Solem Toolkit integration
Hi!
I created a Home Assistant Integration that is a toolkit for the Solem Bluetooth watering controller BL2-IP. It might work with more models, but it was just tested with that one.
I have one of those controllers and felt limited by only being able to use the MySolem app through Bluetooth as I could not control the device remotely. Also it’s a pain in the a** having to track the weather and make sure that I turn off the device when it rains, etc.
Solem Toolkit adds a few services to Home Assistant so you can have control of the device. I will soon create another integration that will actually use this Toolkit, but will be meant for a different purpose, namely managing watering schedules, only watering when it does not rain, etc.
You can install this integration as any other custom component, through HACS. You can find the repo here: GitHub - hcraveiro/Home-Assistant-Solem-Toolkit
If you try it, any feedback is welcome.
