Simple code to get all Data via API direct from you Solax Pocket Wifi 2.0 with firmare 3.003.02.
I found a very interesting post homeassistant-cz, copied the code, reworked it.
Running on
Home Assistant 2022.11.3
Supervisor 2022.10.2
Operating System 9.3
Frontend 20221108.0 - latest
You just need to add code to configuration.yaml, templates.yaml and then add 1 device to the energy dashboard.
add this to configuration.yaml don’t forget to adapt the IP of your solax module amd the password (just read the QR code on the stick)
### Solax REST command online sensor ###
rest:
- authentication: digest
scan_interval: 10
resource: http://###.###.###.####/ # IP of solax module
payload: "optType=ReadRealTimeData&pwd=xxxxxxxxxxx" # replace xxxxxxxxxx with password in whole file
method: POST
headers:
Content-Type: "application/x-www-form-urlencoded"
- name: "solax_rest_data"
json_attributes:
- sn
- ver
- type
- Data
- Information
value_template: 'OK' # dummy value, not used; avoids the "State max length is 255 characters" error
add this to templates.yaml
if you don~t use a template.yaml file add the templates to configuration.yaml and add this on top (as mentioned by Trilis29)
do not forget to exchange the “xxxxxxxxx” with the serial number of your device.
sensors:
###Solax
- name: solax
state: >
{% if state_attr('sensor.solax_rest_data', 'sn') == "xxxxxxxxx" %}{{ now() }}
{% else %}{{ (states('sensor.solax')) }}{% endif %}
attributes:
sn: >-
{% if state_attr('sensor.solax_rest_data', 'sn') == "xxxxxxxxx" %}{{ (state_attr('sensor.solax_rest_data', 'sn')) }}
{% else %}{{ (state_attr('sensor.solax', 'sn')) }}{% endif %}
ver: >-
{% if state_attr('sensor.solax_rest_data', 'sn') == "xxxxxxxxx" %}{{ (state_attr('sensor.solax_rest_data', 'ver')) }}
{% else %}{{ (state_attr('sensor.solax', 'ver')) }}{% endif %}
type: >-
{% if state_attr('sensor.solax_rest_data', 'sn') == "xxxxxxxxx" %}{{ (state_attr('sensor.solax_rest_data', 'type')) }}
{% else %}{{ (state_attr('sensor.solax', 'type')) }}{% endif %}
Data: >-
{% if state_attr('sensor.solax_rest_data', 'sn') == "xxxxxxxxx" %}{{ (state_attr('sensor.solax_rest_data', 'Data')) }}
{% else %}{{ (state_attr('sensor.solax', 'Data')) }}{% endif %}
Information: >-
{% if state_attr('sensor.solax_rest_data', 'sn') == "xxxxxxxxx" %}{{ (state_attr('sensor.solax_rest_data', 'Information')) }}
{% else %}{{ (state_attr('sensor.solax', 'Information')) }}{% endif %}
###AC detailed information
- name: "Solax L1 Voltage"
state: "{{ state_attr('sensor.solax', 'Data')[0] | int(default=2300) / 10}}"
unit_of_measurement: "V"
device_class: "voltage"
- name: "Solax L2 Voltage"
state: "{{ state_attr('sensor.solax', 'Data')[1] | int(default=2300) / 10}}"
- name: "Solax L3 Voltage"
state: "{{ state_attr('sensor.solax', 'Data')[2] | int(default=2300) / 10 }}"
- name: "Solax L1 Current"
state: >
{% if state_attr('sensor.solax', 'Data')[3] > 32767 %}{{ (state_attr('sensor.solax', 'Data')[3] - 65536) | int(default=0) / 10 }}
{% else %}{{ state_attr('sensor.solax', 'Data')[3] | int(default=0) / 10 }}{% endif %}
unit_of_measurement: "A"
device_class: "current"
- name: "Solax L2 Current"
state: >
{% if state_attr('sensor.solax', 'Data')[4] > 32767 %}{{ (state_attr('sensor.solax', 'Data')[4] - 65536) | int(default=0) / 10 }}
{% else %}{{ state_attr('sensor.solax', 'Data')[4] | int(default=0) / 10 }}{% endif %}
- name: "Solax L3 Current"
state: >
{% if state_attr('sensor.solax', 'Data')[5] > 32767 %}{{ (state_attr('sensor.solax', 'Data')[5] - 65536) | int(default=0) / 10 }}
{% else %}{{ state_attr('sensor.solax', 'Data')[5] | int(default=0) / 10 }}{% endif %}
- name: "Solax L1 Power"
state: >
{% if state_attr('sensor.solax', 'Data')[6] > 32767 %}{{ (state_attr('sensor.solax', 'Data')[6] - 65536) | int(default=0) }}
{% else %}{{ state_attr('sensor.solax', 'Data')[6] | int(default=0) }}{% endif %}
