Any errors at logs?
Your config looks ok.
I suggest you remove everything from custom_components folder and start over by following the instructions.
Thanks a lot Vassilis i found out that direct download of json files made mistakes in file. Just copied and past the code on a new .json and all worked flawlessy.
I have another question: as my air conditioner is an old Daikin model , with the remote i have often to push twice the off button to turn off the power. Where do i have to edit to have a repetition of the off input ?
@Vassilis I appreciate that and all that youâve done with this project.
The units are Mitsubishi Heavy Industry SRK models.
SRK25ZJ-S1
SRK71ZK-S
The code files are ready. Please add 1680 and 1681 as device_code and the component will download them.
You can repeat the off command by setting it as an array in the json file:
"commands":{
"off":[
"command...",
"command..."
"heat":{
019-04-07 12:44:59 ERROR (MainThread) [homeassistant.core] Error doing job: Future exception was never retrieved
File â/usr/local/lib/python3.7/concurrent/futures/thread.pyâ, line 57, in run
File â/usr/local/lib/python3.7/site-packages/homeassistant/components/homekit/type_thermostats.pyâ, line 250, in update_state
if isinstance(target_temp, float) and current_temp > target_temp:
TypeError: â>â not supported between instances of âNoneTypeâ and âfloatâ
@Vassilis Hey thanks for the amazing contribution. Works well but it seems like a lot of the commands are missed while controlling my AC using a broadlink RM mini 3.
I need to send them twice or even 4 times for them to work.
Hereâs my config:
smartir:
switch:
- platform: broadlink
host: x.x.x.x
mac: 'x:x:x:x:x:x'
climate:
- platform: smartir
unique_id: xxxxx
device_code: 1281
controller_send_service: switch.broadlink_send_packet_x_x_x_x
Am i doing something wrong?
Iâm seeing occasional missed commands as well, but only in 1 out 10 cases, I would say.
Still trying to figure out if Broadlink fails to send the command, or if Aircon simply doesnât receive it.
Same here with Hisense Cond. But only 1/10 works and randomly⌠I used the available code in the repository, that is not exposing the model name. I suppose it can be from another one different from mine. The âoldâ custom component worked, so iâm planning to complete the manual code acquisition fro the old ini and ask for a conversion.
But the random cases in which it works makes me think that something is not going in the right way with the new component.
The broadlink pro is working correctly using its own app, even when HA seems not sending the commandâŚAnd the same command sent by the âswitchâ component from ha works correctlyâŚ
Could you send me your json file and tell me which command is not sending?
Pozdrav @ Igor_Jurisic!
Iâm also using a Xiaomi door / window sensor to keep track of whether my Toshiba split system is on / off. As you can see below, I have a Xiaomi camera positioned beneath the AC which was really helpful while I was testing things out. I still keep it there just as an additional method of checking
Regarding some commands not getting through, I found the OFF command sometimes wouldnât work, so in my script that turns off the AC, I actually fire the OFF command twice. Iâm using a Broadlink RM Mini 3.
switch_off_toshiba_air_conditioner:
alias: Switch off toshiba air conditioner
sequence:
- service: climate.set_operation_mode
entity_id: climate.toshiba_air_conditioner
operation_mode: 'off'
- delay:
seconds: 2
Cheers,
Petar
Amazing job on the SmartIR Climate Vassilis. Keep up the good work.
Awesome work @vassilis
Is there any chance that your component could also work with this :
It has same functionality as the Broadlink rm mini 3.
thank you !
Pozdrav @pkozul
Iâm doing the sameâŚfurthermore Iâve added contingency plans for situations in which the âonâ command doesnât fire. It checks when climate component turns on, and if within 15 secs the xiaomi sensor doesnât report âopenâ it will send âonâ command once again.
- id: '0063'
alias: 'Aircon Livingroom Infrared On Failed'
- platform: state
entity_id: climate.livingroom_ac
to: 'heat'
for:
seconds: 15
- platform: state
to: 'cool'
for:
seconds: 15
condition:
- condition: state
entity_id: binary_sensor.0x00158d0003132f63_contact
state: 'off'
- service: climate.turn_on
I have tried 1281.json and 1284.json
The previous custom component worked pretty well, however most of my commands get dropped, whereas Google Home and app are able to send commands.
I have enabled debug, will let you know if I see something.
Also, is there a way to learn commands using HA?
(whenever I start learn command service, thereâs an error in log saying cannot connect to broadlink or something.)
@VasileyI was wondering if thereâs a way to use your code to achieve something in reverse (add an IR receiver near AC IR receiver, and get any commands sent to the AC?)
This will be useful to keep HA in sync with any changes made via manual remote/Google
Thanks in anticipation
Whereas the SmartIR Climate gives me this beautiful interface and controls
SmartIR TV only shows me this
No vol+/vol- or chan+/chan- Only a power button (that works)
I created the json file by learning the IR codes.
I found out that there are newer aircond models that not supported by SmartIR.
Is there any way to find latest IR codes for latest aircond models?
Thanks.
I there any plan in implement IR blaster from XIAOMI?
Worked perfectly with hitachi A/C and samsung tv (using broadlink)
Thank you!
