SOLVED! - Almost: Upgrading to 0.91.4 - DON'T do it and don't upgrade Node-red and Configurator
Nothing works after upgrading from 0.91.0 to 0.91.4 - quite annoying
Upgrades for Node-red and Configurator depended on Hassio 0.91.4 so I chose to upgrade - yes now the “crap” is not working anymore.
Why not say or write what we must do after upgrading (it could be a new security token or something). But you have to figure it out yourself - that is not good user experience
What issues specifically are you having? I’m sure someone here who is using 0.91.4 without issue would be happy to assist.
Ok thanks.
First of all. Log is not showing any issues but the user-interface does.
But is I try some of the other parts I see this:
All in all - nothing is working - great !
Configurator and Node-RED is to expected since they now use Ingress.
Please read the blog post and FAQ here:
I’ve seen the same on my end with other upgrades. Most of it was cleared up by doing a page reload or cache flush on my browser.
OK, So, to be clear – “Nothing works” means that your addons that you have in a panel_iframe aren’t showing up in the panel_iframe?
For me, for the addons that enabled Ingress, I just went to hass.io, clicked on the addon I want and then click the open in webui button and it’ll take you to their pages.
Thank you - I can see that I’m not the only one. But could someone give a Big warning against upgrading anything - who have thought that going from 0.91.0 to 0.91.4 would have such a fatal impact. OK Configurator and Node-red add-on went ahead on the first version digit but again - now I cannot do a SH** with my Node-red automations.
THANK YOU !!!
Ctrl F5
I almost got a hart attack - why is this “common” knowledge? I would have printed it with BIG LETTERS in the installation guide.
  • Reload white pages with Ctrl+F5 to reload iframes
  • Press Ctrl+Web-ui on Add-on pages to reload add-on iframes
But not totally fixed yet - I might have to stay up all night to fix this:
iframe part for Configurator is not working from the menu only from the add-on section.
The addons are no longer accessible through exposed ports, they now use the ingress functionality. To access them you currently go to the Hass.io page, navigate to the addon, and press the button to open the web ui.
In a future update there will be a button to add new options to the left hand nav bar to replace the panel_iframes
Well then I cannot access Node-red anymore even not from the add-on part.
This is my Node-red configurator started from the add-on part. My topic conclusion is still right - don’t even think about upgrading anything…
I’m afraid to say I’m fully updated and mine’s working though.
It’s tough to tell from your screenshot because of the cropping - you’ve definitely gone through HassIO > Dashboard > Node-Red > Open Web UI?
What version of Node Red and HASS are you running?
Node-red version 3.0.1
Hassio 0.91.4 (160)
Web UI worked once on my PC afterwards only black screen.
Now I have to go to bed. Have not sleept for 20 hours. And then this happened.
For the configurator, Replace the iframe section in your configuration.yaml with this
panel_custom:
  - name: hassio-main
    sidebar_title: Configurator
    sidebar_icon: mdi:wrench
    js_url: /api/hassio/app/entrypoint.js
    url_path: configurator
    embed_iframe: true
    require_admin: true
    config:
      ingress: "core_configurator"
Not HA’s fault or any developer’s fault.
Hopefully you’ll be in a better mood in the morning.
If you haven’t already, I’d try just restarting HASS as well, if you didn’t already try that post-upgrade.
I’m so dam tired of this Lovelace, nothing works like they say, now they pull this crap with the upgrades. Thanks for nothing.
This works, a Big Thank You.
I can hardly wait for 92.0 so we can start over again.
Yeah, you should probably ask those jerks for a refund… :roll_eyes:
Sturm and Drang
