About configuration of the component
on Hassio the right path for the custom_components/smartir… directory is inside the /config folder, the same folder of the configuration.yaml is this correct?
Is it possible to add a ping host option as the old component? The old component only sent ping’s when required. So that the state updates were quite fast. Whereas the new one requires a power sensor. If I create a ping sensor to feed the power_sensor: option I need to put a small scan_interval which creates unnecessary traffic.
I’ve checked your code and each command has the self.schedule_update_ha_state() statement and def update(self) includes the ping command. And from that information I supposed ping was called with every command and not on a scheduled base. I supposed wrong then, opps
So from another perspective, is it possible to add such functionality to the smartir code?
If should_poll is true then the component calls update on a scheduled base (according to scan_inteval). I’m not planning to add the ping function to smartir. A ping binary sensor will do the job.
Too bad to hear that. Yes I am using a ping binary_sensor, but even with a scan_interval of 30s it has worse performance than the old component. I was not using the “should_poll” with the old component.
Should_poll was true in code. It was mentioned to complete your findings.
For faster updates add scan_interval: to media_player configuration and adjust to your needs.
Actually I don’t have should_poll in code, but thank you. Will look into changing scan intervals to a lesser amount to get the desired effect. Thank you.
This tool converts only climate INI files. There is already a file compatible with your tv. Please add 1060 to device_code parameter. The component will download your file.
