Hey there, Great work with this plugin, I have managed to map all my LG input sources and commands using an RM Mini 3 into this plugin and the UI works flawlessly, I am new to HA (started today) was just wondering how I set up voice triggers for Google home with this? turning on and off the tv works, But I want to be able to change input with voice also is this possible?
I noticed that too. I have also lost on/off switch under the graph.
It still works fine though.
When will SmartIR be integrated with HACS?
Struggling with something very basic here How on earth do I configure the smartir climate component to operate like a thermostat actually - i.e. turn off the AC when the target temperature has been reached? All it does now is to set the AC unit to temperature and mode of operationā¦
do you have a temperature sensor in the room and added to the smartir compnent
temperature_sensor: sensor.temperature
sure do:
- platform: smartir
unique_id: office_air
device_code: 2222
controller_data: 192.168.1.40
temperature_sensor: sensor.office_temp
humidity_sensor: sensor.office_humidity
I think you should probably use automations for this kind of thing. Although I would LOVE to have a thermostat functionality in SmartIR!
Have a look at node red for your automation. It will allow you to configure and automation to wait until the desired temp is reached then send an off command. Also be aware if you turn a/c on and off it will use considerably more power rather than letting it regulate its own temp.
Thanks for the tips, guys. I do have all my automations in NodeRed, couldnāt be happier on this account. I just wanted to make sure Iām not overlooking something and it is what it is with the smartir integration. Also wanted to use the thermostat card natively instead of hacking it (somehow) via NR.
On a separate note, Iāve been wondering about power consumption of an AC under frequent power downs and canāt get a straight answer - seems most sources I looked at agree that it actually saves power as opposed to having the AC run for long stretches. @brent0np, do you have a good source to support your claim I can read up on? Thanks!
Codes for Dry Operation Mode for Daikin 1100 (ex Arc433a21)
"18": "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",
"19": "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",
"20": "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",
"21": "JgC8AXA7DC0MEAwPDBALLgwPDBELEAsQCy4MDwwtDC0NDwwtDC0MLQwtDC0MDwwQDC0MEAwPDBAMEAwPCxAMLQwtDC0MLQwQDA8MEAwQCxAMEAsQDBAMEAwPDBAMEAwPDBALEAwQDBALEAwQDBALEAwRChAMEAsQDC4KEQwQCxAMEAwQDA8MAAPkcTkMLgwPDBAMDwwuCxAKEgwPDBAMLQwPCy4MLQwQDC0MLQwsDS0LLgsQDBALLgwQChEMEAwPDBAMEAsQCxEMEAwPDBALEQoRChMKEAsRCxAMEAwtDA8NDwwQChELLgwQDBAMDwsRDA8MEQwPDA8LLgwtDA8NDwwQDBALEAsRCxAMEAoSCxAMEAoRDC0MLQwQCxEKEgoSCxAKEQwQChIMDwwQCxALEQoSChELEQoRCxILEAsRCxAKEgoRDBAKEQwQDBALEAwQChELEQoRDBAMEAwPDBAKEQwSChALEQouCxEMDwwQCxENDgwQCxELEAsRDBAKEgoRCxEMEAsQDA8MLQwtDBAMDwwQDBALEAwQCxAMEAsRCxAMEQsQDA8MEAsRDA8MLQsuDA8MEAwQCxAMEAwQCwANBQAAAAAAAAAAAAAAAA==",
"22": "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",
"23": "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",