unit_of_measurement: "W"
device_class: "power"
- name: "Solax L2 Power"
state: >
{% if state_attr('sensor.solax', 'Data')[7] > 32767 %}{{ (state_attr('sensor.solax', 'Data')[7] - 65536) | int(default=0) }}
{% else %}{{ state_attr('sensor.solax', 'Data')[7] | int(default=0) }}{% endif %}
- name: "Solax L3 Power"
state: >
{% if state_attr('sensor.solax', 'Data')[8] > 32767 %}{{ (state_attr('sensor.solax', 'Data')[8] - 65536) | int(default=0) }}
{% else %}{{ state_attr('sensor.solax', 'Data')[8] | int(default=0) }}{% endif %}
- name: "Solax Total AC Power"
state: >
{% if state_attr('sensor.solax', 'Data')[9] > 32767 %}{{ (state_attr('sensor.solax', 'Data')[9] - 65536) | int(default=0) }}
{% else %}{{ state_attr('sensor.solax', 'Data')[9] | int(default=0) }}{% endif %}
- name: "Solax L1 Frequency"
state: "{{ state_attr('sensor.solax', 'Data')[16] | int(default=5000) / 100}}"
unit_of_measurement: "Hz"
device_class: "frequency"
- name: "Solax L2 Frequency"
state: "{{ state_attr('sensor.solax', 'Data')[17] | int(default=5000) / 100}}"
- name: "Solax L3 Frequency"
state: "{{ state_attr('sensor.solax', 'Data')[18] | int(default=5000) / 100}}"
### Solax Summary and statistic sensors ###
- name: "Solax Feed-in Power"
state: >
{% if state_attr('sensor.solax', 'Data')[34] > 32767 %}{{ state_attr('sensor.solax', 'Data')[34] - 65536 }}
{% else %}{{ state_attr('sensor.solax', 'Data')[34] }}{% endif %}
- name: "Solax Consumption"
state: >
{% if state_attr('sensor.solax', 'Data')[47] > 32767 %}{{ state_attr('sensor.solax', 'Data')[47] - 65536 }}
{% else %}{{ state_attr('sensor.solax', 'Data')[47] }}{% endif %}
- name: "Solax Energy total"
state: "{{ ((state_attr('sensor.solax', 'Data')[69] * 65536) + state_attr('sensor.solax', 'Data')[68]) | float / 10 }}"
unit_of_measurement: "kWh"
device_class: "energy"
### Today's statistics ###
- name: "Solax Grid out today"
state: "{{ state_attr('sensor.solax', 'Data')[90] | float / 100 }}"
- name: "Solax Grid in today"
state: "{{ state_attr('sensor.solax', 'Data')[92] | float / 100 }}"
- name: "Solax Battery discharge today"
state: "{{ state_attr('sensor.solax', 'Data')[78] | float / 10 }}"
- name: "Solax Battery charge today"
state: "{{ state_attr('sensor.solax', 'Data')[79] | float / 10 }}"
- name: "Solax Energy today"
state: "{{ state_attr('sensor.solax', 'Data')[82] | float / 10 }}"
- name: "Solax Energy incl battery today"
state: "{{ state_attr('sensor.solax', 'Data')[70] | float / 10 }}"
### Total values for Energy panel - needs customization in customize.yaml ###
- name: "Solax Solar energy total"
state: "{{ ((state_attr('sensor.solax', 'Data')[81] * 65536) + state_attr('sensor.solax', 'Data')[80]) | float / 10 }}"
state_class: total_increasing
- name: "Solax Grid out total"
state: "{{ ((state_attr('sensor.solax', 'Data')[87] * 65536) + state_attr('sensor.solax', 'Data')[86]) | float / 100 }}"
- name: "Solax Grid in total"
state: "{{ ((state_attr('sensor.solax', 'Data')[89] * 65536) + state_attr('sensor.solax', 'Data')[88]) | float / 100 }}"
- name: "Solax Consumption total"
state: "{{ state_attr('sensor.solax', 'Data')[88] | float / 100 }}"
- name: "Solax Battery discharge total"
state: "{{ ((state_attr('sensor.solax', 'Data')[75] * 65536) + state_attr('sensor.solax', 'Data')[74]) | float / 10 }}"
- name: "Solax Battery charge total"
state: "{{ ((state_attr('sensor.solax', 'Data')[77] * 65536) + state_attr('sensor.solax', 'Data')[76]) | float / 10 }}"
### PV detailed information ###
- name: "Solax PV1 Voltage"
state: "{{ state_attr('sensor.solax', 'Data')[10] | int(default=0) / 10}}"
- name: "Solax PV2 Voltage"
state: "{{ state_attr('sensor.solax', 'Data')[11] | int(default=0) / 10}}"
- name: "Solax PV1 Current"
state: "{{ state_attr('sensor.solax', 'Data')[12] | int(default=0) / 10 }}"
