, please try this one as going forward I will be iterating solely on this new integration (since you can use Solem with this one) and I have already fixed a few things from the Solem integration.
If you try it, any feedback is welcome.
Any hope to create an utility even for wifi modules?
