Yes, me. Do you own a device? Because I’m waiting mine.
In the upcoming HA version (0.89) there is a breaking change in the climate platform. SmartIR needs to be updated to work properly.
There is already a fix in the SmartIR rc branch that works with HA 0.89 beta versions.
I am trying to migrate my automations from sending Broadlink commands directly, but I am struggling with how to trigger this module from automations. Can someone please give me a hint on how to do this? Example code would be awesome. Thanks!
migrated successfully, too. any hint how to expose a simple on/off switch to homekit?
Does anything else need to get done? I can’t get the climate component working again,
2019-03-07 19:09:01 ERROR (SyncWorker_19) [homeassistant.loader] Error loading custom_components.smartir.climate. Make sure all dependencies are installed
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/loader.py", line 166, in _load_file
module = importlib.import_module(path)
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/home/homeassistant/.homeassistant/custom_components/smartir/climate.py", line 20, in <module>
from . import COMPONENT_ABS_DIR, Helper
ImportError: cannot import name 'COMPONENT_ABS_DIR' from 'custom_components.smartir' (/home/homeassistant/.homeassistant/custom_components/smartir/__init__.py)
2019-03-07 19:09:01 ERROR (SyncWorker_19) [homeassistant.loader] Unable to find platform smartir. Search path was limited to path of component: custom_components
2019-03-07 19:09:03 ERROR (SyncWorker_19) [homeassistant.loader] Error loading custom_components.sharp_aquos. Make sure all dependencies are installed
Please open an issue on GitHub
New issue submitted
Hi
just updated to 0.89 and I’m getting this error
And this is my config
- platform: smartir
device_code: 1400
controller_send_service: switch.broadlink_send_packet_192_168_1_56
temperature_sensor: sensor.temp_sala_xiaomi
humidity_sensor: sensor.temphum_sala_3
both sensors have valid data
I have 3 climate smartir and all of them does not show the Humidity value
Any suggestion?
On Hass.io 0.89.0 I get:
and
EDIT:
I didn’t have controller.py - I added it to the custom_components folder and my problem is now solved.
Hello can anyone tell me how to contribute my climate .json file? i have made one for beko air-conditioning machines and wondered if it would like to be added to the list for everyone else.
Its strange - I had that issue on my phone but desktop worked
Confirm. Works from desktop. That is strange but I am fine
Just in case anyone is a little unsure about how to convert the power sensors for dumb devices using smart plugs (I use xiaomi) on the old config, here’s something that works for me:
old:
fan:
- platform: broadlink
name: Living Room Fan
host: !secret broadlink_pro_ip
mac: !secret broadlink_pro_mac
rfcodes_ini: 'broadlink_fan_codes/living_room_fan.ini'
default_speed: low
customize:
speeds:
- low
power_consumption_entity: switch.plug_xxxxxxxxxxx
power_consumption_threshold: 10
new:
binary_sensor:
sensors:
living_room_fan_power:
friendly_name: "Living Room Fan Power"
value_template: >-
{{ states.switch.plug_xxxxxxx.attributes.load_power|float > 10 }}
fan:
- platform: smartir
unique_id: living_room_fan
device_code: 1030
controller_send_service: switch.broadlink_send_packet_IPADDRESS
power_sensor: binary_sensor.living_room_fan_power
I have a new error message after updating your component: (running 88.2)
The device JSON file is invalid
1:16 PM custom_components/smartir/media_player.py (ERROR)
it all seems to work fine, just a new error. Perhaps you’re aware. No other information given
dear
After upgrading to 0.89.1 i am unable to get smartir working as my
platform: switch.broadlink is not found.
can somebody please help.
I do still have the old vpnmaster custom_components/broadlink/climate.py,fan.py,media_player.py as my custom components, but none are working now.
Please guide.
thanks
Yes, this the new installation mode for custom_components.
