So I was posting a bunch of items that I was recently having issues with. I was getting a lot of warnings about SNMP taking more than 10 seconds to load but then other things started to happen like.
After my last reboot of HA noticed in the logs that metno isn’t working anymore
2020-01-25 10:10:20 ERROR (MainThread) [metno] https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/1.9/ returned
Not sure what I’m seeing is the full command but still erroring during startup.
Then also saw loads of issues with groups and other things taking a long time to connect.
Then got the below composite tracker issues:
2020-01-25 09:20:31 WARNING (SyncWorker_0) [custom_components.composite.device_tracker] device_tracker.john_s_iphone_unifi unsupported source_type: None
2020-01-25 09:20:31 WARNING (SyncWorker_9) [custom_components.composite.device_tracker] device_tracker.sue_s_iphone_unifi unsupported source_type: None
Then also getting errors connecting to my unifi controller
2020-01-25 08:52:47 ERROR (MainThread) [homeassistant.components.unifi] Error connecting to the UniFi controller at 192.168.0.1
When the controller is running and if I stop and start it again after the system was loaded it would connect.
So I commented out some of my yaml files with all my SNMP sensors including the below and the problems went away. All of them. Any idea?
sensor_dell2130cn.yaml:
- platform: snmp
name: Dell 2130CN Cyan
host: 192.168.0.4
baseoid: 1.3.6.1.2.1.43.11.1.1.9.1.1
accept_errors: true
scan_interval: 21600
unit_of_measurement: '%'
value_template: "{{ ((value | float / 2500)*100) | int }}"
- platform: snmp
name: Dell 2130CN Magenta
host: 192.168.0.4
baseoid: 1.3.6.1.2.1.43.11.1.1.9.1.2
accept_errors: true
- platform: snmp
name: Dell 2130CN Yellow
host: 192.168.0.4
baseoid: 1.3.6.1.2.1.43.11.1.1.9.1.3
accept_errors: true
- platform: snmp
name: Dell 2130CN Black
host: 192.168.0.4
baseoid: 1.3.6.1.2.1.43.11.1.1.9.1.4
accept_errors: true
- platform: snmp
name: Dell 2130CN Status
host: 192.168.0.4
baseoid: 1.3.6.1.2.1.43.17.6.1.5.1.1
accept_errors: true
scan_interval: 1000
- platform: snmp
name: Dell 2130CN Status 2
host: 192.168.0.4
baseoid: 1.3.6.1.2.1.43.17.6.1.5.1.2
accept_errors: true
scan_interval: 1000
- platform: snmp
name: Dell 2130CN Ready
host: 192.168.0.4
baseoid: iso.3.6.1.2.1.43.16.5.1.2.1.1
accept_errors: true
scan_interval: 1000
- platform: snmp
name: Dell 2130CN Name
host: 192.168.0.4
baseoid: iso.3.6.1.2.1.25.3.2.1.3.1
accept_errors: true
scan_interval: 86400
value_template: "{{ value.split(';')[0] }}"
- platform: snmp
name: Dell 2130CN How Long Up
host: 192.168.0.4
baseoid: 1.3.6.1.2.1.1.3.0
accept_errors: true
scan_interval: 3600
unit_of_measurement: 'Days'
value_template: "{{ (value | int / 8640000) | int }}"
- platform: snmp
name: Dell 2130CN Pages Printed
host: 192.168.0.4
baseoid: iso.3.6.1.2.1.43.10.2.1.4.1.1
accept_errors: true
scan_interval: 3600
and my other printer of sensor_canonmf8580cdw.yaml:
- platform: snmp
name: Canon MF850CDW Black
host: 192.168.0.6
accept_errors: true
- platform: snmp
name: Canon MF8580CDW Cyan
host: 192.168.0.6
accept_errors: true
- platform: snmp
name: Canon MF8580CDW Magenta
host: 192.168.0.6
accept_errors: true
- platform: snmp
name: Canon MF8580CDW Yellow
host: 192.168.0.6
accept_errors: true
- platform: snmp
name: Canon MF8580CDW Status
host: 192.168.0.6
baseoid: 1.3.6.1.2.1.25.3.5.1.2.1
accept_errors: true
scan_interval: 1000
value_template: "{%if value|int(base=16) == 0 %}OK{% else %}Failed{% endif %}"
- platform: snmp
name: Canon MF8580CDW Name
host: 192.168.0.6
baseoid: 1.3.6.1.2.1.25.3.2.1.3.1
accept_errors: true
- platform: snmp
name: Canon MF8580CDW How Long Up
host: 192.168.0.6
accept_errors: true
scan_interval: 3600
value_template: "{{ ((value | float / 8640000) | float) | round(1) }}"
- platform: snmp
name: Canon MF8580CDW Pages Printed
host: 192.168.0.6
baseoid: 1.3.6.1.4.1.1602.1.11.2.1.1.3.1
accept_errors: true
scan_interval: 3600
- platform: snmp
name: Canon MF8580CDW B/W Pages Printed
host: 192.168.0.6
baseoid: 1.3.6.1.4.1.1602.1.11.2.1.1.3.3
accept_errors: true
scan_interval: 3600
- platform: snmp
name: Canon MF8580CDW Color Pages Printed
host: 192.168.0.6
baseoid: 1.3.6.1.4.1.1602.1.11.2.1.1.3.5
accept_errors: true
scan_interval: 3600
EDIT: If I just put the Dell Printer yaml back in everything seems to be working but adds in one
2020-01-25 10:47:03 WARNING (MainThread) [homeassistant.components.weather] Setup of weather platform met is taking over 10 seconds.
If I switch off the Dell yaml and enable Canon same singular warning.
Should be noticed I am also monitoring two APCs with SNMP. Those are still enabled.