"24": "JgC8AXE6DC0MDw0PDA8MLgwPDBAMDwwQDC0MDwwtDC0MEAwtDCwNLAwtDC0NDwwPDS0MDwwQDA8NDwwQDA8MLQwtDC0MLQwPDBAMDw0PDBAMDwwQDBAMDwwQDBAMDwwQDA8MEAwQDA8MEAwPDBAMEAwPDBAMDw0PDC0MEAwPDBAMDwwQDBAMAAPkcDkNLQwPDBAMDwwuDA8MEAwPDBAMLQwPDC0MLQwQDC0MLAwtDC0MLgwPDA8NLQwPDBAMEAwPDBAMDwwQDBAMDwwQDA8MEAwQDA8MEAwPDBAMDwwuDA8MEAwPDA8NLQwQDA8MEAwPDBAMDw0PDBAMLAwuDA8MEAwPDQ8MEAwPDBAMEAwPDBAMDwwQDC0MLQwPDBAMEAwPDBAMDw0PDBAMDwwQDBAMDwwQDA8MEAwQDA8MEAwPDBAMEAwPDBAMDw0PDA8MEAwQDA8MEAwPDQ8MEAwPDBAMEAwPDBAMDwwtDBAMEAsQDBAMDwwQDBAMDwwQDBAMDwwQDBAMDwwQDA8MLQwtDBAMDwwQDA8MEAwQDA8MEAwQDA8MEAwQDA8MEAwPDQ8MLQwtDA8MEAwQDA8MEAwPDAANBQAAAAAAAAAAAAAAAA==",
"25": "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",
"26": "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",
"27": "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",
"28": "JgC8AXE6DC0MEAwPDBAMLQwPDBAMEAwPDC0MDwwtDC0MEAwtDC0MLA0sDC4MDwwQDC0MDwwQDA8NDwwQDA8MLQwtDC0MLQwPDBAMDwwQDBAMDwwQDBAMDwwQDBAMDwwQDA8MEAwQDA8MEAwPDBAMEAwPDBAMDwwQDC0MDw0PDBAMDwwQDBAMAAPjcDoMLgwPDBAMDwwtDBAMDw0PDA8MLgwPDC0MLQwPDC0MLQwtDC0MLQwQDA8MLQwQDBAMDwwQDA8MEAwQDA8MEAwPDBAMEAwPDBAMEAwPDBAMDwwtDBAMDwsRDA8MLgwPDBAMDwwQDBAMDwsRDA8MLQwtDBAMDw0PDBAMDwwQDBAMDwwQDA8MEAwPDC0MLQwQDBAMDwwQDA8NDwwQDA8MEAwQDA8MEAwPDBAMEAwPDBAMDwwQDBAMDwwQDA8MEAwQDA8MEAwPCxEMDwwQDBAMDwwQDA8NDwwQDA8MEAwtDA8MEAwQDA8MEAwQCxAKEgwPDBAMEAwPDBAMEAwPDBAMLQwsDQ8MEAwPDBAMEAsQDBAMEAwPDBALEA0PDBAMDwwQDA8MLQwtDBAMDwwQDBAMDwwQDAANBQAAAAAAAAAAAAAAAA==",
"29": "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",
"30": "JgC8AXA7DC0MDw4ODBAMLQwPDQ8MEAwPDC0MDwwtDC0MEA0sDC0MLQwsDC4MDwwQDC0MDwwQDA8NDwwQDA8MLQwtDC0MLQwPDBAMEAwPDBAMDwwQDBAMDw0PDBAMDwwQDA8MEAwQDA8MEAwPDQ8MEAwPDBAMEAwPDC0MEAwPDBAMDw0PDBAMAAPkcDoMLQwPDBAMDwwtDBAMEAwPDBAMLQwPDC0NLAwQDC0MLA0sDC0MLQ0PDA8NLQwPDBAMDwwQDA8ODgwQDA8NDw0PDA8MEAwQDA8MEAwPDBAMDwwtDQ8MEAwPDBAMLQwPDQ8MEAwPDBAMDwwQDA8MLQwuDA8MEAwPDBAMEAwPDBAMDwwQDBAMDwwQDCwNLQ0ODBAMEAwPDBAMDwwQDBAMDwwQDA8MEAwQDA8MEAwPDBAMEAwPDBAMDw0PDBAMDwwQDA8NDwwPDBAMEAwPDBAMEAwPDBAMDwwQDBAMDwwtDBAMDwwQDBAMDwwQDA8MEAwQDA8MEAwQDA8MEAwPDQ8MLQwtDA8MEAwQDA8MEAwPDBAMEAwPDQ8MEAwPDBAMEAwPDBAMLA0sDBAMEAwPDBAMDw0PDAANBQAAAAAAAAAAAAAAAA=="
Question: Dry mode is not being shown in Google Home (Via Nabu), is it a bug?
Probably not a mode it supports. Cant say Iāve seen it either, but i donāt use it anyway.
I donāt believe google home support modes: dry, fan, auto.
can you see the other service smartir.check_updates
No, I donāt have it either
So is smartir working for you? Are you using it? You might be best placed to create an issue on the github repo.
Please check your configuration if the smartir:
keyword exists.
yes yes, itās works nice, but the servers isānt there
Please help me with turning this component on using Alexa:
- I have set up an entity called climate.living_room_ac using the smartir component.
- The entity works correctly and I can control it using the Home Assistant front end - turning it on, off, changing temperature etc.
- I have exposed the entity climate.living_room_ac to Alexa using the emulated hue component.
- I CAN change the temperature of the entity climate.living_room_ac using Alexa commands (either via the alexa app on my mobile or voice). The temperature indicator on the front end changes to the new value but the state remains āoffā.
- I CANNOT turn the entity on.
I have used both the broadlink platform (using base64 codes) and the xiaomi platform (using raw codes).
