I just had my Solar company unlock some additional “access” into Solar edge that they decided not to tell me about but I can now see each of my panels and a bunch of information about each panel, including SN, Model, Voltage, power (watts) and current.
Now all that information is available through the Solar Edge application as seen in the screenshot below but I don’t see any of it passing through to Home Assistant. I checked and do not see any additional entities nor does anything show up under the developer section.
I am hoping there is some existing way to add these “optimizer maps” or at least add the individual optimizer (panel) stats into home assistant to be able to monitor. As seen in the screenshot I appear to have several panels that are not working on the same level as others even though having the same angle and positioning on my roof as others right next to them without any shade.
SolarEdge publishes a list of REST APIs that allows one to get access to information about their solar installation site using an API Key. HA has selected a few of these APIs to use. Here is a document containing a list of APIs, and you can look to see if there is one that provides energy estimates for each panel (I could not find one myself). It could be the case that they don’t publish an API for this particular case, but I am not sure. To my knowledge, HA does not use an API that does this, but if the API exists, one can create their own sensor to use this API. One just has to be mindful that SolarEdge rate limits requests to their website, so adding your own sensor would make it more likely to hit this limit.
Seems like there is info to get via API calls i think, would it just not be a matter of the person responsible for the solaredge integration in HA to implement the pulling of this extra data?
I reviewed the documentation wmaker provided and I didn’t see any way to actually pull the individual panel info from the SolarEdge API.
It doesn’t appear to be possible from there, outside of their app.
I also learned that the reason for me wanting this… Is simply my solar company is incompetent and lazy . When they designed my map, they just placed the panels wherever instead of taking the time to put them where they actually are, so those are all my panels on my roof, but the reason I have dark spots all over is because none of the physical panel locations match the map.
good morning everyone, recently owner of homeassistant, recently made solaredge photovoltaic system, already all integrated in HA.
I also wanted to do the integration optimizers, but I get stuck with official Solaredge site id / account / psw. I tried all the combinations (http my complete site, public site, site id code etc) but it always gives me an error
I have installed the integration and I receive data from every single module. But I do not understand the numbers. My idea is to compare the sum up the current production of every single module and to compare it with the numer I recieve from the converter. But the calculated number is much higher that what I see in the app or what the converter delivers:
current unmbers calculated: 3408W
converter: 30.1W
The module power from the app is equal from the numbers I get from the API in HA. What is wrong?
