yesterday HA locked up so i de-powered and restarted HA, it came back up ok but since then smartthings are not getting seen in HA:
Logger: homeassistant.config_entries
Source: components/smartthings/init.py:121
First occurred: 13:22:59 (1 occurrences)
Last logged: 13:22:59
Error setting up entry Home for smartthings
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 313, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File “/usr/src/homeassistant/homeassistant/components/smartthings/init.py”, line 121, in async_setup_entry
token = await api.generate_tokens(
File “/usr/local/lib/python3.9/site-packages/pysmartthings/smartthings.py”, line 209, in generate_tokens
result = await self._service.generate_tokens(
File “/usr/local/lib/python3.9/site-packages/pysmartthings/api.py”, line 424, in generate_tokens
raise APIInvalidGrant(data.get(“error_description”))
pysmartthings.errors.APIInvalidGrant: Invalid refresh token: 0a942401-8b35-4c0e-8157-88f8eaa538c4
Logs:
2022-01-02 13:22:46 ERROR (MainThread) [snitun.client.client_peer] Challenge/Response error with SniTun server (0 bytes read on a total of 32 expected bytes)
2022-01-02 13:22:46 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-01-02 13:22:58 ERROR (MainThread) [snitun.client.client_peer] Challenge/Response error with SniTun server (0 bytes read on a total of 32 expected bytes)
2022-01-02 13:22:58 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-01-02 13:22:59 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Home for smartthings
2022-01-02 13:23:56 WARNING (SyncWorker_0) [homeassistant.components.ring] Error fetching Ring history data for device 3ce1a1afecef: (‘Connection aborted.’, RemoteDisconnected(‘Remote end closed connection without response’))
Hope someone can assist as most of my equipment is through smartthings and none of it is connecting to HA.
