Could someone help me with my problem?.
I want to make my ezviz camera a snapshot when de doorbell is pressed and send a picture with pushover.
I cant get it fixed, do you have more specific tips?
Sure, the basic parts will be something like this:
- platform: state
entity_id: binary_sensor.your_doorbell_sensor_here
to: 'on'
- service: camera.snapshot # take a picture and store it
entity_id: camera.your_camera_here
filename: '/config/www/snapshots/doorbell.jpg'
- delay: 3 # may or may not be required depending on how long it takes to make and store your picture
- service: notify.your_pushover_notifier_here # send the picture
title: "Doorbell"
message: "The doorbell has been pressed."
attachment: "config/www/snapshots/doorbell.jpg"
You need to create the config/www
folder and config/www/snapshots
folders. If you did not already have a www
folder in the /config
folder you need to restart Home Assistant after creating it.
Hallo,
Do I need to place this in the configuration, Or in the automatisation part
Please read the documents on how to create an automation.
Its nog working…
Hello tom,
thanks for trying to get me in the right direction, i hope you can read my lines better now. This is what i got so far. i’m getting a notification if my doorbell is pressed, but no shapshot.
- alias: Deurbel Voordeur Notificatie
- platform: state
entity_id: binary_sensor.doorbell
to: "on"
condition:
- condition: template # only notify once every 10 seconds at most
value_template: "{{ ( as_timestamp(now()) - as_timestamp(state_attr('automation.deurbel_voordeur_notificatie', 'last_triggered')) |int(0) ) > 10 }}"
entity_id: camera.carport
- delay: 5
- service: notify.Jos_po
title: "Deurbel Voordeur"
message: "Ding dong!"
- service: notify.Mieneke_po
somebody any tips?
Does your camera config have a still image URL defined?
you did the snapshot but where you attached it to your notification? The example from @tom_l has it:
title: "Doorbell"
(last line).
Its working, thx for the help.
I hope someone can help me out because I’m stuck. I have been trying for days now to get this working:
doorbell (with shelly integration) is pressed → snapshot taken → snapshot delivered with notification to my iPhone. I came across this feed here hoping to find a solution but nothing I do makes this work.
The frustrating thing is that I have an automation working which sends me a snapshot of another camera whenever my hue motion sensor picks up motion. I build this with this blueprint: 📸 Send camera snapshot notification on motion. Modifying that automation didn’t get me to get this doorbell automation which I am trien to built going either. So what my code looks like is this:
alias: foto deurbel
description: ''
- platform: device
type: changed_states
device_id: 2477bd452f41cb77d93fb00e78422551
entity_id: switch.shelly1_e8db84d46224
domain: switch
condition: []
filename: /config/www/snapshots/camera.diskstation_voordeur.jpg
entity_id: camera.diskstation_voordeur
- service: notify.mobile_app_h_rro
message: tring-tring
content-type: jpg
url: /config/www/snapshots/camera.diskstation_voordeur.jpg
mode: single
What I get is a notification on my iPhone: tring-tring.
When I long press the notification I get this on my iPhone (13 Pro Max):
I can see that every time the automation runs a new snapshot is being taken and the old one overwritten so that part of it works all right.
I have tried about every setting I could think of, changing “url” to " image" etc. but I am stuck.
I am hoping anyone has a suggestion how to solve this.
