As of 0.99.x SolarEdge is still supported in HA
Since last update of HA, my solarEdge sensor is not working. I used the cloud version as local is only available on certain models.
As noted in the release notes, the monitoredOptions where no longer supported (why making this breaking change?) so I removed them and my config simply says:
- platform: solaredge
api_key: !secret solarEdge_api_key
site_id: !secret solarEdge_site_id
And my template looks like this:
grid_now:
friendly_name: "Zonnestroom nu"
icon_template: mdi:import
unit_of_measurement: 'Wh'
value_template: >
{%- if states.sensor.solaredge_current_power.state -%}
{{ (states.sensor.solaredge_current_power.state | float ) | round(2) }}
{%- else -%} 0 {%- endif -%}
What has changed or do I need to change next?
The release notes for some reason did not mention that you also have to change the configuration of solaredge as a standalone component and not as a sensor platform. They did update the document however.
The configuration should now be:
solaredge:
api_key: !secret solaredge_api_key
site_id: !secret sloaredge_site_id
Yep, this is working for me in 0.99.3.
Is there a more complete documentation for the SolarEdge (cloud) component ? The SolarEdge component page only explains how to configure the component but does not give any explanation about the sensors that are created.
I did my first SolarEdge config this week (new solaredge install), it was great to be able to use the standard integration in HA but I miss some clearer explanation about what exactly is returned by the various sensors (current power, gateways, …).
I also have the SolarEdge ModBud power meter, which was an option for the inverter, and want to be sure this is the HW that is used to compute the sensor.solaredge_power_consumption.
Here’s what I see in Dev Tools > States filtering on solaredge. I have the Zigbee gateway.
Entity | State | Attributes |
Filter entities | Filter states | Filter attributes |
sensor.solaredge_batteries | 0 | batteries: friendly_name: solaredge (Batteries) |
sensor.solaredge_current_power | 3884.342 | unit_of_measurement: W friendly_name: SolarEdge Current Power icon: mdi:solar-power |
sensor.solaredge_current_power_kwh | 3.88 | friendly_name: solaredge_current_power_kwh |
sensor.solaredge_energy_this_month | 765037.0 | unit_of_measurement: Wh friendly_name: solaredge (Energy this month) icon: mdi:solar-power |
sensor.solaredge_energy_this_month_kwh | 765.04 | friendly_name: SolarEdge This Month icon: mdi:solar-power unit_of_measurement: kWh |
sensor.solaredge_energy_this_year | 6450311.5 | unit_of_measurement: Wh friendly_name: solaredge (Energy this year) icon: mdi:solar-power |
sensor.solaredge_energy_this_year_kwh | 6450.31 | friendly_name: SolarEdge This Year icon: mdi:solar-power unit_of_measurement: kWh |
sensor.solaredge_energy_today | 3040.0 | unit_of_measurement: Wh friendly_name: solaredge (Energy today) icon: mdi:solar-power |
sensor.solaredge_energy_today_kwh | 3.04 | friendly_name: SolarEdge Today icon: mdi:solar-power unit_of_measurement: kWh |
sensor.solaredge_gateways | 0 | gateways: friendly_name: solaredge (Gateways) |
sensor.solaredge_grid_power | unknown | friendly_name: solaredge (Grid Power) icon: mdi:power-plug |
sensor.solaredge_inverters | 1 | inverters: [object Object] friendly_name: solaredge (Inverters) |
sensor.solaredge_lifetime_energy | 6456638.0 | unit_of_measurement: Wh friendly_name: solaredge (Lifetime energy) icon: mdi:solar-power |
sensor.solaredge_lifetime_energy_kwh | 6456.64 | friendly_name: SolarEdge Lifetime icon: mdi:solar-power unit_of_measurement: kWh |
sensor.solaredge_meters | 0 | meters: friendly_name: solaredge (Meters) |
sensor.solaredge_power_consumption | unknown | friendly_name: solaredge (Power Consumption) icon: mdi:flash |
sensor.solaredge_sensors | 0 | sensors: friendly_name: solaredge (Sensors) |
sensor.solaredge_site_details | Active | name: Site Name peak_power: 8 last_update_time: 2019-09-26 installation_date: 2019-02-01 type: Optimizers & Inverters manufacturer_name: REC model_name: N-Peak 320 DC maximum_power: 320 friendly_name: solaredge (Site details) |
sensor.solaredge_solar_power | unknown | friendly_name: solaredge (Solar Power) icon: mdi:solar-power |
sensor.solaredge_storage_power | unknown | friendly_name: solaredge (Storage Power) icon: mdi:car-battery |
Yes, I had obviously seen the entities list already, but it’s a bit strange there is no documentation anymore about what each of these relate to. I understand the “monitored conditions” have gone out of the configuration, but seen all of these sensors do get created it would make sense to document them somewhere.
