Social media filter
My daughters spend far too much time on social media. So I was looking for a way to block it. I have installed the AdGuard Home Add-on. There is the possibility to set filters yourself.
I searched the internet for different rules and merged them into my repository, Social-media Blocklists.
This repository contains rules to block Facebook, Instagram, TikTok, Youtube and Whatsapp. These are suitable for Pi-Hole or AdGuard Home.
Thanks to @Skeletorjus and @radinsky. They found a way to turn it on and off
input_boolean:
  allowfacebook:
    icon: mdi:facebook
switch:
    switches:
      allowfacebook:
        value_template: "{{ is_state('input_boolean.allowfacebook', 'on') }}"
        icon_template: mdi:facebook
        friendly_name: Facebook
        turn_on:
              entity_id: input_boolean.allowfacebook
        turn_off:
          - service: input_boolean.turn_off
automation:
  - id: enable_facebook
    alias: Enable Facebook
      platform: state
      to: 'on'
    - service: adguard.remove_url
        url: "https://raw.githubusercontent.com/gieljnssns/Social-media-Blocklists/master/adguard-facebook.txt"
  - id: disable_facebook
    alias: Disable Facebook
      platform: state
      to: 'off'
    - service: adguard.add_url
EDIT: changed the service because enable_url and disable_url isn’t working anymore
remove_url also gives an error, but still works
Logger: homeassistant.components.automation.enable_facebook
Source: components/adguard/__init__.py:85
Integration: Automatisering (documentation, issues)
First occurred: 10:14:00 (2 occurrences)
Last logged: 10:14:00
Enable Facebook: Error executing script. Unexpected error for call_service at pos 1: ('Failed removing URL from AdGuard Home filter', {'response': 'OK 0 rules\n'})
While executing automation automation.enable_facebook
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 253, in _async_step
    await getattr(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 460, in _async_call_service_step
    await service_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 1451, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1486, in _execute_service
    await handler.job.target(service_call)
  File "/usr/src/homeassistant/homeassistant/components/adguard/__init__.py", line 85, in remove_url
    await adguard.filtering.remove_url(call.data.get(CONF_URL))
  File "/usr/local/lib/python3.8/site-packages/adguardhome/filtering.py", line 81, in remove_url
    raise AdGuardHomeError(
adguardhome.exceptions.AdGuardHomeError: ('Failed removing URL from AdGuard Home filter', {'response': 'OK 0 rules\n'})
I use them all as packages.
If you find other url’s to block social media, you can always fork my repo and make a PR.
Anyway to please block discord app via these filters?
@sominaik
You can always make a file adguard-discord.txt file and add some url’s you can find on the web.
In adguard home you can search yourself for url’s, just have a look in the query log
Ok thanks for your reply.
Btw, it seems Instagram filter isn’t working … I tried but the app still works on the phone. Do you know notice the same?
