(Continued from here)
Hi all,
I currently have a simple mains powered doorbell chime running on AC:
I have three features that I wish to add to it:
- To generate a programmable notification when it is pressed
- To be able to programmatically mute the chimes
- To be able to programmatically trigger the chimes
I also have a few fundamental requirements: the system should fail to a usable state (ie the doorbell triggers the chime) if the “smart” bits fail, or if the internet goes down.
After a bit of research I’ve found the basis on which this project can be built:
https://github.com/tIsGoud/Doorbell-via-Wemos-and-optocoupler
Which I believe should take care of the first requirement. I now have a few questions, some general to wemos development and some specific to this project.
- I see that there are various Wemos D1 boards, including what seems to be a new D32 model. Should I just go for the latest and greatest, or is that overkill and possibly not yet mature? Or is there a totally different board I should consider?
- Apart from the circuit components, what accessories do I need with the board? I see various shields and the like, do I host the circuit on the “bases” (single double or triple?). Or do I use some kind of separate breakout board? How would that be interfaced to the pins etc?
- I see there are shields with relays in them which I would have considered for a simple on/off usecase. Is it still worth using them for my slightly less trivial project, or should I use my own components?
I’ve come up with design adapted from the github project above:
- For the “switches”, would I just use simple off the shelf relays (taking care of NO/NC per instance), something like this?
- Do I need any other components (eg for safety/regulation)? I feel I’m missing a capacitor or two ;). What should the resistor values be (or how can I calculate that?).
- Is a wemos stable enough for me not to be paranoid about failure and, and to just have a button sensing circuit, a chiming circuit, and a wemos running software in between?
Assuming the above works what else should I add to the shopping list apart from:
- 1x wemos (or equiv)
- 1x 2 channel relay module
- 1x optocoupler
- 1x diode
- 1x 330ohm resistor
- development items (breadboard, power etc)
Any thoughts appreciated!
