I have HA on Raspberry Pi 4, of course connected to LAN/ethernet.
I would like to have an addon hardware with an SIM card (4G/5G, Sweden/Europe) for data traffic to do requests to e.g. Pushover in some cases.
Would this be possible?
Do you have any hardware reconnedations?
Do you have any examples/scripts to do such thing?
I am using the board below for some LLM voice to text from answering a phone call from humans. So a different use case than what you are interested in. That said, what I will offer is that the board was easy to configure 1st with at RPI4 then with a RPI5 hardware wise. I am using Tello as the SIM provider, the board connected to their network very easily. From what I read, a number of problems folks have is with getting the board to work with their selected SIM provider., so select carefully on this.
The documentation from WaveShare is okay, not super. You can find some additional Youtube tutorials on how to use the board as a IP fail over device. There are C and Python examples for various services using the board in the WaveShare github : SMS, Voice, IP, GPS.
Waveshare 4G/3G/GNSS HAT for Raspberry Pi Zero/Zero W/Zero WH/2B/3B/3B+ Jetson Nano Based on SIM7600A-H LTE CAT4 up to 150Mbps Support Phone Call Wireless Communication
My usecase is also different, but I’m using a Waveshare 5G dongle with my Raspberry Pi4 (running OpenWRT). It’s cheap and it being a USB dongle, you can use it elsewhere too.
If all you need is backup internet for the device and its not going to be moved from the location then just invest in a fail over setup with the network switch/router so that WAN 2 becomes active when WAN 1 is down and then you can plug in a 5G modem into WAN 2.
Thanks, that could be an option but likely more expensive.
I have a Ubiquiti Dream Machine but no UPS currently, so that would be needed (incl the switch)
Thanks @TH3xR34P3R
Maybe I should start with an UPS to power Unifi DM, switch and media converter, then I have protection for power outages.
Then add the UniFi LTE Backup you suggested (it is available locally)
If you’re looking to send data via SIM card on a Raspberry Pi 4, especially for tasks like sending requests to Pushover, there’s a pretty straightforward setup you can consider. First off, you’d need a compatible 4G/5G modem that can interface with your Pi. Something like the Huawei E3372 USB dongle could work, or you might explore options like the Waveshare SIM7600X Hat, which has support for 4G and is relatively easy to integrate.
Could you tell use some details about the easy integration of SIM7600X HAT? It seems to me, according to what I see around, that I have to become familiar with AT commands, keep configuration on the OS level, therefore install HASS in RpiOS etc. That does not look easy but you might have some other way in your mind. Share it with us. Thank you.