Again, some of the sensors are straightforward, some others I still wonder what they actually report or relate to.
Home Assistant 1.0 will not support “monitored conditions” so that’s why they removed it from the Solar Edge component. All data will be saved received from the endpoint will be saved. You, as a user, can decide if you want to show it somewhere.
In the release notes there is a remark about breaking change. It was that solar edge was moved from ‘sensor’ to it’s own integration.
So move the:
site_id: !secret solaredge_site_id
monitored_conditions:
- condition 1
- condition 2
- etc...
to it’s own integration section like:
solaredge:
I have no issue with the monitored conditions going away, as long as the right sensors are being created.
Again, all I’m looking for is a description of the sensors created by the integration module.
For instance it’s not clear what these are:
- sensor.solaredge_meters
- sensor.solaredge_sensors
And also not clear what is the difference between these except for the unit (kW and W):
- sensor.solaredge_solar_power
- sensor.solaredge_current_power
Also, any way of getting the data per-pannel that is sent out by sniffing a mirrored port from the inverter? not sure this data that can be seen in the API, but it can be seen in the solaredge app so it is being transmitted somehow to their servers.
Does anyone here have the same problem as i have by intergrate solar edge to it’s own intergrations section?
I looks like the intergrations is working cause i get updatet data from solaredge and the values are the same as in my app. But in de logging every 10 min (when it do a reqeust) i get the following error in my logging.
Log Details (ERROR)
Tue Oct 15 2019 17:25:44 GMT+0200 (Midden-Europese zomertijd)
Missing connections in power flow data
I already mentioned this in this thread. but it looks like no one has a solution. Are there more people with this problem?
Today I had a tech from the company that installed my inverter at my house to try and get the SolarEdge Monitoring website to display data. He downloaded the firmware again, and then did a factory reset. After that I seem to be getting good data in Hassio and on the SolarEdge website (it did zero out my previous data). It also put a 3.5 kW power limit on my inverter, which I discovered on Home Assistant. They will be back tomorrow to fix that problem (should put out 10 kW). I will keep you posted.
I still think that the average optimizer temperature is displaying centigrade not fahrenheit but not sure how to change it.
Thanks for the reply.
Hello everyone,
is it possible to gather data from more than one inverter? i have two inverters, how can i collect data from both?
Hi all,
Is it possible to get the current battery charge? I can see the data is definitely available in the API, but I’m not sure if the data is available in HA.
Thanks!
Hi Gido,
do you know if its possible to add 2 SE sites to HA? I have 2 SE inverters and each belongs to different site. I’ve not been able to figure how to add it to my HA.
Hi @ozarn, interesting, never really thought of that. I had a look but keep getting a duplicate key 'api_key'
. Maybe with different packages in the HA configuration?
Thats what i got as well before posted, duplicate key. Please forgive me, i am a HA newbie. I am not sure what do you mean by different packages .
That’s fine , I was referring to the packages configuration. Just tried it with my own setup (by adding a duplicate) but doesn’t seem to be working. I did find a similar topic with multiple Tradfri gateways. They have similar issues though - sorry I can’t help you any further.
Thank you for letting me know and trying. I’ll check out Tradfri thread .
I had the SolerEdge working file till few versions back (can’t remember which). I have updated the configuration.yaml to the new API and I get no error s in the LOG and no sensors at all.
I might call SolarEdge as one of the posts suggested this might help as I see no firmware update capability nor re-boot in the web monitoring of my system.