- name: "Solax PV2 Current"
state: "{{ state_attr('sensor.solax', 'Data')[13] | int(default=0) / 10 }}"
- name: "Solax PV1 Power"
state: "{{ state_attr('sensor.solax', 'Data')[14] | int(default=0) }}"
- name: "Solax PV2 Power"
state: "{{ state_attr('sensor.solax', 'Data')[15] | int(default=0) }}"
- name: "Solax Total PV Power"
state: "{{ (states('sensor.solax_pv1_power')|int + states('sensor.solax_pv2_power')|int) }}"
### Battery detailed information ###
- name: "Solax Battery Voltage"
state: "{{ state_attr('sensor.solax', 'Data')[39] | float / 100}}"
- name: "Solax Battery Current"
state: >
{% if state_attr('sensor.solax', 'Data')[40] > 32767 %}{{ (state_attr('sensor.solax', 'Data')[40] - 65536) / 100 }}
{% else %}{{ state_attr('sensor.solax', 'Data')[40] / 100 }}{% endif %}
- name: "Solax Battery Power"
state: >
{% if state_attr('sensor.solax', 'Data')[41] > 32767 %}{{ state_attr('sensor.solax', 'Data')[41] - 65536 }}
{% else %}{{ state_attr('sensor.solax', 'Data')[41] }}{% endif %}
- name: "Solax Battery SoC"
state: "{{ state_attr('sensor.solax', 'Data')[103] | int(default=0) }}"
unit_of_measurement: "%"
- name: "Solax Battery Remain Energy"
state: "{{ state_attr('sensor.solax', 'Data')[106] | int(default=0) / 10 }}"
- name: "Solax Battery Temperature"
state: "{{ state_attr('sensor.solax', 'Data')[105] | int(default=0) }}"
unit_of_measurement: "°C"
device_class: "temperature"
- name: "Solax Battery BMS status"
state: >
{% if state_attr('sensor.solax', 'Data')[45] | int == 1 %}OK
{% else %}Fail{% endif %}
### Invertor modes, states ###
- name: "Solax Battery Operation Mode"
state: >
{% if state_attr('sensor.solax', 'Data')[168] == 0 %}Self Use Mode
{% elif state_attr('sensor.solax', 'Data')[168] == 1 %}Force Time Use
{% elif state_attr('sensor.solax', 'Data')[168] == 2 %}Back Up Mode
{% elif state_attr('sensor.solax', 'Data')[168] == 3 %}Feed-in Priority
{% else %}I dont know{% endif %}
- name: "Solax Inverter Operation Mode"
state: >
{% if state_attr('sensor.solax', 'Data')[19] == 0 %}Waiting
{% elif state_attr('sensor.solax', 'Data')[19] == 1 %}Checking
{% elif state_attr('sensor.solax', 'Data')[19] == 2 %}Normal
{% elif state_attr('sensor.solax', 'Data')[19] == 3 %}Off
{% elif state_attr('sensor.solax', 'Data')[19] == 4 %}Permanent Fault
{% elif state_attr('sensor.solax', 'Data')[19] == 5 %}Updating
{% elif state_attr('sensor.solax', 'Data')[19] == 6 %}EPS Check
{% elif state_attr('sensor.solax', 'Data')[19] == 7 %}EPS Mode
{% elif state_attr('sensor.solax', 'Data')[19] == 8 %}Self Test
{% elif state_attr('sensor.solax', 'Data')[19] == 9 %}Idle
{% elif state_attr('sensor.solax', 'Data')[19] == 10 %}Standby
### Invertor and management module information ###
- name: "Solax Module SN"
state: "{{ state_attr('sensor.solax', 'sn') }}"
- name: "Solax module fw version"
state: "{{ state_attr('sensor.solax', 'ver') }}"
- name: "Solax type"
state: > # Other Solax invertor type are described in web API manual
{% if state_attr('sensor.solax', 'type') == 14 %}X3-Hybrid G4
{% else %}Other{% endif %}
- name: "Solax Inverter SN"
state: "{{ state_attr('sensor.solax', 'Information')[2] }}"
- name: "Solax Inverter Nominal Power"
state: "{{ state_attr('sensor.solax', 'Information')[0] | float | round(1) }}"
unit_of_measurement: "kW"
### Test parameters ###
- name: "Solax Inverter Temperature inner ?"
state: "{{ state_attr('sensor.solax', 'Data')[46] | int(default=0) }}"
- name: "Solax Inverter Temperature ?"
state: "{{ state_attr('sensor.solax', 'Data')[54] | int(default=0) }}"
do not forget to check configuration before rebooting.
After the reboot add “Solax Solar Energy total” to your energy dashboard as solar production and wait a little bit.
The trick to get the delta of the whole consumption into the energy board is this “state_class: total_increasing”
