Hi guys, I’ve been adding smartwings zwave roller blinds to my home assistant and I’ve been having some unwanted behavior.
When using the smartwings remote the blinds answer pretty much instantly. When using home assistant, however, I get variable lag… Ideally I’d like the blinds to come up/down in sync in the same room…
I’m wondering if this is a problem with the blinds, if its something with my setup, or just configuration… I’m using a Zooz 800LR dongle, I have some powered ZWave devices throughout the apartment, I dont think the zwave network is “bad” per se, but I dont have a lot of experience…
I’ve tried healing the network, but dont see any difference…
I’ve grouped the blinds within Home Assistant (I understand there isnt a way of doing a ZWave group like a Zigbee group, which would perhaps help this issue)… Is there a way of improving this or at least can someone kindly point me to where I’d monitor for errors?
(I also notice that something the HA cover group that has the blinds seems to be out of sync with where the blinds are, like if one blind goes to the requested position, but another “misses out” on the command)…
Any and all help is appreciated…
I’ve considered changing the motors to their new Matter version, but I dont want to do that unless I’m relatively sure it would fix the performance issues?
Thanks very much for all help!
Some logs : Subscribed to Z-Wave JS log messages…2025-04-14T18:51:12.239Z DRIVER one or - Pastebin.com
